Is my cv axle broken? I need education
Discussion in 'General Sequoia Discussion' started by Sequoia01Green, May 12, 2024.
  1. May 12, 2024 at 3:32 PM
    Sequoia01Green
    Sequoia01Green [OP] New Member
    Travis
    01 Sequoia SR5
    In the process
    This is my first time modifying and upgrading my 01 sequoia. I did not know to strap the spindle up before taking the lower and upper ball joints off. Didn’t know how heavy it really was so bungies weren’t enough. Is it supposed to lean forward like this? Is this normal articulation for the cv axle? Also this a a before photo, I now have it ratchet strapped instead of just bungies. IMG_2437.jpg
  2. May 12, 2024 at 5:54 PM
    Thwagr
    Thwagr New Member
    2021 SR5 Trail
    I am not a mechanic, but if you firmly grab the steering knuckle and pull it out away from the drive shaft does it move in and out or clunk around? Just don’t rip your boot. I am going to guess it’s “fine” because it would have probably flopped off and torn the boot already with that bungee cord setup if it wasn’t connected.
  3. May 15, 2024 at 12:36 PM
    Sequoia01Green
    Travis
    01 Sequoia SR5
    In the process
    Thank you, it does not move or clunk I can just set it back in its original position and the axle spins all the way to the diff. That is as far as it goes.
    Thwagr[QUOTED] likes this.
  4. May 24, 2024 at 10:41 PM
    ScorchedTaco
    ScorchedTaco New Member
    Az
    2012 sequoia 2012 tacoma
    you are probably ok those half shafts are pretty tough…. They can take a massive beating with a BFH to get them off to replace a torn boot and do just fine on reinstall….
