Is there a TSB for the wind noise?
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Jul 6, 2024.
  1. Jul 6, 2024 at 1:54 PM
    SDHNTR
    SDHNTR [OP] New Member
    Dealer is fighting me on this. I get bad wind noise at highway speeds. You can push on the door/window while driving and hear it go whishy whoosh and change tone as you push. I explained to them it’s a widespread problem on new tundras. Dealer says “first I’ve heard of it” and say they can’t replicate the wind noise. I checked the trips and they drove it for less than 1/2 mile on freeway. Of course they didn’t replicate it. Arrggh!
    I’ve come to realize that unless there is a formal recall or TSB for a particular problem, the dealer doesn’t do a damn thing. So is there a TSB for the wind noise issue I can refer them to?
  2. Jul 6, 2024 at 2:53 PM
    Breathing Borla
    Northern Illinois
    There is no tsb I’m aware of
    mine is silent but that doesn’t help you any
    ask for a mechanic to ride along with you and take him out under conditions you know you can replicate
    that’s what I’ve done with some of the deals on my past tundras when I get the “can’t replicate “
    il like here dude , I’ll show you
    Kap1 likes this.
  3. Jul 6, 2024 at 3:06 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  4. Jul 6, 2024 at 3:08 PM
    SDHNTR
  5. Jul 6, 2024 at 3:35 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Here you go, once you'll be done with this thread, consider yourself a wind noise expert.
    https://www.tundras.com/threads/wind-noise-concern.98646/
    Various trucks get wind noise because of different issues, but more common seemed to be rubber window in runner that needed to be replaced. Had mine replaced 3 times and it helped 90%
    Tunrod and Tundrastruck91 like this.
  6. Jul 6, 2024 at 5:12 PM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    The crap part about dealership service departments is that they are hit and miss. I can visit my “regular” service advisor and get stuff addressed under warranty based on what I tell them is going on. I hear in the forums that some dealerships will fight you tooth and nail over clear warranty items or TSB concerns.
  7. Jul 6, 2024 at 5:49 PM
    TundraFl83
    TundraFl83 New Member
    I don’t mind it . It’s only at 70mph
  8. Jul 6, 2024 at 10:29 PM
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    My dealership half-assed replaced it, which made it 10 times worse, and scratched the door in the process. Most likely they used a screwdriver instead of a plastic trim tool. They repainted that part of the door and put in a 3rd seal, but it still didn't fix it. I plan on adding my own weather stripping to it. I have already adjusted the door as far inwards as it will go.
  9. Jul 7, 2024 at 1:37 PM
    SDHNTR
    Wow. Sorry to hear that.
    So it sounds Toyota is still in denial over this issue and there is no TSB.
    has anyone discovered an aftermarket fix or hack?
  10. Mar 5, 2025 at 12:29 PM
    Lorris910
    Lorris910 New Member
    2022 BlackTunda 1974 Edition
    Maybe a little late to the party, but Toyota has released a TSB for the wind noise. It was issued on February 7, 2025. T-SB-0020-25
    BoomBoomGanoom likes this.
  11. Mar 5, 2025 at 12:42 PM
    SDHNTR
    Thanks, that’s helpful. is there somewhere we can go to read the actual bulletin to see what it is they do?
  12. Mar 5, 2025 at 12:51 PM
    Lorris910
  13. Mar 6, 2025 at 8:07 AM
    sudobash
    sudobash New Member
    Great way to get sent a Cease & Desist from Toyota for posting copyrighted material.
  14. Mar 6, 2025 at 8:10 AM
    Breathing Borla
    Northern Illinois
    lol, first hand knowledge there folks....:burp::fistbump:
    PermaFrostTRD and sudobash like this.
  15. Mar 6, 2025 at 8:11 AM
    sudobash
    sudobash New Member
    Knowledge shared by y'all of what happened to someone. Never received a Cease & Desist here.
  16. Mar 6, 2025 at 8:17 AM
    Breathing Borla
    Northern Illinois
    Oh boy, ok.:rofl:
    sudobash[QUOTED] likes this.
