Key Fob and Key Programming
Discussion in '2.5 Gen Tundras (2014-2021)' started by Skiggidy, Sep 30, 2019.
  1. Sep 30, 2019 at 10:01 AM
    Skiggidy
    Skiggidy [OP] New Member
    Scott
    Wichita Falls
    2015 1794 CM
    I have tried searching and still not sure if I have found the right answer. I just purchased a 2015 1794 Tundra. It only came with one key, and I would like to add another key and fob. I have access to a lock shop, so I can cut my own key just fine, the problem is programming. I have read that this can be done with techstream, and that is where I am getting confused. Do i have to have the version 2 cable in order to do this, or will the version 1 cables work. And I will be doing this from a windows 10 laptop with 64bit, so do I need to purchase a certain one for that to work? Again sorry for the dumb questions.
  2. Oct 1, 2019 at 3:34 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I purchased a flip key/fob from Amazon for my 2015 G key after one set was lost. I called a mobile lock smith and he was able to cut and program it for $65. I know that you are looking for programming help, but just wanted to throw out my situation. Good luck
    Skiggidy[OP] likes this.
  3. Oct 1, 2019 at 3:51 PM
    Welcome from NY.
    Someone will chime in with the answer.
  4. Oct 1, 2019 at 3:59 PM
    DireWolf
    DireWolf The Dark Lord - Tundra Owner
    North East Florida
    2016 Dark Gray Tundra SR5 (MGM)
    none
  5. Oct 1, 2019 at 5:27 PM
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    From the research I did a V1 cable will work for this. I could never get techstream to work on my 64bit, tried those reg edits and all that. In the end I had a locksmith program it for me
  6. Oct 1, 2019 at 8:02 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    I had my (2) keys and remote plus (1) valet key and Cut/programmed (2) FOB at dealership for $130. Max keys is (5) for vehicle
    Brownsfanhere and Skiggidy[OP] like this.
  7. Oct 1, 2019 at 8:05 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    I actually have had key cut and then program g key through techstream myself. V1 cable should work. That is what I have.
  8. Oct 1, 2019 at 10:07 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Where did you get your key cut?
  9. Oct 1, 2019 at 10:56 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    At an outside kiosk in a strip mall in Valencia. Lol I think he charged me 8 bucks.
  10. Oct 2, 2019 at 1:39 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Sub’d
  11. Oct 2, 2019 at 8:21 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    I did it about 2 years ago and it was a two step process. Registration of Key and then registration of key fob. I believe i used both these videos for guidance. It's been a long time:
    NHSailor likes this.
  12. Oct 2, 2019 at 8:26 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Do you mind programming mine? I’m in Northridge and I can drive to you
  13. Oct 2, 2019 at 8:28 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Of course not Ian. PM me brother!
    BBTundra likes this.
  14. Oct 2, 2019 at 11:48 AM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    I have taken keys to my local dealer parts department 3 seperate times and they have cut them for free assuming im going to go to service and pay a bunch of money to have the chip programmed....
  15. Oct 2, 2019 at 9:19 PM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    Rear LED, inside LED
    I am on the same boat as you are since I have the windows 10 with 64 bit. I really just need the program since I have the cable already. Hopefully someone answers this question a little better.
  16. Oct 3, 2019 at 6:07 PM
    Skiggidy
    Scott
    Wichita Falls
    2015 1794 CM
    Well I ended up purchasing a cable on Amazon. Cut the key myself, and literally took me 5 minutes with techstream to program. Worked great!
    https://www.amazon.com/gp/product/B078VKM1G3/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    I used an older laptop not connected to the internet because I have read some things that seem shady about the software. I installed on a 64bit windows 10 machine and had no issues.
    I purchased the truck used, so it was actually nice being able to delete my missing fobs and key that the last person kept.
    I ended up purchasing cable, software, “key and fob” All cheaper then locksmith was going to charge for single key.
    Thanks again for all the help guys.
  17. Oct 3, 2019 at 6:14 PM
    Skiggidy
    Scott
    Wichita Falls
    2015 1794 CM
    thanks! That’s what I ended up doing and worked great. I actually have a key cutting machine in my office so it worked perfectly.
    tinman10101[QUOTED] likes this.
  18. Oct 3, 2019 at 6:16 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Great so the seller gave you instructions on how to install on W10 x64? Glad it worked :thumbsup:
  19. Oct 3, 2019 at 6:22 PM
    Skiggidy
    Scott
    Wichita Falls
    2015 1794 CM
    Yeah, they provided decent instructions located on the zip file. Just had to make sure to install the 64bit driver first, then install software. Honestly was a 5 minute install.
    tinman10101 likes this.
  20. Oct 3, 2019 at 6:27 PM
    Skiggidy
    Scott
    Wichita Falls
    2015 1794 CM
  21. Oct 6, 2019 at 8:45 PM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    I just installed this and it worked great since I was able to read everything on the truck. The key won't program though and it keeps giving me an error code. I was able to program other stuff but just the key programming won't work and I was wondering if anyone has had any other issues with it?
  22. Oct 6, 2019 at 9:08 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Is it a g key? Are you having trouble with the g key or fob?
  23. Oct 6, 2019 at 9:14 PM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    Yeah I believe the key is a G key and it’s the key programming I’m having trouble with.
  24. Oct 6, 2019 at 9:22 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Hmm that's weird. It walks you through it in techstream. Dud you get the g key from a reliable source?
  25. Oct 6, 2019 at 9:26 PM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    I got it from ebay and have contacted the seller hopefully he replies, Did you buy a key from a reliable source and did yours work?
  26. Oct 6, 2019 at 10:22 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Yes got it from eBay too but I know there are crappy sellers. Just check the reviews and more importantly amount of reviews. Hopefully he replies.
    porkitt likes this.
  27. Oct 7, 2019 at 7:58 PM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    Do you happen to have the link to the key that you got since mine might just be a crappy one, Thanks I really appreciate it.
  28. Oct 7, 2019 at 10:09 PM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    I get this error when I try to program the key FD1C44D5-2AD3-4913-8B17-3382E3CDB198.jpg
  29. Oct 8, 2019 at 8:48 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    I got it from this vendor on ebay: https://www.ebay.com/usr/remotez4less ... perhaps message him. Hope this helps.
  30. Oct 16, 2019 at 10:28 AM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    I order that key and hopefully it programs. Thanks for all the help.
