Intake manifold spacer
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jnickoles, Feb 4, 2024.
  1. Feb 4, 2024 at 6:11 PM
    Jnickoles
    Jnickoles [OP] New Member
    2021 Tundra sr5
  2. Feb 4, 2024 at 6:29 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I haven't seen any convincing evidence that TB spacers do anything on Tundras. If you find a conclusive test please share it.
    As far as the intake runner kit increased runner length and plenum volume can improve performance much like headers. I haven't seen one tested on Tundra but I've seen one used on other platforms to make some HP gains.
    Mdl likes this.
  3. Feb 4, 2024 at 6:30 PM
    Jnickoles
    2021 Tundra sr5
    Interesting. I’d be curious to hear about peoples real world results with this
    Mdl likes this.
  4. Feb 4, 2024 at 6:43 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @Mdl, weren't you the one keeping the closest eye on this?
  5. Feb 4, 2024 at 6:44 PM
    Saltyhero13
    This product hasn't been released yet.
  6. Feb 4, 2024 at 7:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    An article I saved from awhile back concerning TB spacers. Interestingly I have a spacer of sorts. I have stacked adapter plates for the 95mm TB, about an inch total. I have not noticed ant seat of pants difference but I'm running the SC and non boost drivabilty seems the same.
    https://tundraheadquarters.com/stay-away-from-throttle-body-spacers/
    The AES plenum runner should give some increased low rpm torque. Plus being able to add nos or water/meth injection for each cylinder. They seemvto work on other platforms so I don't see why we wouldn't gain some torque too.
    Wynnded, Saltyhero13 and reywcms like this.
  7. Feb 5, 2024 at 4:46 AM
    Saltyhero13
    Great article. I doubt a TB spacer will do much for a supercharged Tundra for the similar reasons stated in the article. Any swirly air generated by the TB spacer is being manipulated by the rotors/screws of the blower before it gets in the engine.
    On one of the Harrop videos they use it to squeeze out some extra HP.
