Installing factory bed rail system with factory bed-liner myself?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Boosted4runner, May 29, 2018.
  1. May 29, 2018 at 1:31 PM
    Boosted4runner
    Boosted4runner [OP] Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    My 2015 DC 6.5' bed has the Toyota OEM liner installed no rail system. I found the $200 Bed Rail System Kit I want to install. I don't understand how to install the Bed Rail System with the factory bed liner? I watched a video that has both, but can't see up close enough to how they work together. Do the rails mount to the liner - or do I need to cut a section of the liner where the rails go?
  2. May 29, 2018 at 1:33 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Interested in this too
  3. May 29, 2018 at 2:35 PM
    Borgs
    Borgs New Member
    PA
    Do you mean the drop-in liner? If so, you probably need to cut it to have clearance, or at least to be able to see where to drill holes. They make two different liners from factory, one with room for rails, one without.
  4. May 29, 2018 at 2:59 PM
    Boosted4runner
    WA
    Yea, the drop-in liner. My liner does not have room for rails. It looks like the top edges of the liner tuck up behind the factory bed rail caps.
  5. May 29, 2018 at 3:01 PM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    I just did this install today and really stripped all the bolts that held the strip to the bed. It looked like the holes matched up and they were already threaded but under up stripping the bolts, the bolt heads and probably the bed threats too. Agghhhh!!!
  6. May 29, 2018 at 3:08 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    - Screw some studs into the existing rail mount holes.
    - Drop in your liner and press it against the studs to make a visible indent in the liner.
    - Drill a hole in the liner at each indent.
    - Remove the studs, and install the rails with the appropriate bolts.
    Sterlinglwood likes this.
  7. May 29, 2018 at 3:15 PM
    Boosted4runner
    WA
    So the liner has to be removed? Is that a PITA? Do the bed rail caps have to be removed?
  8. May 29, 2018 at 3:52 PM
    Borgs
    Borgs New Member
    PA
    This.
  9. May 29, 2018 at 3:53 PM
    Borgs
    Borgs New Member
    PA
    In your situation I think so, so you can go the stud route described above.
  10. May 29, 2018 at 4:04 PM
    Heatonrx
    Heatonrx New Member
    Bought mine used but rail just covered the top of the liner. It finished the edge and helped hold the sides of the liner down. It's a OEM. I just placed it in and screwed in the rail system. Rails weren't in when I took delivery.
    Nelson76 and Boosted4runner[OP] like this.
  11. May 29, 2018 at 4:09 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    First thing you should do, is get rid of the plastic drop in liner, they ain't worth a shit, spend the money on a spray in liner. Well worth it.
    15whtrd and Norfolk757 like this.
  12. May 29, 2018 at 6:04 PM
    Borgs
    Borgs New Member
    PA
    This. I switched to a LineX spray in a few months ago. Love it. Well worth the money.
    15whtrd likes this.
  13. May 29, 2018 at 10:03 PM
    Boosted4runner
    WA
    I’ve had multiple bed liners for 20 years.
    I always did Line-X and Rhino, and a DIY.
    To be honest - they won’t last for what I do. I live on acreage and the back of my bed will get beat to shit. Hauling a few boulders in my 1 ton damaged/dented the bed pretty bad. The dents look like complete shit.
    The plastic liner prevents that, unlike the spray ins.
    Just this last weekend we cut a bed full of wood for firewood while camping. It was such a nice relief to toss logs in the back without fear of denting the bed.
    On top of that, the spray ins look nice for a few years, then turn gray. I never liked that.
    If the factory liner is considered shitty because of fitment, that doesn’t bother me one bit. Mine seems to fit fine, sure it’s not perfect - but I’d trade not a perfect fit for peace of mind not denting or beating the shit out of my bed.
  14. May 29, 2018 at 10:12 PM
    Boosted4runner
    WA
    Did you have to take off the bed rail caps?
  15. May 30, 2018 at 1:50 PM
    Heatonrx
    Heatonrx New Member
    The bed rail kit wasn't in yet. Came packaged up. Dropped in the liner and then installed the rails.
  16. May 31, 2018 at 9:08 AM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Toyota told me the liner has to be yaken out and you have to cut it below the rail.
  17. Jun 1, 2018 at 12:21 AM
    Boosted4runner
    WA
    I’m almost positive this is what I’m going to have to do.
  18. Jun 1, 2018 at 4:03 AM
    Professional Hand Model
    Hand Protectors
    This^^^
    A working truck likes the drop in liner!
    Spray ins are for road princess’. Hahahha
    Tundyfundy likes this.
  19. Jun 1, 2018 at 6:06 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Until you take that drop in out and see the mayhem it did on ur bed lol. I took mine out and couldnt believe how it looked.
  20. Jun 1, 2018 at 7:29 AM
    Boosted4runner
    WA
    If the drop in comes out, a new one goes in ;-) Always the same color and no dented bed.
    There’s always the option to Linex after a drop in is removed too if that’s what the next owner wants to do.
    Shoveling river rock out of the back here in the next few weekends (not big enough job for dumptruck load and the Kubota). I always hated a metal shovel on a linex bed. Looking forward to not giving a shit with the drop in
  21. Jun 1, 2018 at 1:48 PM
    Hand Protectors
    You could be right, but my bed is not rusting from underneath after routine inspection. I’d be stupid to think between the bed and drop in doesn’t have abrasions and surface rust from the drop liner rub so yeah you are correct again. As far as mayhem I’m sure there would be plenty more mayhem without the drop in as the spray on stuff has no cushion for gouging/pounding type occurences. Plus as mentioned by another poster above the spray in fades gray and needs touch up. I like the action of the drop liner when sliding drywall and other heavy items into/around the cargo area. The spray liner texture acts like heavy grit sandpaper that clogs up and prevents easily sliding material. Like I said a working mans truck and just personal opinion which really doesn’t mean much in the grand scheme of life. And yeah as Boosted above says, shoveling with a spray liner is a pita. Each option has its place. Spray liner is not for me.
    Boosted4runner[OP] likes this.
  22. Jun 7, 2019 at 8:22 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  23. Nov 8, 2023 at 2:30 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Have a 2019 with factory spray in liner. Seems they sprayed over the holes. How the hell do I install now? Can’t even see where the holes would be.
