Is more rear end "bounce" to be expected after lift?
Discussion in 'Suspension' started by jonclark96, Nov 9, 2021.
  1. Nov 9, 2021 at 4:06 AM
    jonclark96
    jonclark96 [OP] Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I'll start off by saying that while I have always liked the look of a lifted truck, I've never actually owned or driven one before. Several weeks ago, my friend and I installed my lift kit and I got new tires installed shortly thereafter. I've also not done much of any suspension work myself on my own vehicles, so I have some paranoia that I did something incorrectly.
    I am experiencing what I would call more "bounce" from the rear of the truck when I go over small to moderate bumps while driving. Think of how a diving board at the pool resonates after you jump off of it - that's how I think it feels going over a small bump. I feel the bump and then some more bounce as I move forward. Is this normal or could I have done something not quite correctly? When I got new tires put on, I had the mechanic take a look at the installed lift and he said it all looked good (with the exception of questioning the differential drop).
    Details of the lift:
    Toytec/Eibach Stage 1 front coilovers (gave about 2.75" of front lift)
    Eibach Pro Sport rear shocks (reused all factory hardware & bushings)
    Toytec adjustable rear shackle set at 1.5" of lift (used new shackle hardware but did not remove the factory bushing in the leaf spring)
    Tires are 275/70 R 18 Cooper Discover Rugged Treks set at 35 PSI
  2. Nov 9, 2021 at 4:11 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Between the new E load tires and the shackle lift, I’d expect that
    Oey12 and jonclark96[OP] like this.
  3. Nov 9, 2021 at 4:18 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Congrats on lift, any pics?
    I have the complete Toytec Aluma series complete lift kit with no issues... I recently added both Trd Sway bars and makes a Yuuuge difference, especially the get on/off ramps.. A must do mod... Good luck.
    jonclark96[OP] likes this.
  4. Nov 9, 2021 at 4:38 AM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    I also have the rear sway bar installed.
    Here's a pic after the lift was installed:
  5. Nov 9, 2021 at 4:46 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    She’s a ‘beaut!
    And as @ninjajay said above, I’d expect a bounce from those new harder-riding tires and the lift shackles as well.
  6. Nov 9, 2021 at 4:56 AM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Thanks guys! It is reassuring that I didn't completely foul up my relatively brand new truck!
    Oey12 likes this.
  7. Nov 9, 2021 at 5:47 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    And just to add the rear sway bar…
    I definitely got a slight more bounce after but only on the rougher roads.
    But exactly what he said^^
  8. Nov 9, 2021 at 6:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Did you torque the shackles with truck on ground/under weight or while in the air? Should be on the ground, tightening them in the air will cause the bushings to bind and give a rougher ride.
  9. Nov 9, 2021 at 7:02 AM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    I am trying to remember, but I think i torqued them in the air. Is it as easy and loosening and re-torqueing them on the ground now?
  10. Nov 9, 2021 at 7:52 AM
    frichco228
    Think that would be fine
  11. Nov 9, 2021 at 2:07 PM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    Factory bushing in the leaf spring could be an issue too. Might want to replace those with poly bushings for a smoother ride.
