K N drop in air filter
Discussion in '2.5 Gen Tundras (2014-2021)' started by Steplift20, Nov 8, 2024.
  1. Nov 8, 2024 at 4:47 PM
    Steplift20
    Steplift20 [OP] New Member
    2018 Tundra
    Do you think it’s worth it? A K N drop in air filter that rep,aces the oem in the air filter box
    I heard it could cause problems cause more small particles get thru but I see a lot of cars and trucks with it.
    What do you think ?
  2. Nov 8, 2024 at 4:53 PM
    The K&N is fine if it's not over-oiled. The AFE Dry and the TRD filters are popular as well. I ran a TRD in mine until recently.
    HulkSmurf14 likes this.
  3. Nov 8, 2024 at 5:21 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    I agree with what @Tundra234 said. It's a good product so long as you don't over oil it. They are meant to stop the smaller particles and debris from getting through so you'll want to keep it clean and LIGHTLY oiled often.
    Personally though, I'd stay away from oiled filters as the oil could dirty up the MAF sensor. I used to run oiled k&n on my Taco for years and I had issues with my MAF sensor.
    If you're in So Cal, I have a brand new unopened AFE dry drop in filter I'd be willing to part with.
    Tundra234 likes this.
  4. Nov 8, 2024 at 5:43 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    One came with my supercharger and went straight into the garbage and a Wix filter in its place. They let too much fine particulates through and will likely damage the engine over time. In a low mile race situation it will increase airflow but I would not recommend in a long term vehicle.
    For evidence watch Engineering Explained or Project Farms testing of air filters including KandN.
    Leek128, Gene_in_FL, reywcms and 3 others like this.
  5. Nov 8, 2024 at 5:45 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    KN is worse filtration, no matter what. Only way you add power with a filter is if it does it's job worse. That said if u want power, go for it.
    HulkSmurf14 and TacomaTRD4x402 like this.
  6. Nov 8, 2024 at 5:53 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    AFE or Wix...if you want real improvement, look into the SABM (Stock Air Box Mod) and a TRD air accelerator...
  7. Nov 8, 2024 at 7:58 PM
    Steplift20
    2018 Tundra
    Thanks to everyone who replied. Let me tell you what I found out.
    I was watching project farm on you tube and he just happened to test a bunch of air filters and one was K N. And a Wix the test confirmed that the Wix was the best at protecting from small particles getting thru and the K N was the worst. It just happened that I ran across that after I posted. The timing was perfect. So. I will get a Wix air filter and leave the K N on the shelf. You did get a very little increase in hp but if you want your 3ngine to last Wix is the way to go.
  8. Nov 8, 2024 at 8:27 PM
    HulkSmurf14
    2014 Tundra Limited
    Honestly tho, check out the SABM... paired with the Wix, you're actually getting more than just sound!
    TacomaTRD4x402 likes this.
  9. Nov 8, 2024 at 8:30 PM
    TacomaTRD4x402
    Southern California
    Does WIX sell a washable/reusable filter? I thought you were looking for one to buy that you can wash and reuse like the K&N. WIX is a disposable filter that you discard when dirty.
  10. Nov 8, 2024 at 8:33 PM
    HulkSmurf14
    2014 Tundra Limited
    Nope... use and lose
  11. Nov 10, 2024 at 2:21 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I have the afe dry filter, i like it. I kept the oem one as spare for when the afe needs cleaning i wont have down time.
  12. Nov 10, 2024 at 3:39 PM
    Steplift20
    2018 Tundra
  13. Nov 10, 2024 at 3:59 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    IMHO, K&N oiled filters are garbage. Too much oil and it screws up sensors. Not enough (or even perfectly oiled) and they don't filter worth a crap.
    MadMaxCanon likes this.
  14. Nov 10, 2024 at 4:47 PM
    TacomaTRD4x402
    Southern California
    I think you quoted the wrong person. What @HulkSmurf14 was referring to is SABM(Stock Air Box Mod). It's where you drill a hole in the side of your stock airbox and in your fender to allow twice the amount of air intake from your fender. Do a search for it and you'll find several posts about it.
  15. Nov 10, 2024 at 7:17 PM
    Leek128
    Leek128 New Member
    Bucks PA
    I recently ditched the k&n/TRD oiled drop in filter for OEM paper filter. And honestly can't tell a difference.
  16. Nov 11, 2024 at 5:32 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    What are you expecting to achieve over stock? You can buy plenty of stock filters for the price of a K&N, the stock has been proven to filter properly and how often are you driving around at WOT to think you'll notice any power difference? Wanna test it, go remove your air filter and drive around the block, you won't notice any difference.
  17. Nov 11, 2024 at 6:30 AM
    Steplift20
    2018 Tundra
    I usually drive a steady 95 mph. On the parkway and route 80. Sometimes I hit 102 very seldom do it drive at the posted speed limit of 65. I never actually floored the pedal , how fast is the top end?
  18. Nov 11, 2024 at 1:09 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Dear Lord
