Intermittent - lights do not flash when unlocking
Discussion in 'Lighting' started by Tundra234, Jul 31, 2023.
  1. Jul 31, 2023 at 8:46 AM
    Tundra234 [OP] New Member
    I noticed that intermittently my lights (front and rear) do not flash when unlocking the truck the first time I hit the button. If I hit the button a few times they work, and I have only noticed it while unlocking. Any ideas?
    I have Morimoto XBs and the Hottails in the rear. Both sets are about a year and a half old. Its not the lights causing it obviously.
    @memario1214 @RainMan_PNW
  2. Aug 17, 2023 at 6:35 AM
  3. Aug 17, 2023 at 11:08 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    does the truck actually unlock when you hit the button that first time (even if the lights don't flash)?
  4. Aug 17, 2023 at 11:43 AM
    Yes it does.
  5. Aug 17, 2023 at 11:48 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Any aftermarket equipment installed that integrates or ties into the unlock/security? (Aftermarket security, remote start, etc.)
  6. Aug 17, 2023 at 12:04 PM
    Not at all. It just started doing it about 2 weeks ago.
  7. Aug 21, 2023 at 8:25 AM
    Still have no idea what is causing this. I even changed the FOB battery again.
  8. Aug 21, 2023 at 9:49 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Honestly - no real idea. I’m slammed right now at work and home, so no real time to go digging through the wiring diagrams to try to understand what might be controlling that flash. Though on a 2020 I’m pretty sure it’s the ECU and not some external relay.
    1lowlife likes this.
  9. Sep 20, 2023 at 9:55 AM
  10. Sep 20, 2023 at 11:05 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Does the horn work? I think it honks or beeps when you lock or unlock. If this is all working and the truck is unlocking the fob battery is good.
    Its an issue inside the truck with sending a signal to the lights, have to tried with the factory lights just to make sure?
    I think its the blinkers that flash correct?
  11. Sep 20, 2023 at 11:13 AM
    The horn only sounds during an alarm. I changed the Fob battery as well. I haven't tried the factory lights yet but it has been fine for the last couple of years. Yes, it is the front and rear turn signals that flash. Sometimes they don't flash when locking either. Every once in a while they will flash like the are supposed to on the the first try, but most of the time they won't until I press the button a couple of times.
  12. Sep 20, 2023 at 11:28 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Yea very strange, I though there was a beeper also that made a sound.
    Have you looked around the Techstream customization menu? This sounds like something you can enable/disable.
  13. Sep 20, 2023 at 12:33 PM
    It's an intermittent issue so it wouldn't be the on/off setting. There is a beeper type unit that will sound if you do something like lock the doors and one is not closed all the way. I'll check for that.
  14. Sep 26, 2023 at 6:16 PM
    So I tried testing the warning buzzer. For normal operation, If you leave a door partially open and lock the truck with the fob, the warning buzzer would sound a steady tone. I tried that a few times today and it no longer does it. I'm at a complete loss between no buzzer and the lights not flashing when they are supposed to.
  15. Oct 11, 2023 at 7:31 AM
  16. Oct 11, 2023 at 3:17 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
  17. Oct 11, 2023 at 3:28 PM
    It's not turned off. All of a sudden I just started getting intermittent times to where they don't flash during unlocking. Now it's 98% of the time. The doors lock and unlock without any issues. If you partially close a.door and try to lock it with the fob, you would get a long tone letting you know that a door is open. It doesn't do that any more either.
    Nio9 likes this.
  18. Oct 11, 2023 at 3:34 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What happens when the door is partially open and you hit the unlock?
  19. Oct 11, 2023 at 3:36 PM
    It unlocks fine.
  20. Oct 11, 2023 at 4:47 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do the lights flash and confirmation beep?
  21. Oct 11, 2023 at 4:49 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Also if you start the truck and walk away with the key does it long beep?
  22. Oct 11, 2023 at 5:13 PM
    Ok i went out and tested it. If I leave a door partially open, all doors lock but no beep. When I unlock it, it beeps.
  23. Oct 11, 2023 at 6:38 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just another thought. Do you have LED interior lights installed and/or LED cargo bed light installed? The LED lights can cause interference issues with the fob. The shark fin is the antenna for the fob and is susceptible to interference because of its proximity to the LED lights.
  24. Oct 11, 2023 at 6:57 PM
    I have the interior leds from the factory and no I do not have the leds in the cargo lights. I was aware of that issue a while back. Everything worked fine since the truck was new. It started this a couple of months ago.
  25. Oct 11, 2023 at 7:08 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Have you tried the other fob?
  26. Oct 11, 2023 at 7:33 PM
    Yes, and even tried new batteries in them.
  27. Oct 11, 2023 at 8:27 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Try disconnecting the battery for 10min and reconnect. Yes I'm grasping.
  28. Oct 16, 2023 at 2:06 PM
  29. Oct 16, 2023 at 3:12 PM
    Toytech6466
    Toytech6466 New Member
    Tracy
    Santa Cruz
    23 Tundra 1794
    I would have to look at a wiring diagram, does it have a separate relay for the lights, do you have aftermarket lights? I have seen customers have issues where they park their car and there is a lot of interference that has cause issues(work at a radio station)?
    Have you checked TSBs
  30. Oct 16, 2023 at 3:40 PM
    Everything has worked completely fine for 3 years and then it started.
