JBA Offroad UCAs with Method +25 Offset 2022 TRD Offroad
Discussion in '3rd Gen Tundras (2022+)' started by StinkyCheeze, Oct 24, 2024.
  1. Oct 24, 2024 at 6:22 PM
    StinkyCheeze
    StinkyCheeze [OP] New Member
    Carlos
    2022 Toyota Tundra TRD Off-Road
    Hi all. I just ordered a set of Method 305 wheels with a +25 offset for my 2022 Tundra TRD with the TRD Offroad package. I'm going to wrap these with a set of 315/70R17 BF Goodrich KO3 tires. I also ordered a set of Fox Performance Elite Series shocks, wich is going to give me a 2-2.5 inch lift which means I'm going to need to get some Upper Control Arms. I really like what i have been reading about the JBA Offroad UCAs, but my question is, will the work with my setup? Does anyone on here have a similar setup? Would love to get some validation that this will work because I don't think if I will be able to return these.
    Thanks in advance!
  2. Oct 24, 2024 at 6:29 PM
    Dtrancrx
    Dtrancrx New Member
    What's gonna work?.the wheels?..plus 25 is the sweet spot for 37s..so your 315s will work for sure
  3. Oct 24, 2024 at 6:33 PM
    StinkyCheeze
    Carlos
    I was asking about the UCAs. I've read that the JBAs are a little bigger so they tend to rub with bigger tires.
  4. Oct 24, 2024 at 6:36 PM
    Dtrancrx
    Dtrancrx New Member
    Oic..sorry, havent heard of that brand, why not camburg or total chaos?
  5. Oct 24, 2024 at 6:44 PM
    StinkyCheeze
    Carlos
    I like the camburg UCAs, but they are more expensive. Even if they were the same price though, I still think I would prefer the JBAs because of the servicability. Real easy to change the ball joints without having to redo the alignment.
  6. Oct 24, 2024 at 6:46 PM
    Dtrancrx
    Dtrancrx New Member
    Oic, didn't know that
  7. Oct 24, 2024 at 7:14 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I had the 25mm Methods on a 2017 with the JBA and 295's, the JBA's had a ton of clearance. I don't see any issue with the 315's
    StinkyCheeze[OP] likes this.
  8. Jan 26, 2025 at 7:10 PM
    mikeaesq
    mikeaesq New Member
    2025 1794 TRD Off Road
    @StinkyCheeze any pics of how this all turned out? I’m looking for a pretty similar set up.
  9. Jan 26, 2025 at 7:44 PM
    StinkyCheeze
    Carlos
    Yes, it worked out perfectly for me. I didn’t want to lift it beyond what the UCAs would add and this setup allowed me to fit the 315/70 17s on the Method 305 wheels with a +25 offset.
    I like the way it came out. Here are some that I had taken a while ago. Will try to get some better ones tomorrow.
    mikeaesq and TRD_84 like this.
  10. Jan 27, 2025 at 3:18 AM
    TRD_84
    TRD_84 New Member
    Chad
    Ohio
    2024 Lunar Rock Tundra Limited TRD Off-Road
    Rough Country Vertex 2.5 Leveling Coilovers 1” Cornfed rear spacer 275/65r20 Nitto Terra Grappler G3 WeatherTech Alloy Tonneau Cover Body Armor 4x4 Power Running Boards Bedrug Classic Bed Mat XPEL Prime XR ceramic window tint BeatSonic Amp (Non JBL system) TRD Puddle Lights from MVPAutoSupplies TRD air filters TufSkinz Foam Console Inserts Spigen Screen Protector TRD Pro Grille Swap w/ OEM marker lights TRD Dual Exhaust tips TRD Pro Camo rear bumper and front fog lights cover TRD Pro glovebox trim swap Matte Black interior vent overlays
    Looks great!
  11. Jan 27, 2025 at 6:32 AM
    mikeaesq
    mikeaesq New Member
    Looks great! Any rub on the sway bar with that wheel offset? Any lift in the back or is that stock height?
  12. Jan 27, 2025 at 7:22 AM
    StinkyCheeze
    Carlos
    No rub at all and while the JBA UCAs lifted it up a few inches in the front, it's all stock height in the back.
    mikeaesq[QUOTED] likes this.
