Installing kicker panel
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Dec 31, 2019.
  1. Dec 31, 2019 at 5:07 AM
    Genuine Cooling Systems [OP] New Member Vendor
    Is there a trick to re installing the kicker panel? I can't seem to get it to line up with the white mount on the inside.
    TTund16 likes this.
  2. Dec 31, 2019 at 5:11 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Sucks major ass....both of mine are jacked up
    TheBeast likes this.
  3. Dec 31, 2019 at 5:50 AM
    Thank you! That makes sense now. I've literally tried close to 100 times now, the thing is a pain in the ass.
  4. Dec 31, 2019 at 6:56 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Those were a pain. I had Toyota redo mine while I was in for service. I tried a dozen times and couldn’t get it back.
  5. Dec 31, 2019 at 9:07 AM
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    This is very helpful info, thank you!
    NewImprovedRon likes this.
  6. Dec 31, 2019 at 9:15 AM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    Lol I am in the same boat after installing Cell Booster and VHF Radio I noticed the kick panel is not flush at the top and I have been trying for weeks to get it to clip back in...thanks now I know how to get it back on properly.
  7. Dec 31, 2019 at 9:29 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Mine have been popping out pretty much from day one. I push them back on place and after a couple of days they pop back out. I stopped worrying about it 5 years ago.
  8. Dec 31, 2019 at 9:54 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I've had that panel out at least a dozen times in the last year. Every time I have to pop the white clip from the truck and reinsert it in the slot on the panel before putting it all back together.
  9. Dec 31, 2019 at 10:02 AM
    Squatting Pigeon
    Holden
    North Texas
    Right? That's a good company man/woman right there!
  10. Dec 31, 2019 at 10:14 AM
    TheBeast The Beach
    my clips are barely holding from all the removing. This is common spot for wiring etc.I should get some new clips at some point..
  11. Dec 31, 2019 at 10:21 AM
    Same engineer who determined the best spot to locate the starter........and water pump......and alternator.....and........
    Toyotoholic and NewImprovedRon like this.
  12. Dec 31, 2019 at 10:42 AM
    .....and chose stereo sound system supplier....and....
  13. Dec 31, 2019 at 10:48 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Remember: the clips are angled, so you have to assemble at the same angle or you will fold the clip or the mounting tab, thus bulging the panel.
  14. Dec 31, 2019 at 12:15 PM
    YorkT
    YorkT New Member
    I just went through all of this last Friday. I finally gave up and had my wife try it. While she was trying to connect it, I found an older post like this one. It took minutes to get the panel on after putting the upper clip back in the kick panel. I left the lower one attached to the truck wall and could slide the kick panel over it. .
  15. Jan 1, 2020 at 7:31 PM
    In case anyone broke the clips for the panel here is the part number. Your welcome.
    90467-09212
  16. Jan 1, 2020 at 8:36 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    This panel is the worst for me to put back together, took me about a thousand of cussing, putting the thing back down and start again . But finally got it put together but still doesn’t look correct.
  17. Jan 2, 2020 at 8:30 AM
    Did you take the clips out and install them on the panel?
  18. Jan 2, 2020 at 9:12 AM
    Ely010606
    SPARKS, NV
    At first no, then finally figured it out.
  19. Sep 27, 2021 at 4:43 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Just did mine, literally 18 secs,,,both clips. Yeahhhhh
    Ely010606[QUOTED] likes this.
  20. Mar 29, 2022 at 8:51 AM
    JoelThor26
    JoelThor26 New Member
    Joel
    Newport News, VA
    2018 Black CrewMax SR5
    Thor's Build (https://www.tundras.com/threads/thors-build-2018-crewmax-w-tss-package.99235)
    I'm not an extremely affectionate person - but I love you... 5 months of trying to find the part number for these damn things... muchas gracias, vielen dank, all that...
  21. Mar 29, 2022 at 9:27 AM
    brkncly
    brkncly New Member
    Oregon
  22. Jul 25, 2022 at 6:24 PM
    Norton50!!!
    Norton50!!! New Member
    Patrick
    2019 TRD Pro
    OMG, You are the best! Thank you!
