Intermediate shaft removal
Discussion in '1st Gen Tundras (2000-2006)' started by Sbct, Jul 14, 2024.
  1. Jul 14, 2024 at 12:37 PM
    Sbct
    Sbct [OP] New Member
    Dave
    2002 Tundra 4.7L. 4x4.
    None
    I have removed both pinch bolts on the intermediate shaft. I cannot get this to come off of either the steering rack or the shaft itself.
    I have tried to get a little wedge up in there and after about 30 minutes, I still can’t get it to come off. Any suggestions?
  2. Jul 14, 2024 at 12:42 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Remove the bolts holding it to the bottom coupler and open up the shaft upper coupler on a vice to get it out.
  3. Jul 14, 2024 at 12:55 PM
    Sbct
    Dave
    None
    I tried. Those are corroded as hell.
  4. Jul 14, 2024 at 1:20 PM
    Jack McCarthy
    Bill
    North of Boston
    Impact won’t get them out?
    Looks like a shallow wobble socket is required to get in there so that may be an issue.
  5. Jul 14, 2024 at 1:23 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Have you sprayed any penetrant on the upper splines? They look dry as a bone
    Mr Badwrench and Jack McCarthy like this.
  6. Jul 14, 2024 at 3:56 PM
    Sbct
    Dave
    None
    Got it removed with help from my neighbor. I am going replace the intermediate shaft as well. The little round bushing thing in this pic, I can’t tell if it is actually broken or if that’s split is there it looks very smooth like it’s almost supposed to be there. I was looking at the intermediate shafts online and none of them seem to come with that little rubber bushing and neither did my new rack and pinion can I just reuse that?
  7. Jul 14, 2024 at 4:08 PM
    Jack McCarthy
    Bill
    North of Boston
    Couldn’t hurt to reuse it.
  8. Jul 14, 2024 at 4:09 PM
    Mind you: The following link is for my '06, which may differ significantly from your '02.
    That said: https://toyota-usa.epc-data.com/tundra/uck40/3806/chassis/4501/?full
    Mouseover any number for a description. Click on any number to get a Toyota part number. But moreover, rather than aimlessly plug around for parts, please use the bullets at the top of this sticky thread to help yourself. After you plug in your VIN, click through onto "Transmission & Chassis", then click on "Steering column & shaft". Click 'open full size scheme' to get the big view I linked above, so you can see things more clearly.
