JB4
Discussion in '3rd Gen Tundras (2022+)' started by 2020Platinum, Mar 25, 2023.
  1. Mar 25, 2023 at 6:38 AM
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Finally installed the JB4 in the TRD Pro, thing is awesome...running map 2 for now so still have room to increase but man, you feel the difference for sure when that boost kicks in
    JB4 with Bluetooth Option...Install/1st Drive Impression...2022 Toyota Tundra TRD Pro
    https://youtu.be/2bL2clQpodE
    T-MAC, Supertech1, forzamrit and 5 others like this.
  2. Mar 25, 2023 at 9:25 AM
    rozemab
    rozemab New Member
    Does this void your warranty?
  3. Mar 25, 2023 at 9:53 AM
    Tom976
    Tom976 New Member
    Tom
    Engine mods like this? Oh ya. Wonder if you can just remove it and leave no evidence if there is a problem.
  4. Mar 25, 2023 at 10:51 AM
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    With all the data logging these vehicles do it is very unlikely there would be no evidence a dealer or manufacturer could find.
    chaztizer, Gotink and DeafJam like this.
  5. Mar 25, 2023 at 4:55 PM
    DeafJam
    DeafJam New Member
    Louisiana
    2023 Toyota Tundra Hybrid, 1794 edition
    Cosmetics for for a pavement princess.
    There is plenty of evidence left behind.
    Gotink likes this.
  6. Mar 25, 2023 at 5:44 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    BMW never found any evidence left behind. Had my 335 serviced several times. Even replaced my mechanical fuel pump with no issues.
    forzamrit and 2020Platinum[OP] like this.
  7. Mar 25, 2023 at 11:32 PM
    DeafJam
    DeafJam New Member
    Louisiana
    The level they look is directly correlated to the level of the issue. A new fuel pump isn’t going to get the same scrutiny that an engine replacement will get. One of those I really want my warranty for a lot more than the other
    BMW does not force the dealer to tell you if your car is flagged when it is scanned during A or B service. When I last kept up with BMW (when I had a Supra), this was not unheard of on the forums. Tunes were regularly caught and JB4 did not have a perfect record either. It is just easier to look the other way on a JB4 if you are smart and you also don’t have a high value claim.
  8. Mar 26, 2023 at 7:21 AM
    DeafJam
    DeafJam New Member
    Louisiana
    @2020Platinum Have you found published dyno curves for the before and after for the hybrid?
    I am liking the power plant as is, but if I can get another year of seeing reliability out of it, I may make that leap.
  9. Mar 26, 2023 at 7:59 PM
    2020Platinum
    Patrick
    Northeast PA
    Not yet, I've tried to get mine on a dyno to have proven/solid results but unfortunately the only two places that do it within a 2 hour drive radius of me both said they can't accommodate my truck because of the width/tires… Sucks, wish I was able to get mine on one to have solid numbers, especially for my viewers!...can't find any other shop in my general area that even does dyno pulls
  10. Mar 30, 2023 at 4:23 PM
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Curious if this is better than a throttle controller. I've seen some say it's better value, others say combine them both. Any thoughts?
  11. Mar 30, 2023 at 4:28 PM
    Black widow TRD
    Manuel
  12. Mar 30, 2023 at 5:18 PM
    chill_trd
    chill_trd New Member
    '22 TRD limited
    The tuner is going to add horsepower to the vehicle, the throttle controller is just going to give you more control of that horsepower and remove some lag. So both is probably ideal but value is probably in the tuner.
    Taikowaza and 2020Platinum[OP] like this.
  13. Mar 30, 2023 at 5:27 PM
    RickyBobbysTundra
    Phoenix
    Are throttle controllers over $150 worth it? Seems like they're all basically the same thing, just different housings and aesthetics/brandings.
  14. Mar 31, 2023 at 9:34 AM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Very sad and disappointed that none of their tunes are available for the 2022+ Tundra SR engines :-( I know it’s software tuned down version of the same engine.
  15. Apr 1, 2023 at 5:16 PM
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    I just pulled my JB4 for my first service appointment. It was a disaster trying to get the rear plug out on my hybrid. No room and that clip didn’t want to let go. And hour later and both my hands are bleeding. What a shit show to remove.
    RickyBobbysTundra likes this.
  16. Apr 1, 2023 at 5:26 PM
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    Why remove it? Unless you're doing warranty work, it shouldn't matter if it's in there....
    Esoto787 likes this.