  17. Mar 6, 2025 at 8:19 AM
    sudobash
    sudobash New Member
    Yup.
  18. Mar 6, 2025 at 8:25 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My memory isn't what it used to be, but I thought they passed a federal law several years ago to make TSBs available to the public.
    If that's correct, how can Toyota legally threaten someone for posting them here?
  19. Mar 6, 2025 at 8:28 AM
    sudobash
    sudobash New Member
    They do get put on NHTSA after a certain amount of time. Toyota can take a while on some. Anything recall related is typically up on NHTSA within 7-10 days.
    And according to those familiar with the matter, a certain someone was sent a Cease & Desist for reposting screenshots of the TSBs here.
  20. Mar 6, 2025 at 8:46 AM
    Matt2015Tundra
    2023 1794 CrewMax
    So, I did a little digging and found the federal law here:
    https://www.federalregister.gov/doc...e-on-submission-and-treatment-of-manufacturer
    Unless the law has changed, it appears Toyota is required to submit TSBs to NHTSA with-in 5 days of sending them to the dealers. I'm no lawyer, but I'd argue that Toyota has no legal grounds to threaten someone for posting TSBs after that 5 day period. Here's a quote from the link above.
    "Many communications about a defect or noncompliance are communications manufacturers make to their dealers, owners, or purchasers about recalls. Some examples of these communications are letters to dealers and vehicle owners informing them about a recall and service bulletins (also known as technical service bulletins or TSBs) that provide repair instructions for trained technicians performing the recall remedy. NHTSA requires manufacturers to submit a representative copy to NHTSA of recall communications “not later than 5 days after they are initially sent to manufacturers, distributors, dealers, or purchasers.” 49 CFR 573.6(c)(10). This applies to “all notices, bulletins, and other communications that relate directly to the defect or noncompliance [that is the subject of a recall] and are sent to more than one manufacturer, distributor, dealer or purchaser.” Id.
  21. Mar 6, 2025 at 9:41 AM
    sudobash
    sudobash New Member
    Well would you looky there. It would seem. Nevermind.
  22. Mar 6, 2025 at 11:23 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Recalls and TSBs may fall under this.
    However, I recall seeing all sorts of everything posted by our friend here, including schematics and other non TSB material. Probably lots of material not necessary designed for regular people
  23. Mar 6, 2025 at 1:42 PM
    Matt2015Tundra
    2023 1794 CrewMax
    That's why my posts specifically mentioned TSBs, since that's what was being discussed.
  24. Mar 6, 2025 at 3:06 PM
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    not that I've seen on the TSB for noise..... but it's sad my 23' Tundra is noisier then my old 97 FJ80 on 35's...... I see some dynamatt and acoustic dampening in my future.... and the hood flutter is a thing... hadn't realized how thin the metal was until I had wind on the nose and coming thru the gaping grille and flexing the hood....
  25. Mar 6, 2025 at 4:38 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Agreed. The hood flutter is very disturbing. It amazes me that modern auto engineers would design a truck with the aerodynamics of a 2-1/2 ton brick.
  26. Mar 6, 2025 at 4:42 PM
    Breathing Borla
    Northern Illinois
    how bad is yours? I’m curious , anyway to take a video without wrapping it around a pole?
    mine just doesn’t do much of that that I’ve noticed, I’ll try to pay more attention next time, what speed do we need to rip it at?
  27. Mar 6, 2025 at 6:25 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Have you experienced 50 mph headwinds at highway speeds? The hood flutter is ridiculously distracting to me.
  28. Mar 6, 2025 at 7:51 PM
    Breathing Borla
    Northern Illinois
    I’ll try and take note next time in those conditions and report back
  29. Mar 7, 2025 at 1:53 AM
    SnowToy
    SnowToy New Member
    Going thru a Valley in NC with wind on the nose I had gusts to 60 maybe and I pulled over to make sure the hood was in fact latched as it was flexing that much...and wasn't really impressed with the safety latch thickness and mounting... On my 200 series I had hood vents to let hot air out- almost wondering if that would help ...
