Just hit 5k miles. Recommended maintenance?
Discussion in '3rd Gen Tundras (2022+)' started by babond, Jun 25, 2024.
  1. Jun 25, 2024 at 7:14 AM
    babond
    babond [OP] New Member
    I just hit 5,000 miles this morning. I have ToyotaCare and bought the extended warranty (10y/125,000 miles). I want this truck to run for as long as possible. Should I schedule an oil change for this week (if not, then when?) and any other services I should be getting? Would I be expected to pay out of pocket for a 5k oil change. Thank you in advance. I'm slammed this week with patients and I've got a second job in the evenings. I should've had this all figured out before I hit 5,000 miles.
  2. Jun 25, 2024 at 7:18 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Change your oil asap. Generally speaking, Turbocharged vehicles break down oil faster than N/A vehicles due to the excess heat from turbochargers. You can use your Toyota care early, at least I did.
    cmiles97 and mayan like this.
  3. Jun 25, 2024 at 7:23 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Just the oil change and personally I rotate and balance tires every 5k miles, same as oil change frequency. Tires last significantly longer doing so.
  4. Jun 25, 2024 at 7:26 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    If you have Toyota Care then you can convince your service advisor to apply the 10k OC if you don't wanna pay now. I stick to 5k OCI and my oil looks beat to hell every time on my commute my oil temp gets to 212F. Minimum you need is tire rotation and oil filter and fluid change. See the attached PDF it could come in handy in the future.
    Last dealer overfilled oil but this is my oil at 25k miles last changed at 20k.
    Data during commute.
    ZappBrannigan and Dylan 556 like this.
  5. Jun 25, 2024 at 8:52 AM
    babond
    Good deal. I've set an appointment for Friday at 3:30. Looks like I need an oil change, filter change, and tire rotation. Once my 2 years of Toyota care is finished, can I maintain my warranty with doing my oil changes? I don't want to do anything to jeopardize the extended warranty. Absolutely love this truck, but terrified of an expensive engine failure that I'd have to pay out of pocket.
  6. Jun 25, 2024 at 9:37 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    I had to force a service adviser to do a 10k at 5k miles as well.
    You have 10 year/125,000 miles Toyota backed warranty. You shouldn't have to worry about it. Go by the owner's manual and document that you followed it.
    Just ask them to take the debris out of the motor during this one and you are good to go! J/K.
  7. Jun 25, 2024 at 9:55 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    Doesn't your Toyota Care include the oil change and tire rotation at first 5k miles at no charge. Air filters are extra.
  8. Jun 25, 2024 at 10:11 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Have them absolutely change it now. They'll do it every 10k per the new parameters, but I would get familiar with how to do it yourself and change it every 5k. It's not hard, and oil is cheap compared to your motor. I write on my receipts when I buy oil and filters and what mileage they were used for and put everything in my truck's service folder. That way you have your proof that you can use to establish the oil was changed and when (for any questions if warranty issues should arise). If you want to keep the truck running a long time, change the oil often. There was never a case of too clean of oil causing damage to a motor, but there sure are cases of the opposite!!! Good luck. And rotate tires every time you change the oil (5k)
  9. Jun 25, 2024 at 10:20 AM
    cmiles97
    cmiles97 New Member
    XP package
    If you want to keep it long term, this is good.
    If you flip them every 3 to 4 years for the latest and greatest, do what Toyota expects.
    On a side note as someone who looks at way too many used vehicles, I wouldn't buy one unless I see 5,000 mile or earlier documented oil changes.
  10. Jun 25, 2024 at 10:43 AM
    737fixer
    737fixer New Member
    I'm going to take backlash on this, but break-in changes I believe are a must. For an easy extra if you can do it yourself as its incredibly easy maintenance is the rear differential. Throughout this forum you will see changes done anywhere from 1000 - 100,000 miles and they all have the same response on how dirty the rear differential oil is and the magnetic plug is covered in debris. Then when the change is done again in 30,000 miles, they can't believe how clean it is. The vast majority of the debris occurred in the first couple of thousand miles and in my opinion it's nice to get it out of there. I guarantee you will freak at how dirty your oil and plug are in a brand new truck but then wait three more years and do it again and it will be nowhere near as dirty. I would do all your gear oils but if you're just looking for an easy bit of maintenance the rear differential is easy and takes the brunt of abuse.
