Jacking points with a factory bottle jack.
Discussion in '2.5 Gen Tundras (2014-2021)' started by JayKay, Apr 10, 2023.
  1. Apr 10, 2023 at 5:07 PM
    JayKay
    JayKay [OP] New Member
    Hi everyone! Just checking to see if anyone knows where I should place the factory bottle jack when I get a flat tire to jack up a 2014 Tundra Platinum. I think you're supposed to put the bottle jack underneath the plate where the u-bolts are to jack up the rear but where do I put the bottle jack to jack up the front? Any help would be greatly appreciated!
  2. Apr 10, 2023 at 6:42 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    From the "friendly manual".
  3. Apr 11, 2023 at 4:19 PM
    JayKay
    Thank you Randy for this manual but the bottle jack will definitely not be able to reach the frame to jack the truck up at the front.
  4. Apr 11, 2023 at 6:22 PM
    biebs96
    PA
    If the truck is stock, it is long enough.
    It is sketchy for sure, but it will work.
    I keep two 8” pieces of 2x8 screwed together under the rear seat, to use under the jack. Helps it reach with 35s installed.
    Randy Morton and bulldog93 like this.
  5. Apr 11, 2023 at 7:21 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    "Follow for more tips!"
    "Use this one trick to keep your cats! Methheads hate him!"
    Sierradevil likes this.
  6. Apr 12, 2023 at 11:02 AM
    JayKay
    Thanks Biebs, I will do the same.
    biebs96[QUOTED] likes this.
  7. Apr 12, 2023 at 11:08 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I keep my floor jack in the bed of my truck, then I don't need to carry it out when I need to use it in the drive and I wont have to fool with the bottle jack if I get a flat on the road. Also carry a patch kit and compressor.
  8. Apr 12, 2023 at 11:23 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I bought the the Ryobi cordless compressor. It's about the size of a cordless impact driver (I have a bunch of their cordless stuff and almost always have a battery with me). I didn't expect much, but it actually pumped up my E tires on the van to 75psi. It's much easier if you can jack it up a bit to get the weight off while pumping. Whatever kind is easiest to carry, having at least some kind of compressor on board is a good idea.
    The last truck had a cap and the bed was full of tools/gear all the time. I kept a hunk of 2x10 and 2 small pieces of 4x4 and a jack stand in the bed at all times. Those things and the bottle jack under the seat and I felt covered.
    At the minimum, it wouldn't hurt to keep a few small hunks of lumber on board. That and the bottle jack will at least let you get a flat changed out in the boonies.
    Also, a wheel chock or 2 is a good idea. I have a few stamped steel chocks that don't take up any room at all.
