Is a snorkel worth it?
Discussion in '1st Gen Tundras (2000-2006)' started by tyler-brown, Aug 22, 2021.
  1. Aug 22, 2021 at 7:33 AM
    tyler-brown
    tyler-brown [OP] New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    Doing some reading and some guys saying moving the intake up the pillar helps keep it out of the dust and not in the fender well, which makes sense for dust created by my own truck...even though I'm moving forward and the dust would be behind me...but on dirtroads with trucks in front of me it seems it would be in the dust ALOT more. And how does heavy rain & snow effect them? I don't plan on waterproofing my truck and siliconing everything or submerging it. I do like the idea of more cleaner fresher air (even though the engine will only use what it needs)
    And I'm also a nerd that thinks they look cool, ha.
    Besides aesthetics, if I don't plan on submerging my truck...is it worth it?
    Thanks
    Darkness and Metro14536 like this.
  2. Aug 22, 2021 at 7:54 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    How quick does your air filter get dirty and how often do you need to replace it?
    KK6PD likes this.
  3. Aug 22, 2021 at 9:15 AM
    tyler-brown
    Canada, B.C.
    Both answers are not often.
    It's typically a hunting & winter truck. So sees wetter/snowy climates. But that doesn't mean it doesn't go down dirt roads to get to the fishing lakes
    des2mtn likes this.
  4. Aug 22, 2021 at 9:19 AM
    Outbound
    Aaron
    Northern Alberta
    Honestly, I don't think so. I do a heavy amount of backwoods driving in northern BC and AB on dusty roads. I haven't had any issues. I just replace my air filter when I do my oil changes, they're so cheap. I'd only bother with a snorkel if I was doing deep water crossings.
  5. Aug 22, 2021 at 9:27 AM
    tyler-brown
    Canada, B.C.
    Fair point. Stock is tried & proven. I've never had an issue either, just. Wondering to my self.
    So. Purely aesthetics. So it only lowers it on the priority list. If it was a bit more practical/functional I could justify it to my self.
    Thanks
    Outbound[QUOTED] likes this.
  6. Aug 22, 2021 at 9:34 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Since you don't plan on submerging your vehicle, I wouldn't even bother unless you really want the cool look of it. Even then, the only snorkels that do anything are ones with cylindrical pre-filter style heads. It's common to get MAF sensor issues with the normal style heads, even after the computer learns it. In the end, any gains you get from the snorkel for your usage will be negligible, unless once again you just want it for looks (which by all means do it, I think they look rad haha)
    Cody06tundra and Jeff_1974 like this.
  7. Aug 22, 2021 at 9:39 AM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Outside of swimming with your truck they serve the same purpose as the hood scoops.
  8. Aug 22, 2021 at 9:53 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’m the opposite. I really need a snorkel but just can’t get over how stupid they look. Maybe one day when someone comes out with a low profile hidden stealth snorkel I’ll get one.
    FrenchToasty, 831Tun, KevinK and 8 others like this.
  9. Aug 22, 2021 at 10:11 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You could always run it to your wiper cowl. Search undercover snorkel. We have a first gen member that did this.
  10. Aug 22, 2021 at 11:52 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  11. Aug 22, 2021 at 1:37 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That's called the glovebox mod :D
    Darkness, joonbug[QUOTED] and Sirfive like this.
  12. Aug 22, 2021 at 1:43 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Mount a turbo to chop that dust into harmless powder.
  13. Aug 22, 2021 at 2:04 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Sirfive[QUOTED] likes this.
  14. Aug 22, 2021 at 4:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @KevinK did it on his 3rd gen. Good enough reason for me not to do it. :laugh:
  15. Aug 22, 2021 at 4:20 PM
    timsp8
    NY
    Looks like you're leaning against it now, but if you do and your truck is typically a winter truck make sure the intake is facing backwards or you’ll end up with an intake packed full of snow.
    NewImprovedRon likes this.
  16. Aug 24, 2021 at 3:26 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    https://www.instagram.com/p/BWDflkxhXBx/
  17. Aug 24, 2021 at 3:48 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  18. Aug 24, 2021 at 5:49 PM
  19. Aug 24, 2021 at 7:27 PM
    tyler-brown
    Canada, B.C.
