Issue Filling Up My Gas Tank
Discussion in 'General Tundra Discussion' started by keenanduran1, Apr 13, 2020.
  1. Apr 13, 2020 at 1:37 PM
    keenanduran1
    keenanduran1 [OP] New Member
    Keenan
    2017 Tundra 4x4
    Stuff for Mexico
    Hey guys. I have a 2017 Tundra and I am having an ANNOYING issue with my gas tank. When filling up my gas tank the gas keeps coming back up and shuts off the gas. Takes me like 30+ minutes to fill up my tank. I replaced the vents and the hose but its still having this issue. Some one said I have to replace my tank. Seeing if any of you can help y diagnose and fix this before going this route.! Thank you
    831Tun likes this.
  2. Apr 13, 2020 at 1:39 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Sometime it could be a shitty pump at the gas station. I have noticed this when filling up rental cars. Does it happen at other gas stations too?
    GeezePlease, 15whtrd and 14burrito like this.
  3. Apr 13, 2020 at 1:39 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Does it fuel properly with hoses to canister disconnected?
    You mentioned replacing hoses and such...if the canister is saturated, new hoses etc wont help. If it fuels fine with vent tubes to the canister disconnected then the canister is more than likely the culprit.
    Black Wolf and 15whtrd like this.
  4. Apr 13, 2020 at 1:40 PM
    keenanduran1
    Keenan
    2017 Tundra 4x4
    Stuff for Mexico
    It happens at al the pumps i go to
  5. Apr 13, 2020 at 1:41 PM
    keenanduran1
    Keenan
    2017 Tundra 4x4
    Stuff for Mexico
    My fried replaced it at his shop in long beach. If you can tell me how to disconnect it ill try it
  6. Apr 13, 2020 at 1:42 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Unfortunately I'm not near my truck. But the evap canister I think is right above the axle on the driver side. Just disconnect the vent lines going to it.
  7. Apr 13, 2020 at 2:58 PM
    TheBeast The Beach
  8. Apr 13, 2020 at 5:31 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Couple of questions. 1) Do you off road your truck? 2) Do you top off your tank?
    Topping off your tank can cause problems with the charcoal canister in your evap system....... Expensive to repair
    If you wheel you may have a stuck roll over valve. Sometimes this problem resolves itself.... I know of 1 such case.
    The proper fix is (you were informed correctly) is to replace the tank. What I did was drop the tank, remove the filler hose at the tank and pop the valve open. The valve is located about 7" down and there's an anti-siphon ring to get past. You can see the valve/gate, it's shiny silver.
    15whtrd, Black Wolf, TheBeast and 5 others like this.
  9. Apr 14, 2020 at 3:24 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  10. Apr 14, 2020 at 3:59 AM
    Tundyfundy
    Bay Area, CA
    I think topping off is considered overfilling, not filling. If it clicks once it’s full, it you pull the trigger again it’s topping off. At least that’s how it usually works.
  11. Apr 14, 2020 at 5:18 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I found a charcoal canister on ebay for $200. Its still sitting in my garage waiting for me to install it haha
    831Tun[QUOTED] likes this.
  12. Apr 14, 2020 at 8:17 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    @Tundyfundy is correct. Full tank is fine but trying to force another half gallon in after that first click of the pump will foul the charcoal canister.
  13. Apr 14, 2020 at 9:37 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I used to fit 3.5 ga in after the first click haha
  14. Apr 14, 2020 at 9:44 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    joonbug and osidepunker[QUOTED] like this.
  15. Apr 14, 2020 at 9:47 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I was probably using my charcoal canister as an aux fuel cell
  16. Apr 14, 2020 at 10:10 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, you're never one to push the limits,,,,,:benchpress:. I can't can't believe it dried out and is working again, that's really cool. You could probably sell your spare for $250.:p
  17. Apr 14, 2020 at 12:36 PM
    TheBeast The Beach
    :spy::spy:
    Tundyfundy[QUOTED] likes this.
  18. Apr 14, 2020 at 2:05 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Oh no its still messed up. I have to keep the nozzle just under one click. But Im able to fill it up thats why I havent been motivated to swap it :rolleyes:
  19. Apr 14, 2020 at 4:39 PM
    keenanduran1
    Keenan
    2017 Tundra 4x4
    Stuff for Mexico
    It's not that
  20. Apr 14, 2020 at 4:43 PM
    keenanduran1
    Keenan
    2017 Tundra 4x4
    Stuff for Mexico
    Yes I do offroad quite a bit. Ill try and drop it. When you say pop the valve, should that fix the issue. In theory
  21. Apr 14, 2020 at 5:53 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yes, sort of. You can "pop" it back open with something long and thin. Mine snapped open really easily. My fear was that it'd just happen again so I bent the gate and disabled the valve completely. I, of course, can't recommend this for anyone else.
    pickeledpigsfeet and joonbug like this.
  22. Apr 16, 2020 at 9:35 PM
    keenanduran1
    Keenan
    2017 Tundra 4x4
    Stuff for Mexico
    I dropped the tank this morning and that rollover valve was the issue. Thank you so much!
  23. Apr 16, 2020 at 10:33 PM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    TSP on this issue for 2017s. The fix is a new filler neck. It was happening to my 2016 and they just replaced the filler neck a week ago. I haven’t tried to put any gas in yet since I’m not really going anywhere.
    It has been happening to me on and off over the last several months.
  24. Apr 16, 2020 at 10:48 PM
    keenanduran1
    Keenan
    2017 Tundra 4x4
    Stuff for Mexico
    I replaced my filler neck because i thought it was the issue, but it still happened. After I dropped the dank and looked down filler neck hole i saw the silver Roll Over Valve, used a piece of bailing wire to push it, super easy, and put it back together and it works. Took me and my brother like 40 minutes total
    831Tun and newguy[QUOTED] like this.
  25. Apr 16, 2020 at 10:53 PM
    newguy
    newguy New Member
    I may have to connect with you in the future if it happens to me again. SO frustrating!!!
  26. Apr 19, 2020 at 8:06 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Once I hear the click I wait 30 sec then fill one more time. This bad? Learned the trick from TFL on YouTube.
    831Tun likes this.
  27. Apr 19, 2020 at 8:34 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I honestly don't know. But, risks vs rewards?
    joonbug likes this.
  28. Apr 19, 2020 at 4:28 PM
    newguy
    newguy New Member
    After replacing the filler neck, still can’t put gas in.
    831Tun likes this.
  29. Apr 19, 2020 at 8:10 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Sounds like you need to run the tank low, drop it and pop the roll over valve open.
  30. Apr 20, 2020 at 1:19 PM
    keenanduran1
    Keenan
    2017 Tundra 4x4
    Stuff for Mexico
    Well, It worked for filling up my tank once. IDK what happened but I can tfill up the tank again without the gas shutting off 10 cents at a time.
    831Tun likes this.
