is it bad to use wheel spacers?
Discussion in '2nd Gen Tundras (2007-2013)' started by 5ive7even, May 11, 2020.
  1. May 11, 2020 at 5:07 PM
    5ive7even
    5ive7even [OP] New Member
    Brett
    Nova Scotia
    silver 2007 regular cab long box sr5
    Leveled w/ Bilstein 5100, 1.5" spacers & rear airbags, factory alloys wrapped w/ 275/70r18 Goodyear Duratracs and a SS Magnaflow 12588
    was hoping for some opinions of a few people more knowledgable than I am on the subject
    I'm looking into buying a new set of rims and I was hoping to get the tires outside the wheel wells about an inch by doing so.. unfortunately fuel discontinued my first choice so I had to move down the list.. the second set Ive chosen come in a +1 or +20 offset, I was thinking I'd need roughly -25 to get the tires where I want them but its possible I just don't understand wheel offset as well as I think I do.
    I was wondering if buying the +1 offset wheels and using 1" wheel spacers is a reasonable solution or are they not really recommended? I feel like they might put extra stress on the front end components?
  2. May 11, 2020 at 5:37 PM
    Sunnier
    Sunny
    San Diego, CA
    Hmmn. I can’t help you with your offset calculations because I suck at it.
    But I can tell you, based on reading just about every thread on here over two years, that, while it’s “ideal” not to use spacers*, many of us do. I and others I know have done lots of cool antics (think air + landings) with spacers, with no problems. 1” spacers won’t wreck anything. But stick to top-quality spacers; I run BORA.
  3. May 11, 2020 at 6:33 PM
    This pic is from another member's truck. 275/70/18 Nitto Ridge Grapplers on Ray10 wheels that have a +25mm offset. Your +20mm wheels would be approximately 1/4" further out, a +1mm would be just shy of an inch further out than the pic, and if you did -25mm offset you would be almost 2 inches further out.
  4. May 11, 2020 at 6:42 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Love my spacers. Around 30,000 trouble free miles so far with heavy wheeling.
    Boerseun likes this.
  5. May 11, 2020 at 6:43 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The concern about putting extra stress on the front end components is somewhat true, but irrelevant. There is a little more stress because the wheel is further out so the moment force is bigger, but it is exactly the same as using a wheel with a similar offset. So, compared to stock, there is a slight increase in stress, but stock wheel with spacer and aftermarket wheel with more offset (negative offset actually) is exactly the same stress. So long story short, it does not help to buy wider wheels because you are concerned about wheel spacer stress. Lots of people use spacers just like lots have wheels with different offsets. I hardly ever hear any bad news regarding wheel bearings or other components breaking because of that.
  6. May 11, 2020 at 6:46 PM
    Tundyfundy
    Bay Area, CA
    Perfectly correct. With rims you don’t have to worry about the connection between the rim spacer and hub but as long as they are torqued per manufacturer it’s basically the same deal. No difference between spacers and offset wheels.
    Boerseun[QUOTED] and GODZILLA like this.
  7. May 11, 2020 at 6:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    With spacers, i would just make sure the wheels and the spacers are both hub centric
  8. May 11, 2020 at 6:59 PM
    138thBatista
    138thBatista New Member
    Tulsa
    2010 Seq. Limited
    Either BORA or Spydertrax, and make sure to use thread locker on the lug nuts holding on the spacer, but not your rims obviously!
    Hbjeff[QUOTED] and Boerseun like this.
  9. May 11, 2020 at 6:59 PM
    I have +1 offset and my tires are just a tad outside of my Bushwacker flares.
    5ive7even[OP] likes this.
  10. May 11, 2020 at 8:01 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Just for reference, here is -11
  11. May 11, 2020 at 11:11 PM
    Tundyfundy
    Bay Area, CA
    So some spacer companies will void the warranty if you use loctite. I would say just follow manufacturer specifications regardless of which spacers you get. Some say use and some say don’t. More importantly is make sure you torque and Re torque after manufacturer recommended intervals. The safety of wheel spacers depends on the install assuming your buying a quality product with quality materials. Also make sure you clean the surface of the hub to get a smooth mating surface. If it’s not smooth it can cause problems with alignment and a bad ride as well as damage to other components like brakes rotors, wheel studs, etc...
  12. May 12, 2020 at 9:10 AM
    I've run 1.25" spacers for 125,000 miles with no issues. No loctite, no bearing failures. Towed a 7500# camper regularly. These are hubcentric spacers. Not Bora. If you're gonna run a small spacer (1.5" or less) make sure that the factory lugs don't stick out past the spacer, or make sure the wheel has relief between the bolt holes for the lugs to clear. Otherwise you'll have to trim the factory studs down, not recommended.
    5ive7even[OP] and Tundyfundy like this.
  13. May 12, 2020 at 9:26 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    A hub centric wheel bolted to a hub centric wheel spacer has the same leverage on it as a hub centric wheel with 1.25inches less backspacing.
    the only difference is the addition seam, but if properly torqued, then rechecked that should not be an issue. It may be slightly weaker, but i doubt our loads can break it
    Tundyfundy and jeremyd like this.
  14. May 12, 2020 at 9:35 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The same people who complain about spacers being unsafe are the same ppl who roll through stop signs and break the speed limit.
