KYB Top Hat w/ 6112?
Discussion in 'Suspension' started by Stocky Balboa, Nov 4, 2019.
  1. Nov 4, 2019 at 12:27 PM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Just ordered my 6112’s and I see folks mentioning adding KYB Top Hats.
    :newbie alert :
    Is this a must do?
    Why and what do they do?
    ‘18 W/20k miles
    Thanks
  2. Nov 4, 2019 at 12:36 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Having a secondary top hat is necessary if you intend to leave your stockers intact (coil & shock still attached). Lots of folks find this makes the stockers easier to resell.
    If you don’t have a secondary top hat (like KYB) to build the 6112s, you have to break down the stockers to get the stock top hat off in order to build the 6112s.
    Stocky Balboa[OP] likes this.
  3. Nov 4, 2019 at 12:37 PM
    AZBoatHauler
    So.Arizona
    Not a must do. From the factory, the 6112s reuse the top hat of your existing stock shock meaning once you get the stock shock out of the truck you need to move the top hat parts to the new shock. Getting a new top hat allows you to fully assemble the 6112 before you pull out the old shock making your install a little quicker/easier.
    plumber802 and Stocky Balboa[OP] like this.
  4. Nov 4, 2019 at 1:07 PM
    Stocky Balboa
    OC , CA
    Ahhh makes sense now. Thank you! I’ll go ahead and pickup the KYBs
    georgiey22 likes this.
  5. Nov 4, 2019 at 2:58 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    It’s easier to purchase the KYB top hats. Note: 1 top hat per package, so you need to order 2. I purchased these KYB’s on Amazon for $39 all in.
  6. Jul 1, 2021 at 5:54 PM
    Fyshhead
    Fyshhead New Member
    Mark
    Folsom
    2021 Tundra Limited MGM TRD Off Road DC
    Vehicle Modifications:
    What’s a good resale price on the stock Bilstein/spring assembly? Only 1,000 miles on them. Installing 6112’s
  7. Jul 1, 2021 at 7:06 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Depends how fast you want to get rid of them...$300 will go slow, $100 much faster...you didn't buy the Billy's with the thought of selling your OEM...just pay it forward to folk...at least, that's my intention when I post mine up...I don't need them taking up shop space and I don't intend on going back to stock...
    RangerBP likes this.
  8. Jul 1, 2021 at 7:51 PM
    Fyshhead
    Fyshhead New Member
    Mark
    Folsom
    Probably put them up on offer up locally, shipping would probably be a lot do to weight.
  9. Jul 1, 2021 at 8:05 PM
    RangerBP
    I gave mine away because they’re 12/$.10. See @HulkSmurf14 ‘s post above for sound advice.
    HulkSmurf14 likes this.
