Is this an Aisin Transmission
Discussion in '1st Gen Tundras (2000-2006)' started by ProudTundran, Sep 10, 2021.
  1. Sep 10, 2021 at 7:43 PM
    ProudTundran
    ProudTundran [OP] New Member
    2005 Tundra SR5 DC RWD
    [​IMG] [​IMG]
    I have owned my truck since February. I was looking through my Haynes manual to see if the picture of the transmission ID plate was similar to what is under my 2005 2WD DC. What I found was a label with a QR code showing 35010-0C050. I was sure that this was an aftermarket transmission because it did not show the Aisin ID plate. A Google search suggests that this is likely the original transmission. Is the 35010-0C050 an Aisin branded transmission. Is this the A750E transmission. Thanks.
  2. Sep 10, 2021 at 9:11 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Re: Is this...?
    Yes and yes.
    ProudTundran[OP] likes this.
  3. Sep 12, 2021 at 7:26 AM
    It's definitely OEM. 90% or more of Toyota part numbers follow a pattern of #####-0c0$$ where # is a number and $ is a letter or number.
  4. Sep 12, 2021 at 7:53 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm guessing your 05 has a different ID plate on it because it's a different transmission(5 speed vs 4) but on my 2002, it has an Aisin ID plate that is similar to the one in the Haynes manual. I'm betting the other guys are correct that it's probably NOT aftermarket. I wouldn't sweat it.
  5. Sep 12, 2021 at 7:55 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The a750 didn’t have a plate. The a340 did
    What you’ve got is the original a750
    shifty` likes this.
  6. Sep 12, 2021 at 1:03 PM
    ProudTundran
    Thanks for the little nugget regarding the Toyota part number sequence. This is good to know.
  7. Sep 12, 2021 at 1:05 PM
    ProudTundran
    Thanks for the response. This Tundra is my first vehicle where I am getting to know its many moving parts in depth. The help that I am getting from other first gen owners through this forum prompts me to get to know my truck even more.
    Sirfive and empty_lord[QUOTED] like this.
  8. Sep 12, 2021 at 1:43 PM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    This is Interesting…Aisin makes the transmission that goes in the 1000 lb foot Cummins ram. They also make those really heavy duty manual locking hubs. Makes me feel good that a well made slush box is behind the 4.7 in my Tundra.
  9. Sep 12, 2021 at 1:48 PM
    empty_lord
    05 rollover special
    Almost all the Toyota transmissions are Aisin Warner
  10. Sep 12, 2021 at 1:53 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Sweet! I didn’t know that…shows my knowledge of Toyota products.
    empty_lord[QUOTED] likes this.
