Is the 4.7L an iron block? Coolant dirty.
Discussion in '1st Gen Tundras (2000-2006)' started by atikovi, Sep 2, 2021.
  1. Sep 2, 2021 at 9:17 AM
    atikovi
    atikovi [OP] New Member
    Suburban Washington DC
    Drained the radiator prior to a timing belt service on my Sequoia. I assume this is an iron block? Coolant is a bit rusty.
  2. Sep 2, 2021 at 9:17 AM
    Yes it is
  3. Sep 2, 2021 at 9:19 AM
    atikovi
    So that coolant pretty normal if neglected?
  4. Sep 2, 2021 at 9:28 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think part of the issue is that it's the wrong coolant. The coolant needed for the 4.7L is pink, not orange. Most of us use Zerex Asian blend.
  5. Sep 2, 2021 at 9:40 AM
    atikovi
    Umm, that's not orange. That's brown.
    NWPirate likes this.
  6. Sep 2, 2021 at 9:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Perhaps I'm color blind. Looks orangish brown from here. I'm not denying it might be rusty too. A good coolant flush is in your future. If you didn't already know, there are two drains on each side of the block for draining the coolant.
    Sunnier likes this.
  7. Sep 2, 2021 at 9:53 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looks like its contaminated, maybe with oil. Flush it, refill it with the right coolant, check again in a few hundred miles.
  8. Sep 2, 2021 at 9:54 AM
    atikovi
    I didn't, just got it. What are the chances they would even budge on an 18 year old iron block?
    Jack McCarthy likes this.
  9. Sep 2, 2021 at 10:05 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Drains are brass. They always worked on my old Tundra. Make easy work of changing the coolant since you can add a hose to the drain and not make a mess.
    FrenchToasty likes this.
  10. Sep 2, 2021 at 10:05 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I think this coolant started its life as pink Toyota or Asian coolant, but now, 10+ years later it is a soup broth of coolant and rust. If it were mine I'd drain, fill with distilled water, drive, drain, and repeat again. I would also try to reach the block drains and open those to try and get the rust flakes out of the system. Final fill with super long life and move on the the next project.
    NewImprovedRon and Darkness like this.
  11. Sep 2, 2021 at 10:07 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Super Long Life coolant (pink) for the late 2003 and newer. Standard Toyota Red coolant for earlier. Toyota did not back spec the newer pink coolant for applications that originally called for the red.
  12. Sep 2, 2021 at 10:10 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
  13. Sep 2, 2021 at 10:28 AM
    atikovi
    OK I'll try to find the drain plugs.
  14. Sep 2, 2021 at 10:46 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Here is what the passenger side looks like.
  15. Sep 2, 2021 at 11:32 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    My coolant is red, but I'm using the older toyota coolant you mix with distilled water. Now they add the water and charge you twice as much for the pink stuff.
    I made the mistake of trying to drain mine via on of the brass cocks on the block and broke one off. The dealer tells me they never touch them.
  16. Sep 2, 2021 at 2:37 PM
    Just dawned on me that this is the vehicle that you're working on the timing belt with the radiator still in place. Knowing that the coolant looks like that, I would replace the radiator as part of my cooling system refresh and restore. It'll make the Timing belt job so much easier and I would be leery of the radiator that's on there with that much rust in the system.
  17. Sep 2, 2021 at 5:33 PM
    atikovi
    I'm not doing a concurs restoration, just maintenance. Will flush the system good and call it a day. I'm selling the truck and if the buyer wants to replace a radiator that isn't leaking or overheating, that's on him.
  18. Sep 2, 2021 at 6:14 PM
    Ah, got it. Makes more sense now.
    DaWhiteTundra likes this.
  19. Sep 2, 2021 at 7:45 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Is it possible they have been filling it with regular water vs coolant or distilled water. How did the thermostat look, can you add some photos?
  20. Sep 2, 2021 at 7:53 PM
    atikovi
    Didn't take the thermostat out but will see after I get the water pump off.
    jerryallday likes this.
  21. Sep 3, 2021 at 5:58 AM
    If they put straight water in it, not coolant, yeah.
  22. Sep 3, 2021 at 6:05 AM
    Looks like GA clay slurry to me, so I'm going with you're both right. You just lack the snark.
    DING DING DING DING DING
  23. Sep 3, 2021 at 6:13 AM
    outlaw.taco
    outlaw.taco New Member
    Houston
    If you have access to an air compressor, use a vacuum refill system
  24. Sep 3, 2021 at 7:00 AM
    atikovi
    Yes, I have both.
  25. Sep 4, 2021 at 6:37 AM
    atikovi
    What new coolant to use? I flushed out the block and radiator until water runs clear. I understand it was around 2003 was about when Toyota went from red to pink. Any reason not to use the longer life pink?
  26. Sep 4, 2021 at 7:28 AM
  27. Sep 4, 2021 at 8:16 AM
    atikovi
    The Toyota pink only comes 50/50, so if there is water left in the block from flushing, the freeze protection won't be close to -34F. Who makes a full strength pink?
  28. Sep 4, 2021 at 9:07 AM
    Jack McCarthy
    Bill
    North of Boston
    It wouldn't be pink, it would be toyota red and they stopped making that a few years back. I did manage to buy 8 gallons of it for $10 each from a Toyota dealership in Keene, NH on a closeout sale.
  29. Sep 4, 2021 at 9:20 AM
    atikovi
    So what do the Toyota dealers up there use? It's gets below -34F in some places.
  30. Sep 4, 2021 at 9:33 AM
    Jack McCarthy
    Bill
    North of Boston
    I would assume the Toyota pink. Now you just have to buy twice as much as the red.
