King 2.5 Springs - Need 650Lb
Discussion in 'Suspension' started by khens12, Mar 19, 2019.
  1. Mar 19, 2019 at 12:12 PM
    khens12
    khens12 [OP] New Member
    Kevin
    2018 Tundra SR5 Off-Road 4x4
    - Icon Billet UCA - King 2.5 Coilovers - King 2.0 “Shorty” Bumpstops
    Hey guys,
    Need some input here. I’ve had my kings installed for +-5000 miles and feel that the 600 lb spring isn’t enough to achieve the lift I’m looking for out of the front. I’ll post a photo of the compression on the springs but I think it’s too much. What is yalls input?
    Ride just feels stiff/harsh. Let me have the good/bad/ugly about what I’m trying to do here.
    Driver:
    PAX:
    Black Wolf likes this.
  2. Mar 19, 2019 at 12:42 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Swap out the King coils for some quality coils like Eibach.
    I gotta say, I was very happy with 600lb coils on my old ADS setup! Achieved the lift I wanted without excessive preload.
    Black Wolf and khens12[OP] like this.
  3. Mar 19, 2019 at 12:51 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Kings are funny, once you go past a certain spot they ride shitty, sweet spot is how they came out of the box which how mine are for a leveled stance. Got over 30k miles no problems rides plush on the street and soft mobbing the desert. 600lbs springs are softer and give more flex, I’m not sure why yours ride stiff since you have aftermarket UCA’s as well. Lower the coilovers and see how it feels after.
  4. Mar 19, 2019 at 1:39 PM
    3mxdivr
    3mxdivr New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    If you go up to 700lbs springs you will have less preload, but probably as stiff.
    Black Wolf, 14burrito and TheBeast like this.
  5. Mar 19, 2019 at 1:41 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    As Oliver said get Eibachs
    Bannock452 and 14burrito like this.
  6. Mar 19, 2019 at 1:42 PM
    blizz86
    blizz86 New Member
    What psi are your tires at?
  7. Mar 19, 2019 at 3:28 PM
    khens12
    Kevin
    I know the ADS come with them so that was my exact thought. Do you know the specs for those springs that I could get direct through Eibach?
  8. Mar 19, 2019 at 3:31 PM
    khens12
    Kevin
    I’ve got them set when cool at 34 but after it heats up they’re up to 39. I know i could stay more in too if this to assist in the ride quality.
    I was just curious/wondering if the preload amount that they’re currently set at is “too much” or is that still acceptable.
  9. Mar 19, 2019 at 3:33 PM
    TheBeast The Beach
    I run about the same. 13 ish driver and stock King passenger i.e 8. have to compensate for Tundra lean.
    khens12[OP] likes this.
  10. Mar 19, 2019 at 5:03 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  11. Mar 19, 2019 at 8:49 PM
    khens12
    Kevin
    Do you notice any ride quality being sacrificed?
    I’m in the process of deciding on the rear end set up (MCM Bypass/Deavers or King 3.0’s). If I go with the ADS rears I’ll most likely end up swapping the front to ADS 3.0’s
  12. Mar 19, 2019 at 9:00 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Sorry I don't off-hand, my setup has switched to 3.0s and I no longer have the old setup to look at.
  13. Mar 19, 2019 at 9:02 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I lied, found pic
    1600.300.0600
    16" 3" D 600lb
  14. Mar 19, 2019 at 9:03 PM
    khens12
    Kevin
    No worries - I’m strongly considering the switch to 3.0 ADS up front.
  15. Mar 20, 2019 at 9:06 AM
    blizz86
    blizz86 New Member
    i have about 11 threads showing and its pretty cushy. do you have your front sway bar in?
  16. Mar 20, 2019 at 10:05 AM
    khens12
    Kevin
    I’ve got the seat bar deleted. Last I counted I’m at 13 driver and like 9-10 passenger.
  17. Mar 20, 2019 at 11:01 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
  18. Mar 20, 2019 at 4:42 PM
    khens12
    Kevin
    Thank you for this! I will be looking into changing out the springs.
  19. Mar 20, 2019 at 4:50 PM
    Sorry...temporary derail...I'm considering removing my OEM sway bar... have OME coilovers with winch/bumper. I see here that several have removed it. I go off road a lot here in CO on crappy old mining roads. What can I expect? Sorry OP.....
    reelcracker likes this.
  20. Mar 20, 2019 at 4:52 PM
    GiantsFanDan
    I ran with sway bar for about 4 months and then took it off. I daily drive my truck and I'm okay with them off, but you can tell they have been removed.
  21. Mar 20, 2019 at 4:57 PM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    Dude I would say you have those cranked down too much also. I had 700# coils on my kings 2.5 with resi's, on my tacoma cranked all the way up^ and they gave me a solid 2.5 inch lift. Then i put an ARB bumper and winch on the front and they settled to a solid 2. I would without a doubt go with a minimum 650# coil and set it at zero to about a half at the most. that should still give you a nice ride and give you lift. jmo.
  22. Mar 20, 2019 at 4:58 PM
    reelcracker
    Farva
    2018 off-road d/c
    sway bars suck.
  23. Mar 20, 2019 at 5:09 PM
    khens12
    Kevin
    That was my thought too. I thought it looked like a lot of preload initially
    reelcracker[QUOTED] likes this.
  24. Mar 20, 2019 at 5:12 PM
    reelcracker
    Farva
    2018 off-road d/c
    yup. I did the same thing with my kings at first and they rode hooooorrrrible. I was ready to send them back when a toyota tech explained to me what an idiot I am. The light bulb went off and I fixed it, But yeah I had my Kings cranked down a ton and was like WTF...
    Also, have heard nothing but great things about ADS!
  25. Mar 20, 2019 at 5:28 PM
    khens12
    Kevin
    Did you make the jump to 650’s?
  26. Mar 20, 2019 at 6:35 PM
    Thanks Dan.
    GiantsFanDan[QUOTED] likes this.
  27. Mar 20, 2019 at 8:23 PM
    TheBeast The Beach
    @Grey Wolf
    just don't take any corners too quick. the only time I think it would be useful to have the front sway bar is emergency swerving on the freeway like trying to avoid something. I think you might flip the truck if no sway bar.
    tagging @Vizsla for his input as he had a good story.
  28. Mar 21, 2019 at 4:51 AM
    reelcracker
    Farva
    2018 off-road d/c
    I actually went to 700# and put on and ARB.
  29. Mar 21, 2019 at 6:44 AM
    blizz86
    blizz86 New Member
    You can expect better articulation and not as much side to side jarring when you're going over uneven surfaces and large bumps. At speed you'll notice a little bit more body roll. I can still take freeway off-ramps that do nearly a full circle ~30-35mph without any hesitation. As long as you're paying attention on roads you shouldnt really be paranoid about flipping the truck.
  30. Sep 21, 2021 at 9:44 PM
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    Since two years have passed since you posted this, I assume you learned that 2.5” springs don’t fit on a 2.5” shock. You need 3” springs. Too much lift will cause a terrible ride quality. you ideally want the shock sitting mid stroke for the best ride. This gives you equal travel in both directions. Do you have the extended travel Kings? I hope since you have the nice UCAs. You can convert your shock if you didn’t order the extended travel option.
