JL 1 12TW3 Vs. 2 10TW3
Discussion in 'Audio & Video' started by Master_tundra, Feb 2, 2019.
  1. Feb 2, 2019 at 7:06 PM
    Master_tundra
    Master_tundra [OP] New Member
    2017 MGM limited
    Started my audio build, so far I have ordered JL Audio c5 and c2 components with JL XD1000.5 amp.
    What would you guys recommend, 1 JL 12tw3 or 2 JL 10tw3? I would be willing to sacrifice bass for sound clarity.
    Rica25 likes this.
  2. Feb 2, 2019 at 7:09 PM
    Rica25
    Ricardo
    Tulare
    I have always been told 10s are clearer than 12s the other difference is 12s will carry bass further on outside of vehicle if you want to rattle people's windows
  3. Feb 2, 2019 at 7:12 PM
    Rica25
    Ricardo
    Tulare
    I have one 10 inch Addictive Audio sub max wattage is 1200 and RMS power is 700 and I absolutely love it it really rumbles my truck 20190120_095827.jpg
    Y0TA PR0 likes this.
  4. Feb 2, 2019 at 7:29 PM
    Master_tundra
    2017 MGM limited
    Rica25[QUOTED] likes this.
  5. Feb 2, 2019 at 7:33 PM
    Rica25
    Ricardo
    Tulare
    Having the right amp and specially the right TUNED box is the main thing to do
    Toyotoholic likes this.
  6. Feb 2, 2019 at 7:35 PM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    Take a look at the Stereo Integrity BM MK V if you want sound quality
  7. Feb 2, 2019 at 7:42 PM
    Master_tundra
    2017 MGM limited
    Never heard of them, do you run their sub?
    Rica25 likes this.
  8. Feb 2, 2019 at 7:46 PM
    Mdjamesd
    Mdjamesd New Member
    I dont run onepersonally, yet. Shallow mount SQ sub. I first came across their subs when I was researching diy subs on a handful of hometheater forums. Every review I've read of the BM MK series gives them high praise for producing bass that's clean and blends into the soundstage instead of overpowering it
    Rica25 likes this.
  9. Feb 2, 2019 at 7:53 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm running c5's in the front c2's in the rear, hd900/5 and stealthbox with two 10tw3's. They sound absolutely amazing. You'll love them.
    Master_tundra[OP] and Rica25 like this.
  10. Feb 2, 2019 at 8:01 PM
    Master_tundra
    2017 MGM limited
    Really considering them as an option, would I have to get a custom box made for their sub?
    Rica25 likes this.
  11. Feb 2, 2019 at 8:05 PM
    Mdjamesd
    Mdjamesd New Member
  12. Feb 2, 2019 at 8:56 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Two 10's
    It will be tighter, cleaner bass. With two, you will get plenty of low, but without the mud. One twelve worked great in the gen1's center console, but still lacked overall control. You retain control three ways: 1. clean source. 2. Clean, powerful amp with output rms 120% of rated woofer (to account for loss). 3 quality woofer and enclosure.
    The larger the woofer, the greater the power required to control it. Two 10's give the best overall performance between pounding clean bass, and depth of low frequencies. A single 12 may go lower in hz but 20" (10x2) of cone area is still better than 12" when moving air (bass). JL stealth box for a gen3 is 100% best choice for our trucks, without custom building a box.
  13. Feb 2, 2019 at 8:59 PM
    Master_tundra
    2017 MGM limited
    Did you pay retail for your stealth box? Would like to get a better price, if I go that direction.
  14. Feb 3, 2019 at 7:57 AM
    Danimal86
    Daniel
    Sacramento, CA
    I searched around all over the place to try to find a better deal on the stealthbox but the best I could find is a scratch and dent from crutchfield. It had a tiny little scuff in the carpet. It was a couple hundred off.
    If you want to save some money, you could have have James at tech12volts make you a box and put the same subs in. I almost went this route, but I've had really good luck with the JL boxes in the past, I wanted to stick with it.
  15. Feb 3, 2019 at 8:00 AM
    Rica25
    Ricardo
    Tulare
    I always used to use JL audio in the early 2000s but now they are just way over priced and no longer made in USA sundown....addictive audio.....and many others just as good or better and much cheaper
  16. Feb 3, 2019 at 9:18 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    I have 2 10TW3-V4's in a custom box in my 14 CM behind the rear seats powered by a RF T1500-1db.Those things are amazing in both quality and volume.
    Rica25 likes this.
  17. Feb 4, 2019 at 4:27 AM
    niscur38
    niscur38 New Member
    Haven’t heard the JL’s but I would say two 10’s! My dual pioneer shallows sound flat out amazing vs the single subs I’ve had in other trucks.
    Rica25 likes this.
  18. Feb 20, 2019 at 5:15 PM
    Master_tundra
    2017 MGM limited
    Did you go with a sealed or ported box?
  19. Feb 20, 2019 at 5:22 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Ported.
    Rica25 likes this.