  17. Apr 1, 2023 at 5:30 PM
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    Don’t want to put my 10yr/100k warranty in jeopardy after 5k.
    Tuna22 likes this.
  18. Apr 1, 2023 at 5:40 PM
    pnw.tundra
    Paul
    PDX
    Fair enough. I remember taking mine out of my M3 for each service a few years ago. Bloody knuckles and all just like you. It got tiring for sure.
  19. Apr 1, 2023 at 6:21 PM
    2020Platinum
    Patrick
    Northeast PA
    As mentioned above, the JB4 tuner is going to actually add horsepower which you can definitely feel… Items like the Pedal Commander and similar only adjust throttle response, they don't actually add performance gains… I'm going to be putting my Pedal Commander back in to go with my JB4, should be awesome having both!
  20. Apr 2, 2023 at 6:21 AM
    2020Platinum
    Patrick
    Northeast PA
    Did you try removing that bolt I show in the video that holds the hybrid harness in place?...gave me just enough wiggle room to take that connector in and out a little easier
  21. Apr 3, 2023 at 9:08 AM
    RickyBobbysTundra
    Phoenix
    I also have a hybrid. I'm going to go ahead and guess this was not plug and play as I initially thought?
  22. Apr 3, 2023 at 9:20 AM
    2020Platinum
    Patrick
    Northeast PA
    It's definitely plug n play, it's just that back harness is a pain to get to...if ya haven't watched my video I show exactly where it is and where that bolt is to remove on the hybrid harness to make it at least a little easier (mine is a TRD Pro/Hybrid)...let me know if I can help!
  23. Apr 3, 2023 at 9:31 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Super easy on non-HV. You guys with that fancy hybrid setup gotta bleed a lil for this mod.
  24. Apr 3, 2023 at 2:22 PM
    Black widow TRD
    Manuel
    As a caveat be sure to go to settings and clear the stored codes.
    So there is no evidence of overboost, if it does report such an occurrence. on my BMW I’d be sure to clear what in the BMW world we call shadow codes.
    path is settings, advanced, app settings then clear saved codes.
  25. Apr 3, 2023 at 2:29 PM
    eddiefromcali
    Eddie
    100% Stock
    I have yet to throw an overboost code in a year running the JB4 on map 5. I think BMS set pretty mild maps and I think Terry even said he felt there was another 30-50hp left in it.
    Black widow TRD likes this.
  26. Apr 3, 2023 at 2:32 PM
    Black widow TRD
    Manuel
    Neither have I, I’ve only been running Map 5 for about a month. Just throwing it out there just as a CYA.
    I know I had 2 codes when I disconnected the map sensor and whatever other sensor you disconnect upon initial install.
    I had to go to the aforementioned menu to completely clear those codes from memory. I didn’t wanna leave Toyo an hint of me altering the truck.
    eddiefromcali likes this.
  27. Apr 3, 2023 at 8:45 PM
    2020Platinum
    Patrick
    Northeast PA
    So is it true that the JB4 leaves no footprint if you clear these out?...I've had several viewers ask and I can't get a definitive answer, and don't want to give anyone wrong info!
  28. Apr 3, 2023 at 9:20 PM
    eddiefromcali
    Eddie
    100% Stock
    Leaving a footprint, no it does not. That doesn't mean that recorded data cannot be interpreted as there being some modification at some point. Good example would be injector duty cycle at WOT. Since the JB4 tricks the ecu into seeing lower boost than actual, any WOT data will show injector duty cycle higher than stock at oem boost levels. This is not a jb4 footprint but it's likely solid evidence that some trickery was at play. Any engineer would expect to see X% of duty cycle at WOT/Xlbs of boost. If they see a considerable higher % at "stock boost" they'll know its fake data.
    They won't see any other data like if the JB4 was in/uninstalled but they don't need to. They'll just interpret the data and any significant deviation from expected values will tell them.
  29. Apr 4, 2023 at 2:15 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Anybody know the details as to why the SR cannot be “tuned”?
    Justa_SR and Woocawachie[QUOTED] like this.
  30. Apr 8, 2023 at 5:37 AM
    RPKEAN
    RPKEAN New Member
    Ryan
    Just to add, anyone using JB4 on a non-hybrid? Thoughts? While I more an likely saved 6-7k off my current Platinum, I do definitely feel he initial turbo lag that is most likely not here in the hybrid. I will say I’m more often driving in sport mode in the city to alleviate this.
    still happy with the stock power regardless although I feel like my 19 had a bit more torque initially off the line.
