Is there a truck bed cover that’d work with custom size space?
Discussion in '3rd Gen Tundras (2022+)' started by La1dbackdude, Dec 8, 2023.
  1. Dec 8, 2023 at 10:04 AM
    La1dbackdude
    La1dbackdude [OP] New Member
    2024 Tundra 1794
    I have a 6.5’ bed but with my tool box on top I now only has 56”
    My question is is there a bed truck cover that can accommodate custom size? I was thinking attach a retractable cover kit onto the tool box? Would that work? I was worry that I won’t be able to trim the track to the size I want.
    There is tool box that have the retractable kit built in but it’s like $3700. :(
  2. Dec 8, 2023 at 10:09 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  3. Dec 8, 2023 at 11:14 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Just thinking out loud here. My Bakflip MX4 cover for my 5'5" bed measures roughly 56" without the forward most half-panel. If you could remove that panel, it would almost be the perfect length for your truck. I have no idea what's involved in separating the panels, but I suspect it could be done. You would have to cut the cover rails and re-located the mounting hardware, but I also think that would be doable. Getting a water-tight seal along your tool box might be a bit tricky, however.
  4. Dec 8, 2023 at 11:43 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    On my '13 and '18 tundras I shortened the last panel of a soft trifold cover, worked great but won't fold up all the way. If I needed the open bed it came of in a minute or two.
  5. Dec 9, 2023 at 1:38 PM
    La1dbackdude
    2024 Tundra 1794
    Is there absolutely no retractable cover kit that’d allow you to trim the track to a certain length? The roll up access seemed cheaply made and probably not worth $600.
