JBA Performance Exhaust review
Discussion in 'Performance and Tuning' started by B.Ross, Mar 21, 2020.
  1. Mar 21, 2020 at 1:54 PM
    B.Ross
    B.Ross [OP] New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Just my thoughts on a value priced cat back exhaust in SS. Your mileage may vary....
    https://shop.jbaheaders.com/jba-per...-7-5-7l-universal-single-side-swept-exit.html
    Total install time was about 3hrs with a trip to O'REILLY's.
    Straight forward color directions and all parts accounted for.
    Some of the tools I used for install
    Map gas and PB blaster along with my impact wouldn't budge the flange bolts. So out came the Milwaukee hack saw. Cut off the flange nuts and cleaned up with the grinder. (I had the nuts/ bolts on hand) Finished with high temp paint.
    The flanges bolt together nicely. Reused the gaskets since they stayed intact.
    Get the muffler hung and tail pipe installed.
    Get the U clamps on and go to hang the muffler bracket and...this is were the word "universal" comes into play.
    The Y pipe is too long! The muffler bracket U clamp won't hang off the factory bosses.
    The bracket is asymmetrical and can't be flipped. I ponder this for a bit while tightening the clamps.
    Off to O'REILLY's. I purchase 2 rubber muffler straps and problem solved. (See above pics closely)
    If you're a DIY kinda guy this kit is a great value at $347.00 shipped. I had $3.00 in bolts and $10 for the 2 muffler straps for a total of $360.00
    Overall grade for fit B & finish A.
    Note: There's 1.5" of clearance between the driveshaft and muffler. Guys with a large spare tire may have issues. About 1.5" clearance between factory sized spare and where the tail pipe turns 90° to the tip.
    Darkness, Rica25 and toyofan87 like this.
  2. Mar 21, 2020 at 1:55 PM
    B.Ross
    Southern Utah
    Let's talk sound next.
    No real drone or not enough to be off putting.
    Pretty mellow/ quiet tone.
    No discernable loss of low end torque.
    Excuse the cab noise my Tundra isn't exactly quiet.
    Hope this helps someone considering this system. I'm happy with it FWIW.
    Jcmf52 and Rica25 like this.
  3. Mar 21, 2020 at 1:57 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Subscribed
    Rica25 likes this.
  4. Mar 21, 2020 at 2:13 PM
    B.Ross
    Southern Utah
    BTW.
    JBA had 2 of these kits left in stock after I ordered mine Tuesday morning. Had my kit in hand on Friday. Quick shipping from California to Utah.
    Rica25 likes this.
  5. Jan 9, 2021 at 12:54 PM
    Rhubarb
    Rhubarb New Member
    Hello Ross. Is the muffler a straight through design? Thank you.
    Rica25 likes this.
  6. Jan 10, 2021 at 8:23 PM
    B.Ross
    Southern Utah
    Baffled.
    Rica25 likes this.
