Is OME lift the best bang for the buck?
Discussion in 'Suspension' started by Jmccracken1214, Jan 3, 2023.
  1. Jan 3, 2023 at 3:00 PM
    Jmccracken1214
    Jmccracken1214 [OP] New Member
    2015 Tundra CM
    Try and keep this short and to the point.
    When i got my 2015 tundra this year, it had a OME 3.5" lift on it, and had been on there since new. Im guessing the previous owner wheeled and towed, it had a trailer brake controller installed also. The suspension was worn out, so I spent $2500 on a ironman complete lift... What a mistake.
    First, drivers side UCA is bad, squeeks like crazy, they replace it.... That was the end of my help from this company.
    Anothert squeek pops up in the front... the bottom of the shock is rubbing the little housing it sits in on the truck. I have to spray lube on it every month to keep it was driving me crazy. I email them pics, and videos... I get a reply "Hard to tell what it is or where its coming from".... All replies from them stop.
    Rear Leaf springs squeek on both sides, I can spray them down with lube, it goes away for a while... I reach back out to them, no reply... I call, get someone, "theyll be in touch".
    Worthless company, in my experience.
    Now, with the market it like it is, its cheaper for me to just replace this suspension and keep the truck than it is to trade it in on a $65,000 new one.
    Not looking to drop $5000, just want a good 3" lift to keep the look I have the same.
    EvoTundra likes this.
  2. Jan 3, 2023 at 8:24 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Get yourself good coilovers and deaver leaf pack as well as an upper control arm. Bilstein setup might be a good option for you
  3. Jan 3, 2023 at 8:50 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I have the OME kit and don’t have any issues. My buddy got the Ironman on his 2018 tundra and has issues with squeaking and not leveled in the front. He’s not happy about it.
    Ironman hasn’t reached back to him after a few months. Company is shit.
    IsaiahCanada and reywcms like this.
  4. Jan 3, 2023 at 10:27 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I'm curious about "the bottom of the shock is rubbing the little housing it sits in on the truck", where is that exactly? Never heard of that, and mine don't do it. Love my shocks... even though I had to reload the springs to keep them from rubbing on the shock body. If that is happening to yours, then that would squeak.
    Spring pack squeaks are not unusual. I've definitely heard that about OME and Deaver. Jack up the truck so the spring hangs down, pressure wash and lube between the leafs. Check the torque on your ubolts too.
  5. Jan 4, 2023 at 4:20 AM
    Jmccracken1214
    2015 Tundra CM
    Atleast it isn’t just me they ignore.
    I’m wondering if I could replace just the Leafs and leave the Ironman shocks on.
    i worry because the Ironman kit is for a 3.5” lift and the leafs that come with the OME say 2.5” lift.
  6. Jan 4, 2023 at 4:22 AM
    Jmccracken1214
    2015 Tundra CM
    I’m put rubber pads in from spring thing and that helped some. If I lay under the truck and push up on the spare tire, I can hear it up near the top rear bushing. I’ve greased them, checked and double checked torque.
    It’s annoying hearing the noise anytime I’m on any sort of uneven ground
  7. Jan 4, 2023 at 4:51 AM
    CaptRussia253
    Ruslan
    I would keep the Ironman leafs and try a spring insert to attempt a fix for the squeak. Replace the front shock/coil with OME and use the 614 coil. I got over 3” of lift with the stock bumper.
  8. Jan 4, 2023 at 5:41 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I've had an OME 3" lift since 2015.
    It has been absolutely trouble free.
    My only complaint is that the ride is very stiff...it rides like a truck.
    You're probably not going to be able to go down washboard roads at 50 mph, but this will get you down any four-wheel drive only road to your favorite campsite with no problem.
    Yes, I think it is one of the most trouble free, most bang for the buck systems available.
    CaptRussia253 likes this.
  9. Jan 4, 2023 at 6:24 AM
    Jmccracken1214
    2015 Tundra CM
    The ome lift on here was a lot stiffer than this Ironman lift. But it had factory springs and shackles. The springs were curved the opposite way lol. I may just order the entire OME kit sometime soon and swap it all out, AGAIN. What a pain in the ass.
    $2500 down the drain with this lift kit.
  10. Jan 4, 2023 at 6:45 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    We sell and capture feedback on a lot of different suspension components, and my .02 is that unless you enjoy the ride comfort of an Oregon Trail style covered wagon I would steer you away from OME. They're simply just not very compliant when it comes to ride quality. Will they last forever and a day + provide the lift that you ask of them? Yes. Will they hold up if you load the truck down? Yes. That's about it though!
    I ran an OME suspension on my 05' Tacoma back in the day, and knowing what I know now with the budget I had I would have been much better off with something like a Bilstein 5100 setup. Unless you're running a good amount of static weight I generally encourage folks to look elsewhere.
    Okay - Moving on to solving your issues. I understand that you want 3" of lift up front. Do you also want 3" of lift in the rear? That would maintain your stock rake values. Stock rake varies by truck slightly, but generally comes in around 1.5-2". The way that the roofline and sits on the 07-21 Tundra gives an illusion that the truck is lower in the rear than it actually is. I generally recommend maintaining about 1" of rear rake as a leveled truck looks low in the back.
    We may be able to keep those leaf packs that you have though. You are thinking that the noise is coming from the bushings, and not from between the leafs, correct?
    My gut is telling me to get you into something like a Bilstein 6112/5160 setup should the budget allow for it, and we can look at your Ironman components piece-by-piece to see what we can or can't salvage...
