Interior lights staying on?
Discussion in '1st Gen Tundras (2000-2006)' started by Galladanb, Jul 11, 2023.
  1. Jul 11, 2023 at 3:21 PM
    Galladanb
    Galladanb [OP] New Member
    Southeastern Tennessee
    2002 AC Sr5
    So as I have been installing the backup cam, going in and out of the truck, my door lights have stayed on overnight and ran down the battery…
    no problem, I just recharged the battery. All is well for now.
    But, now I have come up with a question for all you great knowledge guru’s, please?
    shouldn’t the panel light dimmer knob (number 22 in the image above) have a positive little bump or catch to let me know the lights are set to full bright? Or is there some other way to set a time out for the lighting upon leaving and locking up the truck???
    I did a search for this, but must not know the correct terminology to find this…
  2. Jul 11, 2023 at 3:26 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Mine is set to full bright but the lights don’t stay on when the doors are closed and things are locked up. I can’t recall if there’s a delay or not. I’d have to check when it gets dark in 3 hours.
    Galladanb[OP] likes this.
  3. Jul 11, 2023 at 3:33 PM
    Galladanb
    2002 AC Sr5
    Yea, today, I double checked and it was lights out as expected…
    So, don’t really know why they were on…
    FYI, Cargo light was off also…
  4. Jul 11, 2023 at 3:39 PM
    Jack McCarthy
    Bill
    North of Boston
    My cargo light is the only thing that stays on for 30 seconds now that I recall.
  5. Jul 11, 2023 at 4:20 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Won't assume if an 02 is same as an 04 but that knob on an 04 goes full CCW(8 o'clock) to decrease and full CW(4 o'clock) to increase. It also controls only the Instrument panel bckgnd lights and Integration Control and Panel(A/C, Heat, Fan knobs....etc). Does not control door courtesy, footwell or Dome light, at least not in an 04.
    If you haven't noticed and if it happens again, take note if the open door indicator light is on. Might be a door switch going wonky turning appropriate lights on.
    Galladanb[QUOTED][OP] likes this.
  6. Jul 11, 2023 at 4:56 PM
    There’s a switch for the front map lights and a switch for the dome light, both overhead. You can turn them both on, on with opening the doors or off. The front map lights are manual on off, or door triggered.