    23 Platinum likes this.
  11. Jun 25, 2024 at 11:39 AM
    Dylan 556
    Dylan 556 New Member
    2024 White Limited TRD OR
    What app is that?
    licensedshark and dJunior like this.
  12. Jun 25, 2024 at 11:42 AM
    23 Platinum
    23 Platinum 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    At 5,000 miles I had my 3rd set of oil in mine. Brainiacs on this forum made fun of me for it.
  13. Jun 25, 2024 at 11:46 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    :thumbsup: Your money/maint. investment, not theirs.
    eddiefromcali likes this.
  14. Jun 25, 2024 at 11:49 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I was on #2...not sure if it helped or not but I was happy I did it and thats all that matters.
  15. Jun 25, 2024 at 12:06 PM
    ARB1977
    ARB1977 New Member
    Anthony
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I got suckered in the up to 85K maintenance plan. So my plan is to do the 5K oil change myself. Take it in so Toyota can do their 5K stuff. 10K let the dealer do it.
    Toyotoholic likes this.
  16. Jun 25, 2024 at 12:22 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Replace main bearings.
  17. Jun 25, 2024 at 1:32 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Hahaha
    Me too
    500 - 1000 - 5000 + every 5k
    23 Platinum[QUOTED] likes this.
  18. Jun 25, 2024 at 2:56 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I’ve done this move as well for vehicles that came with oil changes at ridiculous intervals. Every so often I used to bring them in just so there’s some documentation if I ever sold the car.
    ARB1977[QUOTED] likes this.
  19. Jun 25, 2024 at 3:39 PM
    Retired...finally
    Tell the dealer your driving qualifies as rough or severe service. Since I tow a lot the dealer was forced to do my 10K service at 5K. You're getting the same amount of freebees but using them up in half the miles.
  20. Jun 25, 2024 at 6:01 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    Go a step further and take a picture of your receipts and make a folder for them. The receipts nowadays can get washed out in heat and can't be read.
  21. Jun 25, 2024 at 6:06 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I have a digital album of everything too! Lol
    It's easy to reference quickly and the paper folder is the hard evidence! I update the oil changes and rotations on my Carfax too. That way is it on the report should someone pull it.
    dJunior and Rockpig[QUOTED] like this.
  22. Jun 25, 2024 at 8:45 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Dealer reached out to me to schedule first service at 5,000 miles or 6 months. Since I had rear differential replaced under warranty at 1,100 miles had them change rear differential fluid along with oil and filter even though my odometer was only 2,400 miles. Rear differential fluid was handled under warranty and oil/filter charged to 10,000 mile service. No hassle from Service Advisor.
    Best news was no metal filings!
  23. Jun 25, 2024 at 9:03 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    …Yet.
    :D
  24. Jun 26, 2024 at 4:10 AM
    mayan
    Mayan
    DFW
    OBD Fusion but it’s doesn’t fully support 3rd gen tundra yet.
    Dylan 556[QUOTED] likes this.
  25. Jun 26, 2024 at 4:30 AM
    dJunior
    dJunior New Member
    CT
    Yeah i buy my oil off Amazon so DL the reciepts into google drive and have a google sheet to keep tabs on all "stuff" Just found out about the Carfax stuff as well so will add that to the endless updating.
    The oil changes arent awful to DIY- especially with a fumoto valve.
    If you want extra nerd points send out a sample to Blackstone Labs or some other company for testing. Doesnt hurt and gives an idea of what is happening "in there"
    Toyotoholic[QUOTED] likes this.
