Intermittent rough idle issue S.O.S
Discussion in '1st Gen Tundras (2000-2006)' started by ocdan, Aug 21, 2019.
  1. Aug 21, 2019 at 7:09 PM
    ocdan
    ocdan [OP] New Member
    Hey guys my names Daniel new to the forum i have an 02 tundra 4wd access cab unlimited. For the last three months ive had intermittent rough idle it happens sometimes on cold starts but it also happens frequently in drive at full stop the truck goes from 700rpm to 500rpm sometimes lower and almost stalls but has yet to stall, the truck isn't throwing any codes or misfire codes.
    so far the work ive done to fix the issue is clean the throttle body, i then cleaned and regreased the fly by wire mechanism on the throttle body, cleaned then replaced MAF, replaced TPS and the other day i put in new plugs(NGK iridium IX)
    I havent been able to pinpoint the issue if anyone has an idea of what it is i'd greatly appreciate it! Heres a pic of my rig and the throttle body before i cleaned it IMG_4021.jpg throttle body pic 1.jpg throttle body pic 2.jpg
  2. Aug 21, 2019 at 9:55 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I would check the fuel filter next.
    Just sounds like a fuel issue.
    GODZILLA likes this.
  3. Aug 22, 2019 at 4:37 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    Have a code reader check to see if there are any pending codes.
  4. Aug 22, 2019 at 6:29 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I would throw a can of Seafoam in your tank and change your fuel filter, love your black 1st gen though buddy that's one clean looking unit.
  5. Aug 22, 2019 at 7:04 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Harmonic balance is off?
  6. Aug 22, 2019 at 7:53 AM
    FirstGenVol
    FirstGenVol Even the aliens want my truck
    East TN
    2002 AC
    1st-welcome to the forum. Love your truck. 2nd- you've done all the things I would have done. My wife's Rav4 has a similar issue and when trying to diagnose it I kept getting these suggestions- The idle air control valve or throttle position sensor. @empty_lord do you have any feedback on this issue for OP?
    Edit-just re-read your post and realized you already replaced the TPS. Did you go OEM on this part?
  7. Aug 22, 2019 at 4:57 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    With issues like this it’s best to have a scan tool capable of graphing to watch what the sensors are doing, it can be a million things. These are known for the throttle issues. So It wouldn’t surprise me if there’s a issue with it finding idle
  8. Aug 22, 2019 at 7:29 PM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    Check for cracks in the intake and any vacuum hoses. Could be a slight vacuum leak.
    KarmaKannon, SC T100 and empty_lord like this.
  9. Aug 23, 2019 at 5:03 AM
    bmf4069
    bmf4069 Miller Lite aficionado
    Beau
    TX
    02 AC sr5 4wd v8
    If you replace the fuel filter, have someone else do it. I HATE that fuel filter.
    lsaami likes this.
  10. Aug 23, 2019 at 9:13 AM
    ocdan
    Unfortunately it was out of my budget to go oem(broke college student) the dealership want $180 so I ended up picking up one from autozone for $90
  11. Aug 23, 2019 at 9:16 AM
    ocdan
    Update changed fuel filter idle did fluctuate at start up but stayed relatively still in drive however was still low at 500rpm
    On the bright side my transmission shifted 100% better with very little to no slipping although this was only after initial test drive
  12. Aug 23, 2019 at 4:19 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Hello.
    I’m new to Tundra’s myself, but have had a T100 for about 15 years.
    I had intermittent idle issues on the T100 and it was due to a plugged idle air valve (as suggested above).
    I’m not very familiar with this engine yet, but with the T it could be removed and cleaned.
    I was able to improve it with Seafoam intake cleaner (different than regular Seafoam), you spray it in the intake with a long tube while the truck is running, and since it’s at idle while doing it, it has to go through the idle air valve.
  13. Aug 23, 2019 at 5:21 PM
    ocdan
    I haven’t been able to find any pics of the IAC valve and that is what my mechanic said might be the problem
  14. Aug 23, 2019 at 6:09 PM
    PenderBen
    2003 Tundra AC 4x4
    On the T it is under the intake, not particularly accessible.
  15. Aug 29, 2019 at 5:36 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I had to take out the battery in my 02 a few times and after I put it back in it took a lot of cranks for it to start up. At stop lights it would die unless I pushed the accelerator and no codes thrown. I found out that if I ran it with the A/C on at idle for about 5minutes everything went away:confused: Havent taken out the battery in a couple years and no issues. Might give it a try Good luck
  16. Aug 30, 2019 at 6:22 AM
    coyote
    coyote New Member
    Buy a vacuum tester at one of the parts places to make sure you’re holding a steady reading. If the needle bobs around or is inconsistent it can point to a leak & other issues ( the gauge will help diagnose more than just a vac leak ) they are cheap. Or borrow one from a buddy!!!
  17. Aug 31, 2019 at 9:33 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    When the AC on the truck will idle up to help with strain on the engine. Probably why yours won’t die at lights with the AC on.
  18. Aug 31, 2019 at 9:47 AM
    coyote
    coyote New Member
    Ive taken out the battery before on a tacoma and it took a few miles when reinstalled for the computer to recalibrate etc. — acted like it wanted to stall, low idle, but eventually after some bit of driving, went back to normal....
  19. Aug 31, 2019 at 5:07 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I forgot to mention I turned off the A/C after the 5 or so minutes you can even drive it around during that time. For some reason on my 02 it worked but it had all the same symptoms as the OP/ Ocdan
  20. Oct 1, 2019 at 4:59 PM
    ocdan
    Well I still haven’t been able to fix the idle and recently it finally threw 2 codes a p0171 and p0174 I looked it up and it could be a couple things most likely a vacuum leak or bad o2 sensors possible a issue with fuel system if anyone has some input on what to try first let me know!
  21. Oct 1, 2019 at 6:37 PM
    Aerindel
    Aerindel New Member
    Montana
    02 sensors. One of the most important sensors on the vehicle. (the ones before the cat, the ones after are just emissions BS)
    Charruabrew likes this.
