JBL System question
Discussion in 'Audio & Video' started by babyyodacuh, Apr 20, 2021.
  1. Apr 20, 2021 at 5:33 PM
    babyyodacuh
    babyyodacuh [OP] New Member
    I am sorry that this has probably been covered but after an hour of digging I cannot find my answer.
    is the problem with the crappy sound from the JBL sound system the head unit, the amp, the speakers or all? I really don’t want to get rid of the stock head unit but I will gut everything else!
    thanks for the help
  2. Apr 20, 2021 at 5:38 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    You can keep the head unit with a DSR, AMPPro or similar device. The speakers are a weak link but the system as a whole sucks. You can get decent sound with upgrading everything but the HU. The best sound will come from a full upgrade
    RdKing and babyyodacuh[OP] like this.
  3. Apr 20, 2021 at 5:39 PM
    Cfincke
    San Antonio
    All of it sucks. I have already replaced the amp and speakers and it is so much better. One day I will replace the head unit like @Danimal86 has. If you keep the head unit, you will need a sound processor, the Rockford fosgate DSR1 has a plug and play harness for the tundras.
    I would recommend getting un touch with James with Tech12volts, best way is to email him. He builds his boxes here in the USA and can get you set up for your budget.
  4. Apr 20, 2021 at 5:51 PM
    babyyodacuh
    Thank you both! I like the clean look of the stock head unit. I am not I need of a super audiophile system. Just one that doesn’t suck
    RdKing and Saltyhero13 like this.
  5. Apr 20, 2021 at 5:54 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    If your truck is 2019 or older, the factory HU has pretty much zero redeeming qualities. The weakest part of the setup is the stock sub.
  6. Apr 20, 2021 at 7:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I was in your shoes, everyone said to ditch the head unit.....I held on for about 3 years, until I couldn't take it any more. The factory head unit is the weak link. Take the $300 or so that you would spend on a dsr1 and put it towards a new head unit. Wireless android auto is amazingly awesome and sound quality is so much better.
  7. Apr 21, 2021 at 12:59 PM
    babyyodacuh
    It is a 2021
  8. May 21, 2021 at 12:04 PM
    rrp0968
    rrp0968 New Member
    Do you lose the integration with the truck like the gauge cluster display when changing head unit?
  9. May 21, 2021 at 1:10 PM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Will you be doing the work yourself? What is your budget?
  10. May 21, 2021 at 1:19 PM
    AT x AT
    Jimmy
    Mods, what mods?
    These are the threads I read and gathered ideas from:
    https://www.tundras.com/threads/2020-jbl-amp-replacement-my-dyi.63052/
    https://www.tundras.com/threads/tundra-audio-wiring-harnesses-jbl-and-non-jbl.43781/
    https://www.tundras.com/threads/how-to-add-a-new-amp-to-your-3rd-gen-tundra-jbl-entune-system.22527/
    https://www.tundras.com/threads/tundratex-2016-crewmax-audio-build.7394/
    I want to keep the stock head unit.
    You can look in to getting the following:
    12" shallow sub with box (assuming you have a CM, so the depth will be a challenge. I think it's about 8" on the bottom and about 5" at the top. reference @TundraTex build thread for box measurements [https://www.tundras.com/threads/tundratex-2016-crewmax-audio-build.7394/])
    5 channel amp
    amp wiring kit
    Audio Control LC7i
    Audio Control ACR1
    JBL amp wiring harness adapter (from my understanding, it allows you to keep the factory amp and add the aftermarket amp downstream and pump the signal to the speakers.)
    Bottom line is really your budget. I priced my build out and it cost me just over $600 for materials. I did the install myself and I'm pretty technically inclined. The install took me about 5 hours, which included wire management and labeling them for future reference.