    Truck is infact black...
    Maybe the people ahead of me...are actually coming towards me making dust I am going to drive into...?
    g6t9ed, Black Wolf, bmf4069 and 2 others like this.
  20. Aug 24, 2021 at 8:05 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You're just about to pass them most likely.
  21. Aug 24, 2021 at 8:11 PM
    tyler-brown
    Canada, B.C.
    Ha.
    Pass everything except a gas station.
  22. Aug 24, 2021 at 8:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    So I did a snorkel on my 5th gen 4runner(tjm) mainly for cooler intake reasons, which proved positive from scan gauge readings. But for some reason our stock setup shows almost the same differential as my 4runner with the snorky. So I don’t know if I would really have my money invested in that area at this time in my life.
  23. Aug 24, 2021 at 8:32 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I ran a snorkel for almost 15 years, including tens of thousands of km of fire roads in BC and Alberta.
    If you are truck 3 in a convoy on those fine dust roads north of Kamloops a snorkel really does help. We are talking the kind of dust that even inside the truck you taste it and it’s everywhere. Instead of cleaning the airbox every few hours it was just once a day or less. But, in my experience, it’s only really worth it for dust if you’re in a convoy.
    For water crossings, the airbox is only one piece of the system. There are so many other things that water can cause issues with. However, a snorkel is extra insurance if you have done all of those. I’ve crashed through ice on river crossings twice and had water suddenly up and over a windshield. The snorkel saved me those times.
    As far as engine temp it made no material difference in my experience. Only a few degrees.
    Snow in the winter? Yeah, experienced a bit of that too considering Canada and all. Turning the head on most ARB style heads defeats the engineering. It’s designed to keep rain and snow out and push water out the sides of the head. I have only ever had to turn the head around in one or two VERY heavy and wet storms. One where it was so wet and heavy it caked the entire head.
    With all that said, I don’t have a snorkel my Tundra as my needs have changed.
  24. Aug 24, 2021 at 8:34 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Awesome cacti!
  25. Aug 24, 2021 at 9:03 PM
    FrenchToasty
    Mo
    Bone stock
    You can appreciate this as a bro in law.
    My bro in law came home to his house after a magical Disneyland vacation, but were locked out of the house. He went around to the side yard thru a gate, all at night. And tripped and fell into a similar arrangement………
    Wtf is right!!!!!
    Haha after getting it to the house some how, they went to the ER, the doctor basically said we can put you under and cut you up, or your body will slowly work the thorns out of your knee caps………
    He choose the slow version.
    I also have heard a version of a drunkard at a work party getting stuck to a fishhook barrel cactus twice in the same night!!!
    Thirdly, momma bear LOVES to park super close to those and open her door into the cactus, I then find them when I’m washing the lower door panels in the paint!!!! Those pricks are no joke!!!
  26. Aug 24, 2021 at 9:14 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @FrenchToasty the house I grew up in had some cactus, similar to prickly pear but was a little different. It was so bastardly it would shed needles if the wind blew right and they would go over the fence and stick in you. It reminded me of getting itchy from fiberglass. You don't see it hit you but you feel it.
    FrenchToasty likes this.
  27. Aug 25, 2021 at 2:49 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    The snorkel thing ?? To do or not?
    You don't see to many? I'm not a fan. Keep it simple.
    Your truck, go for it.. Good luck.
  28. Aug 25, 2021 at 5:27 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was JUST about to say this. So funny that we both noticed this. I love plants in general but that one looks terrifying. My buddy lived in Santa Fe for a little while and would let their cat out to explore. She came home one night with cacti needles in her eye which they had to remove!
  29. Aug 25, 2021 at 5:34 AM
    FrenchToasty
    Mo
    Bone stock
    It’s funny both of you like it so much. Personally I’ve wanted to strap a chain to it and rip the whole bunch out, for the sole fact that she keeps parking to close and opening the door into them, I give the meanest glare if I’m in the car when she does it.
  30. Aug 25, 2021 at 5:41 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I don't see why yall keep such evil plants around. That's like a damn land mine in your yard.
    Darkness and FrenchToasty like this.
