Is this a problem?
Discussion in 'General Tundra Discussion' started by Outbound, Jul 5, 2018.
  1. Jul 5, 2018 at 12:45 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Is this cable supposed to be tight or tucked up more?15308199324801744152790.jpg
  2. Jul 5, 2018 at 12:48 PM
    Parking brake line huh? Looks no bueno amigo
    HighDesertSurfer likes this.
  3. Jul 5, 2018 at 12:49 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Yeah, doesn’t look good to me. Should be tucked up out of the way
  4. Jul 5, 2018 at 12:55 PM
    Casper421
    In the woods
    06 DC
    Does your parking brake work still?
  5. Jul 5, 2018 at 12:56 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It should probably look something like this:
    Does your parking brake hold your truck from rolling? Test it on an incline in neutral.
    Have you been under the truck and watched while someone else applied and released the parking brake?
    Pudge and HighDesertSurfer like this.
  6. Jul 5, 2018 at 1:29 PM
    Outbound
    Aaron
    Northern Alberta
    Park brake cable for sure. Park brake does not hold truck. As a rookie when it comes to auto mechanics, is this just something I need to tighten up somehow?
  7. Jul 5, 2018 at 2:00 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It’s hanging so loose it may be broken. You want to look at it while it’s being operated to confirm that the cable is moving with the operating of the control in the cab. If not, it may not be connected. Check this and report back
    TheBeast likes this.
  8. Jul 5, 2018 at 2:00 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    In the brake backing plate is a “bellcrank”, actually there is one on each side. Most likely one or both are siezed on the pivot - the lever is steel inside an aluminum pivot. Add road salt, time, and possibly not using the parking brake regularly, they sieze up, causing the rear shoes to drag and overheat, and also not self-adjust.
    Dorman makes an aftermarket kit to fix this, p/n 924-752, much cheaper than OEM.
    https://www.amazon.ca/Dorman-924-752-Parking-Brake-Crank/dp/B00C0UAABW
    Black Wolf and gosolo like this.
  9. Jul 5, 2018 at 2:07 PM
    Casper421
    In the woods
    06 DC
    There’s a turnbuckle in the drivers side frame rail under the drivers door that will take the slack out. However, that’s a lot of slack and not sure if you can take all that out. Tighten the turnbuckle and see how much slack is taken out.
    gosolo and HighDesertSurfer like this.
  10. Jul 5, 2018 at 2:38 PM
    Professional Hand Model
    Hand Protectors
    What is everyones thoughts on spraying anti-sieze on those “bell cranks” (careful to not spray on pads) and the turn buckle adjustments (under driver side door) to free them up? I’ve tried to adjust the turn buckle in the past without success. Never had a droop (as bad as) OP.
    BTW my parking brake never seemed to work properly ever since driving off the lot. Most other parking brakes would completely stop vehicle from moving. The 02’ Tundra it just seemed to slow things at half strength. Never a solid lock. Even had my mechanic ‘adjust’ one time and it was slightly better but never full strength.
    gosolo likes this.
  11. Jul 5, 2018 at 2:40 PM
    Outbound
    Aaron
    Northern Alberta
    The cable does move easily when the pedal in the cab is operated. Thankfully it doesn't appear broken.
    I found the turnbuckle and once it cools off a bit here, I'll tighten it up. Got some penetrating oil on it now. It definitely is alot of slack. Looks like almost 3 inches. Not sure if I have that much room in the turnbuckle, but we'll see
  12. Jul 5, 2018 at 2:42 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Anti-sieze or water resistant high temp grease is a great way to prevent the bellcranks seizing, but won’t do much to free them up in my experience.
    OP’s ‘05 has bigger rear brakes than your ‘02, and they do hold pretty good when all adjusted correctly.
    Should have quote PHM...
  13. Jul 5, 2018 at 2:45 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Check those bellcranks first, otherwise burnt rear shoes, axle seals... could be in your future.
  14. Jul 5, 2018 at 3:07 PM
    Outbound
    Aaron
    Northern Alberta
    Hmm, gonna have to figure out how to do that without a jack or jackstands. LOL.
    Black Wolf likes this.
  15. Jul 6, 2018 at 11:45 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You can just grab them from the back side without removing the wheel / drum to check them. They are the exposed levers the cables attach to.
    To replace them the drum and shoes have to be removed, but you can check for full movement back against the adjustable stop bolt just by crawling under the truck.
