Lacquer Thinner in Fuel
Discussion in '1st Gen Tundras (2000-2006)' started by sylobeg, Jun 8, 2022.
  1. Jun 8, 2022 at 9:43 AM
    sylobeg
    sylobeg [OP] New Member
    Hey there, just wondering if any of you have heard of Lacquer thinner in your fuel to clean the catalytic converter. I saw it on Youtube so it must be valid . :rolleyes:
    My Limp mode went on and I thought it was a clogged cat. I reset it by taking the battery off, which set off an old alarm that I had to remove (another thread).
    Anyway, is running good now so cat must be good? I suspect it was a loose OIL cap, almost ready to fall out.
    But, he has 220k miles, 2005, so I figured it would help.
    Thoughts?
  2. Jun 8, 2022 at 9:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    NO on adding that stuff to your gas.
    BravoDeltaRomeo and KNABORES like this.
  3. Jun 8, 2022 at 9:55 AM
    Loose oil cap wouldn't cause limp mode that I know of. I would be leery of adding the lacquer thinner to my fuel, but there are numerous references to it being effective. There are also numerous off the shelf chemicals designed for this. What codes were being thrown when the truck went into limp mode? Those codes will point you towards the right solutions. The SAIS is the most common reason discussed on here.
    BravoDeltaRomeo likes this.
  4. Jun 8, 2022 at 10:33 AM
    I've heard of using kerosene in engine oil to reduce varnish, but never seen legit evidence adding lacquer thinner in gasoline will clean your cats.
    On a quick internet search using the big G, I found lots of less-than-reputable sites out there making claims it works. But they all read like my conspiracy-loving tnfoil-hat-wearing uncle in south TX wrote them.
    BravoDeltaRomeo and frichco228 like this.
  5. Jun 8, 2022 at 10:38 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Unless you fill your tank with lacquer, I wouldn't use it.
  6. Jun 8, 2022 at 10:39 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    We all know that if something is cheap and ACTUALLY WORKS it will be bought out and removed from the market to protect profits - just like those 100 mpg carburetors from the 1960's (or was it 70's?). :tinfoilhat:;)
  7. Jun 8, 2022 at 10:49 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Dale Gribble finds that reference to be offensive. When they really are out to get you, is it still paranoia?
    5N0W808, Jernik and Hightide like this.
  8. Jun 8, 2022 at 11:21 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I know some guys who attend Paranoid's Anonymous...but they won't tell me where they meet!
    5N0W808, shifty`, Jernik and 2 others like this.
  9. Jun 8, 2022 at 11:28 AM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Most common issue that we would see that destroys a catalytic converter is running a higher octane fuel than is recommended. Trying to find this big article I had from a previous life in order to dissuade people from running 93 in their four and six cylinder econoboxes with the low, low compression ratio engines. Just couldn't get lots of people to stop throwing their money away and "burning most of that extra octane" in their exhaust/converters. Unless you're up there in the 10 to 1 compression area or higher, it's not doing you any favors to run the high octane fuel. I always assumed it got the converter to a higher temp than it could handle and would just destroy that honeycomb/matrix inside.
    gosolo likes this.
  10. Jun 9, 2022 at 9:45 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Doesn’t lacquer thinner attack the plastic gas tanks? Just another reason to avoid this “fix”...
