Is there some sort of way to force ev mode??
Discussion in '3rd Gen Tundras (2022+)' started by kregstrong, Sep 15, 2022.
  1. Sep 15, 2022 at 9:39 AM
    kregstrong
    kregstrong [OP] New Member
    I know there isn't a way to do it from the factory but is there an aftermarket option?
  2. Sep 15, 2022 at 11:40 AM
    breynolds
    breynolds New Member
    Future Tundra owner
    Doubt it, batteries and re-gen system aren't sufficient enough to do so. Or if you could, you wouldn't be able to go very far.
    Mattedfred likes this.
  3. Sep 15, 2022 at 12:09 PM
    nodak67
    nodak67 New Member
    JR
    technically the tundra doesnt have any sort of ev mode so to speak.
    all the batteries are for is to supplement the gas engine as a temp short duration boost (duration is probably shorter than 5-10 mins tops)
  4. Sep 15, 2022 at 12:18 PM
    breynolds
    Future Tundra owner
    There are times when it runs on EV only though like through parking lots or putting around neighborhoods (if the battery level is high enough) so I get the idea that you may be able to bypass something and only have it run on EV but you're asking to get stranded somewhere haha.
  5. Sep 15, 2022 at 12:19 PM
    nodak67
    nodak67 New Member
    JR
    yeah i know about parking mode <18mph, but it wont last very long, still only about 5 mins on avg maybe 10 mins.
    the battery pack is really small in the hybrid, 1.87 kwh
    the prius is hella bigger at 8.8 kwh which will give it about 25 miles of ev only range
  6. Sep 15, 2022 at 4:52 PM
    xc_tc
    xc_tc New Member
    You could drive for a mile or so in EV at 35-40 mph but on flat road. It’ll go longer if the battery is full. Just keep the MAX gauge below half and you can force it to stay in EV.
    Tumbler and Mattedfred like this.
  7. Apr 12, 2024 at 10:19 PM
    Apein
    Apein New Member
    Yes. I ran out of gas once. It went into ev. I didn’t notice because it was quiet. Than realized it did. One other thing it wasn’t very fast. So good thing I wasn’t on the freeway. Also the tundra ran out of gas as soon as it went to zero.
  8. Apr 13, 2024 at 4:46 PM
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    Are you saying that if I run out of gas that it will go into an EV limp mode until the hybrid battery runs dead?
  9. Jun 3, 2024 at 10:55 AM
    Bhazelton010
    Bhazelton010 New Member
    The Tundra will not run in ev mode if it runs out of fuel... it doesn't have a limp mode..
  10. Jun 3, 2024 at 11:03 AM
    tesilential
    tesilential New Member
    Tampa bay
    ‘24 limited lunar rock hybrid TRD off-road
    The manual says hybrid mode won’t work if the low fuel light comes on. Says to refuel and ensure at least 5 gal are in the tank and hybrid engine will work again.
    Bhazelton010 likes this.
  11. Jun 3, 2024 at 11:29 AM
    Bhazelton010
    Yes I know.. was responding to guy that says he limped his tundra with no gas in ev mode.. letting people know that is 100 percent false
