Kenwood DMX1057XR backup camera issue
Discussion in 'Audio & Video' started by TundraWA2017, Oct 4, 2024.
  1. Oct 4, 2024 at 9:25 AM
    TundraWA2017
    TundraWA2017 [OP] Red Lobster anyone?
    WA State
    2017 Silver Sky SR5 TRD OR CM
    Hello all,
    Just recently installed the 1057xr with a maestro rr and the tech12volts system (amazing btw, highly recommended).
    Everything works except the backup camera. The lines show up when I put it in reverse but no picture. I connected the RCA from the maestro harness to the RCA from the head unit. Anyone have any tips? Thank you.
  2. Oct 4, 2024 at 11:22 AM
    SD Surfer
    Bruce
    So Cal
    Got a meter? Sounds like maybe the camera isn't getting power when you put it in reverse.
    Not sure if yours is the same but on my '19 I get two sets of lines, one from Toyota and one set from Kenwood... The Toyota are built in, the ones from the HU I can toggle on/off. If you're only getting one set on your screen something is either not connected or not getting power.
    bulldog93 and TundraWA2017[OP] like this.
  3. Oct 7, 2024 at 8:13 PM
    TundraWA2017
    WA State
    Update: Took it to a shop. I missed a harness but I did not see that step on the maestro instructions.
    bulldog93 and SD Surfer like this.
  4. Oct 7, 2024 at 10:46 PM
    SD Surfer
    Bruce
    So Cal
    Glad you got it figured out.
    That's why I just paid the professionals way too much to do my install, I just don't have the patience or motivation for this stuff anymore. Plus, as I get less motivated and patient, electronics get more complicated.
