Iron Cross Patriot Install - Does this look right?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Plumpy33, Oct 6, 2020.
  1. Oct 6, 2020 at 10:23 AM
    Plumpy33
    Plumpy33 [OP] New Member
    Mark
    Central PA
    2020 White Double Cab Limited
    After much research, including looking at a lot of pics in this forum, I decided to replace my OEM plastic shell running boards with Iron Cross Patriots. I chose them because I liked the step width and the polished stainless steel finish, since I don't plan on dechroming my Limited DC. I really like them, but they stick out away from the truck more than I would like - about 3 inches out past the tires. Is this correct? They don't appear to stick out that far on any of the pics that I have seen. I have them adjusted in as far as possible until the bracket hits the lip on the bottom of the boards. Is this the way they all are or is there something wrong? Also, this is my first time inserting pics, so go easy on me if I screw it up.
  2. Oct 11, 2020 at 7:44 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    This is how mine looks just make sure you have your brackets in the right spots. Yours looks to stick out a little more than mine.
    I really like mine definitely helps on not getting any door dings. mines on a double cab though.74502D3E-3812-49AD-9B13-BC91A7C26ECC.jpg
  3. Oct 11, 2020 at 8:08 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Are they 6 “ wide? is there a possibility you have the brackets backwards.
    whst does the Iron Cross web site say, you might call tech support on Monday for a Q & A session.
    What did you take off of your DC?
    I’m looking for stock flat side steps to replace my tube ones. Not wide enough.
    Good luck with your new steps.
  4. Oct 11, 2020 at 8:19 PM
    Willard
    Willard New Member
    2024 F250
    I can tell from the picture showing the underside that you don’t have the iron cross brackets. Those are the brackets that runningboard warehouse ships, which are their own design and somewhat universal. They also cause the patriot boards to stick out an extra 1.5” or so.
    I know this because I had those. I sent pictures to iron cross and they explained it. I then bought the correct brackets directly from iron cross and now my boards are tucked in much closer.
  5. Oct 12, 2020 at 12:46 PM
    MICKs18yota
    Ohio
    2018 Tundra SR
    E811007A-4461-4652-83C4-7D4C7014288A.jpg 4E188BC5-B1D5-4515-8E23-7203C6958640.jpg FEED58AD-B7DA-444B-ADFA-2945C47DB760.jpg These are some photos of the brackets I actually got them directly from Iron Cross when I bought the steps like the other post said they don’t look like Iron Cross brackets.
  6. Oct 12, 2020 at 1:54 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Here’s mine, they look a little closer to the truck than yours but not much. I like these steps a lot.
  7. Oct 12, 2020 at 1:57 PM
    usmealgle
    usmealgle New Member
    orjan
    White 2017 Tundra Limited CrewMaxx
    these are mine which i'm about to replace, mine dont seem to stick out quite as far.
  8. Oct 12, 2020 at 2:27 PM
    Plumpy33
    Mark
    Central PA
    Thanks Willard and Mick. I ordered my boards from realtruck.com (the website is very similar to runningboard warehouse) so it appears that I received their brackets and not iron cross brackets. I really like the boards. They are very functional as a step and door ding protection, and the tread is very good, so I can live with the look not being exactly what I wanted. From some angles they almost look like wings, so the only concern that I have is that my Super White DC is so fast, I'm afraid that I might actually take off if I give it too much gas! Thanks again to everyone for taking the time to take pics and respond!
    Medicineman likes this.
  9. Oct 12, 2020 at 2:31 PM
    Plumpy33
    Mark
    Central PA
    I took these off. They are aluminum with a plastic shell. I didn't hate them, but my better half has an ankle problem, and I felt they were a little slippery, so I wanted something that offered more traction. Also, I kinda like the polished SS or chrome look better.
    Inquiringone[QUOTED] likes this.
  10. Oct 12, 2020 at 2:33 PM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    They look good. Dont worry about the take off from too much velocity. All the MGM folks know that Super White color decreases HP/Torque by a factor of 3. The truck will definitely stay grounded.:D