  11. Jan 4, 2023 at 6:47 AM
    Jmccracken1214
    2015 Tundra CM
    Do you have a business that sells this stuff? If so, I’d love to chat over the phone to figure it out
  12. Jan 4, 2023 at 6:49 AM
    memario1214
    Colton
    Missoula, MT
    Sure do. We're Hotshot Offroad :wave:
    www.hotshotoffroad.com
    You'll want to talk with me directly since I'm our Toyota guy and I'll be tied up today until about 1015 MST. Feel free to call me at 406-936-0206 anytime after that :thumbsup:
    - Colton
  13. Jan 4, 2023 at 8:38 AM
    rruff
    rruff New Member
    The rear shocks will work with any springs with a modest lift. But... fix the squeak in the ones you have, OME are not going to be any better. Besides ubolts being loose, another cause of squeaks can be the bushing bolts too tight. I'm guessing you have the greasable bushings? Did you install this yourself or pay someone... and if you paid someone, who was it?
    And like I said, check the spring-shock body clearance on the front. That is the most common issue and it can be fixed by resetting the coils to maximize clearance. That's not fun because you need to remove the shocks, but...
    That would be a wasteful downgrade. I absolutely love the performance of the Ironman FCPs. I think their full kit is a joke though, and I wouldn't recommend any front shock-lift over 2.5". And if you are doing that, you don't need UCAs or a rear lift, so...
  14. Jan 4, 2023 at 7:02 PM
    CaptRussia253
    Ruslan
    To each their own. Like I said my buddy has a lot of issues with his Ironman lift and I have zero with my OME. They may not be the best option but man are they reliable.
    reywcms likes this.
  15. Jan 4, 2023 at 7:20 PM
    rruff
    rruff New Member
    A huge factor in this case is that the OP already has Ironman... and the issues he is having are squeaks which are not yet identified, but probably not hard to remedy.
    There is a huge IM thread on here somewhere, and the only issue of note that I recall was the "springs rubbing on the shock body"... a common and serious problem but fixable.
  16. Jan 11, 2023 at 2:32 PM
    Jmccracken1214
    2015 Tundra CM
    My coil over springs are not touching the body.
    I installed the spring thing rubber pads between the leafs and made no difference. Just sprayed everything with dry lube, no difference.
    here’s a video of me just rolling the rear tire forward.
    https://youtube.com/shorts/ZRu_U9szD4A?feature=share
  17. Jan 12, 2023 at 7:08 AM
    Jmccracken1214
    2015 Tundra CM
    I sent Ironman another email after removing the springs, reinstalling and still no fix to this noise! Asking them to please honor their warranty and refund me for this springs as I will be going with a different brand.
    I’m looking at the OME leafs, they say 2.5”, will I be unlevel if I go with these and keep the rest of the Ironman lift
  18. Jan 12, 2023 at 10:30 AM
    rruff
    rruff New Member
    You might want to do a search to see how many people with Deaver, Alcan, OME, etc report squeaking. You might even learn how to fix it. Replacing springs will not solve the problem if they are installed and used in the same manner. The IM poly bushings and shackles have grease fittings which is definitely a benefit.
  19. Jan 12, 2023 at 11:11 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    The other option you can do and if I'm not mistaken is rebuild the OME shocks. I had the Bilsteins 5100's on my truck since my truck was new. Regreted putting them on, truck rode like a brick. No matterr how I adjusted the heights of the shock or adjusting tire pressures, it did not do anything to make it a more comforting ride. I use my truck as daily, on road and off road and as well some towing. I ended up in the late last year replacing them with OME BP51's. I've been in heaven, I don't get those jarring bumps, truck rides smooth as hell. Just another option for you to consider.
    AggiePhil likes this.
  20. Jan 12, 2023 at 1:05 PM
    Jmccracken1214
    2015 Tundra CM
    I’m not sure what else to do. Everything is greased and torqued to spec. I don’t wheel this truck, it doesn’t see much other than gravel roads from time to time
    rruff[QUOTED] likes this.
  21. Jan 12, 2023 at 3:12 PM
    Jmccracken1214
    2015 Tundra CM
    Here's a small update.
    I get home tonight, going to grease the bushings again... 1 zerk wont take grease... weird.. Ill replace it tomorrow.
    I come in and hop online to see if I can find the thread pitch for this zerk on IM website... i find the instructions.....
    Now....... When I put this crap on, I went by THEIR install video, in which I just triple checked.. The dude says to torque the nuts on the zerk side to 35ft lbs... THATS IT... nothing else. I dont recall all my actions at the time of install.
    I bring up their instructions, it says to torque it to 85 ft lbs... and the inside nuts to 95 ft lbs... He mentions none of this on the video. So Ill replace the grease fitting tomorrow and drop the spare tire and double check this. I swear, if Ive been riding around for 6 months wanting to crash this noisey ass truck into every tree I pass because of this, Im going to be pissed.... and happy.
    rruff likes this.
  22. Jan 19, 2023 at 4:48 PM
    Jmccracken1214
    2015 Tundra CM
    That didnt fix my issue. I got a hold of them again, and talked to them for a while and sent them videos of each side. THey could see where I have rubber pads between the leafs, and greased them and they still made noise...
    To start off, they were going to warranty the drivers side, because "it sounds louder than the passenger"...... WtF? lol... nah.
    Talked some more, and got a tracking number today for my new set of leafs. From the picture on their site, they seem to have added more spring clamps through out the pack compared to the ones I have.
  23. Jan 19, 2023 at 6:32 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    My lift kit is perfect for what I want it for. I am not using my truck as a rock crawler so I don't need a crazy aggressive lift or amazing shocks. The OME lift is sufficient for the average driver.
    xodius likes this.
