KC | Flex LED Lights - Extreme Performance & Modular
Discussion in 'Lighting' started by Taylor @KC HiLiTES, Nov 6, 2018.
  1. Nov 6, 2018 at 1:31 PM
    Taylor @KC HiLiTES
    Taylor @KC HiLiTES [OP] New Member
    Taylor
    The KC HiLiTES Flex LED lights are uniquely designed to be able to be customized and configured in a huge variety of ways, leading to the origin of their name. These lights are modular and expandable, giving you the option of building left, right, up, or down to create a light that will fit and look exactly how YOU want it to. Light up what you want to see with the spot or spread beam patterns. Then, add in even further personalization with different colored bezel options and clear and amber covers, and the possibilities become unlimited.
    OPTICAL PERFORMANCE
    Engineered by KC using precision injected reflector optics to give you race-level performance light output and optical clarity.
    RACE-TESTED CONSTRUCTION
    Developed and proven under the most demanding physical and optical conditions by our DIRT TRIBE teams of athletes at races like the BAJA 1000.
    ELECTRONIC STABILITY
    Integrated EMI and RMI blocking and filtering that provides interference transparency and PCB electronics stability.
    PASS-THROUGH POWER BUS
    Patented power back-plane that streamlines your wiring as you link or stack FLEX LED configurations simplifying wiring setups.
    Light Options:
    Flex Features & Information:
    • LED Source: CREE XM-L2 U2
    • LED Color: 5700K
    • IP Rating: IP68
    • Die-Cast Aluminum Housing
    Flex Accessories:
    • Bezels Kits
      • Diecast Aluminum with ED Coated Paint
      • Red, Blue, Black, Gold
    • Flex Shield
      • Laser cut Lexan hard-coated lens
      • Clear or Amber
    • Linker Kits
      • Diecast Linker plate, 12GA Power wire and Stainless Steel Allen Bolts
    Useful links:
    If you have any questions about this product or any others that we offer, please let me know!
    Flex Specs:
    Two single Flex LEDs
    iHacker likes this.