    Depending on how bad they are siezed (still assuming they are) you can tap them back to the released position, which should stop any dragging in the short term, and take the slack out of the cable so you don’t do the fighter jet / aircraft carrier thing. :eek2: :D
  16. Jul 6, 2018 at 1:13 PM
    Outbound
    Aaron
    Northern Alberta
    I always did want to be a fighter pilot. :D
    Yeah, they were definitely seized. The stop bolt was about 1/2" away from the stop plate on the driver's side and at least an inch away on the passenger side. I tapped them back into place and cable slack is gone. I ordered up a jack and stands which should be here next week. I also ordered that parts kit you linked to. The stuff should be here on Wed so hopefully next weekend I'll tackle this job.
    Thanks for the help! :D
  17. Jul 6, 2018 at 1:25 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Success!
  18. Jul 6, 2018 at 1:47 PM
    Casper421
    In the woods
    06 DC
    Nice work and does the parking brake work?
  19. Jul 6, 2018 at 1:49 PM
    Outbound
    Aaron
    Northern Alberta
    I haven't tested it since knocking the stop bolts back into place. Thunderstorm rolling in so I'll check that after the rain stops.
  20. Jul 6, 2018 at 2:12 PM
    Hand Protectors
    I wonder now that they are tapped back if the anti seize and some grease would suffice? Obviously, new parts on the way is best but for future may be an option. Haven’t used my parking brake in a while and this thread has me wondering. Great advice people!
    gosolo likes this.
  21. Jul 6, 2018 at 3:55 PM
    Hand Protectors
    Went under and checked the cable which is slightly taut with the bell cranks and springs against the backside of drum case at the bolt stop. No tapping required as they weren’t seized. Greased them up. Can see how one would have to remove the entire drum to access the internal parts shrouded by the rubber boot where the bell cranks dive into the drum.
    Test pushed the parking brake foot pedal and it felt firm, but failed to stop the trucks forward movement in anyway. This is why I stopped using the parking brake because its easy to forget its on if it doesn't stop the truck. May need to work on it a bit more near the turnbuckle.
    Outbound[OP] likes this.
  22. Jul 7, 2018 at 9:59 AM
    Hand Protectors
    Conclusion: For the 02’ Tundra, seems as if the design for this parking park is poor. Came to this conclusion after adjustments were made at the turnbuckle. I PB blasted the nuts at the turnbuckle under drivers side door. My cable was not very loose, but was able to relieve about an inch of thread on the adjusting rod. Got it at the optimum point and the brake is only slightly better.
    I think the lever hitch on the middle of the back axle where the cable dissects to go to each drum is where the design is flawed (dissimilar pull pressures). After that there are too many variables to adjust making the solution not worth the time.
    Hope the OP has better success. Looking forward to the info.
  23. Jul 7, 2018 at 10:09 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    There's a cable inside the drum itself too. I had to replace both of them and the bell cranks on both sides of my 04...and it will hold great for about 2 weeks then even using it every day to keep it adjusted it seems to loosen up.
  24. Jul 7, 2018 at 10:16 AM
    Hand Protectors
    Yeah this is what I was thinking. Not worth it. Thanks for the input.
  25. Jul 7, 2018 at 10:18 AM
    Outbound
    Aaron
    Northern Alberta
    Yeah, sorry guys. Weather took a turn for the worse here and with no garage it looks like I won't be tackling this until later in the week.
    We'll see how involved the work gets on it, but I may end up returning the parts to Amazon if it's too much of a hassle. I honestly never use the parking brake anyways, which is probably why it's seized on my truck.
  26. Jul 7, 2018 at 10:25 AM
    Hand Protectors
    Same here. Except the seizing part. You could spray and put some grease on the cranks, adjust the turnbuckle to take out remaining slack, and call it a day. Its a bad design problem IMO. Too many working parts. Not to mention the stretch factor on the cable. You could chase this thing forever!
    Outbound[QUOTED][OP] likes this.
  27. Jul 7, 2018 at 10:38 AM
    Sunnier
    Sunny
    San Diego, CA
    Weird timing of your post (in relation to a recent first ever conversation I had about this same thing): my sister and b.i.l. live in northern ID where the winters get cold. They've experienced this failure of the parking brake and believe, based on others' experience in that area, that it literally freezes up. I think they fixed it once (warrantee period) then left it alone after that....
  28. Jul 7, 2018 at 11:13 AM
    Outbound
    Aaron
    Northern Alberta
    I think that's what I'm going to do. I cancelled the parts order for now. Since the only time I ever used it was while working under the truck, I'll just forget about trying to fix it and chock the tires when needed.
