Just need clarification that these oem wheels will fit my 21 tundra
Discussion in 'Wheels & Tires' started by CanTundra, Nov 4, 2022.
  1. Nov 4, 2022 at 7:46 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    Hi guys I have a 2021 tundra trd off road with the black polish type of rims 18”.
    I am shopping for winter rims and was thinking to go with the standard silver aluminum rims since I think they will be better with the salt on the roads . I just want to be sure they are perfect fit and use same bolts etc as my trd off road
    thank you
    ElNopal likes this.
  2. Nov 4, 2022 at 7:54 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Same
    Tripleconpanna likes this.
  3. Nov 4, 2022 at 10:28 PM
    Thadoggfather
    Thadoggfather New Member
    21 plat
    Yes they’ll work. Good luck with tpms if you’re not transferring them!
  4. Nov 4, 2022 at 11:13 PM
    CanTundra
    The silver set offered to me are complete with oem tpms sensors
    Thadoggfather likes this.
  5. Nov 5, 2022 at 12:11 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    2018 or 19 to 21 use different sensors if I'm not mistaking. The year truck they come off of is important if you want to be able to use it. Otherwise you'll have to buy new sensors.
  6. Nov 5, 2022 at 12:17 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Yes those will work on a 2021, I have used those rims on a 2017 and 2021. The offset is 60mm so anything wider than a 275mm tire can get too tight. The ideal stock sized winter tire (32”) is 255/70r18 based on my experience instead of the usual 275/65r18 for summer. When I sold my 2017 I kept the winter tires/rims and the tpms worked on the 2021 without issue, so I would think any tpms on the 2nd gen “should” work.
