Just purchased 2006 Tundra need Suspension info
Discussion in 'Suspension' started by 06TundraMom, Aug 19, 2021.
  1. Aug 19, 2021 at 7:33 AM
    06TundraMom
    06TundraMom [OP] New Member
    2006 Tundra V8
    None
    Hi! I just purchased a 2006 Tundra 191,000. When driving home it seems to have an issue on the front passenger side. If you hit a bump on the right front wheel it is trying to pull the truck to the right as it bounces back up. It looks like there has been new stuff put on, but I have no clue what would be causing this. Any clues? Any info would be helpful. It was as is. Thank you
    YardBird likes this.
  2. Aug 19, 2021 at 7:35 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I hope someone here can help with this issue . . .
    06TundraMom[OP] likes this.
  3. Aug 19, 2021 at 9:29 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    could be something as simple as needing alignment. If alignment is off it can cause bump steer. But since you said there are many new parts on the truck, something could be installed incorrectly or there could be other worn parts up front somewhere. If you have a front sway bar, check its condition, especially the end links. One could be broken. Look for any bad bushing, leaking shocks up front.
    Drive it around some, hit some bumps, listen for any odd noises. If no noises and the truck is otherwise driving and tracking well, other than the bump steer, I would get the front end alignment done and see if that resolves your issue.
  4. Aug 19, 2021 at 9:31 AM
    frichco228
    and list more about your truck, is it stock or lifted?
  5. Aug 19, 2021 at 4:34 PM
    06TundraMom
    2006 Tundra V8
    None
    frichco228, It is a stock truck. I am adding photo's. If more needed let me know. Does anything look abnormal?
  6. Aug 19, 2021 at 5:16 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal. Looks like you got new coilovers and links. You're not going to like this suggestion, but you should probably take it to a mechanic and ask for a full inspection. 1st gens have a frame rust recall, and I'm seeing evidence of some pretty serious corrosion. It'd probably be worth your while to get a full lookover.
  7. Aug 19, 2021 at 5:39 PM
    frichco228
    Good advice above. in the first pic, that cv shaft looks pretty degraded, rust hit it pretty hard, but I dont think it would cause bump steer. I am going to stick with my first thought- they recently replaced coilovers, so my guess is that they never had the truck aligned after....and that is required.
    Take it to a trusted shop, have them give it a look over to see if anything else needs immediate attention and do a front end alignment.
    Gravy and 06TundraMom[OP] like this.
  8. Aug 19, 2021 at 6:42 PM
    06TundraMom
    2006 Tundra V8
    None
    Thank you for the info. I guess I will start with Toyota to check it out. I bought it at a used car place. I did get a 2yr warranty, but I am not seeing "frame" being covered. I will update as soon as I get it aligned.
  9. Aug 20, 2021 at 10:07 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That's not a stock bolt on the rt side lower shock mount. I bet it's undersized and has slop. Could be photo perspective, but further evidence is how low the shock end appears to sit in relation to the mount.
    dbittle and AZBoatHauler like this.
  10. Aug 20, 2021 at 10:21 AM
    AZBoatHauler
    So.Arizona
    Good eye.
    dbittle and alb1k[QUOTED] like this.
  11. Aug 20, 2021 at 10:41 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    If those are the Monroe shocks, they wear out very quickly. My truck did the same thing because one of them wouldn't extend all the way.
  12. Aug 25, 2021 at 2:24 PM
    06TundraMom
    2006 Tundra V8
    None
  13. Aug 25, 2021 at 2:26 PM
    06TundraMom
    2006 Tundra V8
    None
    Frame is good thank goodness.
    Gravy likes this.
  14. Aug 25, 2021 at 2:27 PM
    06TundraMom
    2006 Tundra V8
    None
    I have no clue
  15. Aug 25, 2021 at 2:31 PM
    06TundraMom
    2006 Tundra V8
    None
    I think you are talking about pic#4??? Can you circle the place you are saying where it sits plz and thank you.
  16. Aug 25, 2021 at 2:36 PM
    alb1k
    Left Coast
    It's good
  17. Aug 25, 2021 at 2:51 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    You might need to replace the rack and pinion bushings. I replaced mine when I had an ‘06 Tundra. I used energy suspension poly bushings instead of oem. Check to see how yours look (i.e. torn/cracking). Could also be a lower ball joint if not these bushings.
    here’s a helpful vid link I found on the bushings being replaced; I didn’t mess with my tie rods as they were fine:
    https://m.youtube.com/watch?v=-up2ivctxzM
    Pics were after I replaced (they’re the red poly bushings when looking at the photos)
  18. Aug 25, 2021 at 2:58 PM
    06TundraMom
    2006 Tundra V8
    None
    ***You are the winner*** The Toe and cam are not at the correct settings. Getting new tires will help too.
    frichco228[QUOTED], Gravy and alb1k like this.
  19. Aug 25, 2021 at 3:01 PM
    06TundraMom
    2006 Tundra V8
    None
    Gotcha! I see the flat part on one of the bolts. I was thinking pic 4 had too long of screws too.
  20. Aug 25, 2021 at 3:21 PM
    alb1k
    Left Coast
    It's good
    glad you figured it out. that poly bushings looks like a great idea for me anyway when I replace the rack and pinion @1P7R9O4
    1P7R9O4 likes this.
  21. Aug 25, 2021 at 4:12 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Fortunately, caught in time that I didn’t need to replace the actual rack and pinion, just the bushings. I had 1 or two bushings that were pretty worn/split, so just replaced all 3 with the poly bushing kit. Ran perfectly afterwards.
