Issues to look for when buying a 2014-21 Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Midsouth Jacket, Feb 19, 2024.
  1. Feb 19, 2024 at 8:03 AM
    Midsouth Jacket
    Midsouth Jacket [OP] New Member
    Ted
    2015 SR5 Crewmax Magnetic Gray Metallic
    Bilstein 5100 front and back, Coachbuilder +3 shackle, 18x9 +1 Fuel Vector wheels, 35x12.5 Toyo M/T
    I currently own a 2015 SR5 flex fuel. I think I’ve figured out the flex fuel issue thanks to the great info on this site. But she has 210k. My original plan in buying the truck in 2017 was to drive it “forever” which I still might do. However, I was contemplating upgrading to a newer 2.5 Gen in order to have a lower mile truck with nicer trim level, LED lights, and additional safety features etc. Basically everything that was added in later years. Since Toyota went to the V6 turbos, the V8s are getting older and older and I was hoping to snag one in the next year or so if the market is right. Currently seeing $42k in my area for a vehicle with less than 50,000 miles.
    Other than the flex fuel issue (which I know all too well about) in terms of engine, performance, recall, or electrical issues common to later 2.5 Gen what should I look out for if test driving, looking under the hood or under the car?
    thanks in advance!
    MSJ
  2. Feb 19, 2024 at 8:15 AM
    d33pt
    d33pt New Member
    What's your issue with Flexfuel? I have a 2015 FF but haven't had any issues yet.
  3. Feb 19, 2024 at 8:24 AM
    Midsouth Jacket
    Ted
  4. Feb 19, 2024 at 8:26 AM
    PentagonTundra
    PentagonTundra New Member
    2018 Tundra Platinum 4x4
    fully stock
    Midsouth Jacket[OP] likes this.
  5. Feb 19, 2024 at 8:36 AM
    d33pt
    d33pt New Member
  6. Feb 19, 2024 at 8:39 AM
    Midsouth Jacket
    Ted
    Personally no. I bought the truck with 70k miles. I don’t know if the original owner did but I don’t think the issue depends on that.
  7. Feb 19, 2024 at 8:44 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Just check for cam tower leaks.
    2mchfun and Midsouth Jacket[OP] like this.
  8. Feb 19, 2024 at 9:10 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  9. Feb 19, 2024 at 9:27 AM
    2mchfun
    Cam tower leaks, valley plate coolant leaks, lacking auxiliary transmission cooler, sticky or stuck 4x4 engagement, frame rust, water in rear diff from boat launching, lots of paint chips around safety chain loops on the hitch (indicator of frequent towing).
    Beware of flood damage as well!
  10. Feb 19, 2024 at 9:28 AM
    Midsouth Jacket
    Ted
  11. Feb 19, 2024 at 9:29 AM
    Midsouth Jacket
    Ted
    Awesome thank you!
    2mchfun[QUOTED] likes this.
  12. Feb 19, 2024 at 9:32 AM
    If it has oversize tires assume it has more miles than listed.
  13. Feb 19, 2024 at 9:32 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Not mine but have the exact same truck and very pleased. I do think you would enjoy a 2020 or 2021, I just remembered this one had low mileage and reasonably priced. Funny story! I reached out to the dealership trying to buy the topper, no dice but I thought what the hell worth a shot.