  15. May 12, 2020 at 1:11 PM
    5ive7even
    Brett
    Nova Scotia
    I really like this explanation. Thanks to all who replied, I didn't realize that a +1 offset would get the wheels outside of the fenders. I guess I just assume that the +1 would be 1mm less offset than the stock aluminum rims I'm running now, so I figured to get an inch outside of the fenders I would need to have -25. So I guess the assumption I made in reality was that the stock alloy rims for the 2nd gen tundras were to be considered a 0 offset .. but obviously not... does this mean that the offset on factory rims is somewhere around +25?
  16. May 12, 2020 at 1:15 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    I have ran spacers on three vehicles I have owned and currently run them with a +50 offset TSS wheels on my 2017 Platinum. There is no difference between this and a aftermarket wheel offset. I have never seen a loss in life in regards to my hub bearings or joints or anything for that matter. I have always ran Spydertrax because they are very reliable but there is one con to them..... they are anodize blue :( I hate blue.
    With the math of these spacers and the +50 wheels I am sitting at +18 Offset
  17. May 12, 2020 at 5:35 PM
    Factory wheels are not +25. Closer to +50 or 60. The wheels I posted above (just poking out of the fenders) are +25.
  18. May 12, 2020 at 5:45 PM
    5ive7even
    Brett
    Nova Scotia
    thanks again, i got a straight answer from google this time and it said +60 on the 18" alloys. Must have worded it the wrong way last time. I apologize for my ignorance hahaha :D
    Boerseun and Black Wolf like this.
  19. May 12, 2020 at 5:51 PM
    No worries. I'm a noob on all this. My Tundra is the first vehicle I've ever wanted to change the wheels on, so we all start somewhere. Never apologize for asking a question you don't know the answer to.
  20. May 12, 2020 at 5:52 PM
    Factory TRD 18" are +60 offset
  21. May 12, 2020 at 6:00 PM
    Once you apply the "recommended" torque on spacers to the hub....they become "one". There is a misconception about this that isn't true. All about the direct force applied to the hub. The torgued force of the spacer to the hub doesn't weaken anything. There are mechanical engineers here that explain it better than me. We calibrate torque multipliers at our lab. In order to do that we have to attach our reference torgue standard to the Unit Under Test and depending on the torque load we apply recommended torque per our calibration procedure. "Equal force". Under torquing and over torquing spacers is when problems seem to occur.
  22. May 12, 2020 at 8:08 PM
    Inkoosikas
    Inkoosikas New Member
    Alex
    2007 Blue Tundra SR5 TRD 4WD DC
    None
    I would never do it again. I used wheel spacers once and my wheel came off...
  23. May 12, 2020 at 8:18 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    please be more specific. What came off? Broken studs? Oe wheels? Nuts came loose?
    Tundyfundy likes this.
  24. May 12, 2020 at 8:23 PM
    Inkoosikas
    Alex
    None
    It broke all the studs off one hub and the wheel basically came off while I was on a road trip in the middle of nowhere in a desert...
  25. May 12, 2020 at 8:27 PM
    138thBatista
    Tulsa
    2010 Seq. Limited
    Correct, Spydertrax actually includes loctite, but making sure they are still TQ'd properly after 500 miles and then making sure every rotate is key. You're doubling your points of failure and potentially putting things out of whack if you don't get it flush.
  26. May 12, 2020 at 8:34 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    I ran BORA 1.25" on my Tundra with the stock TRD OR wheels for a while—no issues at all. They were my first set of spacers, so I was hesitant as well, given what you can find when you google about them. But even loaded with camping gear/fire road driving for a whole summer they never seemed to cause any issues.
    Tundra805 likes this.
  27. May 12, 2020 at 8:46 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Maybe its just me, but i would rather buy a rim/tire combo with the proper offset to get the look i want, rather than worry about something coming loose or breaking off. But then again, i might be old school because i like the biggest tires i can get that don't stick out past the fender. ;)
    FREEK and GODZILLA like this.
  28. May 13, 2020 at 9:15 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    The big thing with a Toyota truck is they LOVE hubcentric wheels. I always tell people toyota vehicles are very sensitive to things when it comes to shakes and vibrations alot of times its the wheels or tires being the causer. Having a lug centric wheel sends you in that direction of having those issues. Dont get me wrong I ran Methods for years and loved them. But alot aftermarket wheel companies claim their wheels are hubcentric but they are not the bore is just very close. I love having a aftermarket offset with a hubcentric fit wheel plus I love the TSS wheels. That is where the spacers are a win win for me. I had my Methods come loose on me many of times and found myself re torquing them. I would say on any truck you have to worry about anything coming loose but I do get its one less thing to worry about.
    Hbjeff likes this.
  29. May 13, 2020 at 9:17 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    That sounds like the spacer was not torqued down came loose and sheared all the lugs.
    Hbjeff likes this.
  30. May 13, 2020 at 9:33 AM
    Klowry97
    Klowry97 New Member
    iowa
    2018 Tundra Limited TRD offroad 4x4 Cement
    Method Race Wheels MR305 NV 18x9 +25 offset WRAPPED in Hankook Dynapro AT2 RF11 275/65 R18
    Check these 2 sites out. they helped me out tremendously. i eventually went with a +25 offset. they stick out roughly 1 1/2"...you can check out my pics in my profile
    5ive7even[QUOTED][OP] likes this.
