Largest Spare Tire size
Discussion in 'Wheels & Tires' started by C2Tundra, Feb 10, 2023.
  1. Feb 10, 2023 at 11:06 AM
    C2Tundra
    C2Tundra [OP] New Member
    Looking to upgrade tire sizes on my 23 Limited. I wanna replace the spare tire with the same size that I will be upgrading too. What is the largest tire size the spare tire well will facilitate? Thanks in advance.
  2. Feb 10, 2023 at 11:23 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I know for a fact a 35 will fit in the location.
    SC4333 and Taco-Spike like this.
  3. Feb 11, 2023 at 5:54 AM
    Beams37
    Beams37 New Member
    Did you have to lower the tire pressure?
  4. Feb 11, 2023 at 7:57 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Negative. 35 and full pressure
  5. Feb 11, 2023 at 8:50 AM
    worksjo
    worksjo New Member
    2023 Tundra SR5 Off Road
    A 35” tire will fit but I think there are considerations for the spare wheel size to be aware of.
    I watched a video that stated that the spare wheel is 18x7.5” wide and should not have a 35x12.5 tire on it as the minimum spec for wheel width is 8” on that tire size. It was recommended to go 295/70r18 on the spare max.
    This was for my SR5 Off-Road though which comes with 18” OEM wheels. I do not know if the Platinum with 20” OEM wheels has the same spare.
    DrLulz likes this.
  6. Feb 11, 2023 at 3:39 PM
    Beams37
    Beams37 New Member
    I'm not sure how to interpret this. I'm planning to throw it up there and see what happens.
  7. Feb 11, 2023 at 3:39 PM
    Beams37
    Beams37 New Member
    Thanks.
  8. Feb 11, 2023 at 7:56 PM
    TrailKiller
    TrailKiller New Member
    CJ
    540 Virginia
    2023 TUNDRA SR5 BLUEPRINT 4x4 Factory Lift & Loaded
    2023 MY:
    Im sitting on the 20" 's w/265's from factory and considering this as well, had inquired at the Dealership and got a negative. Current spare is the OEM original 18.
    Don't feel like throwing 900 at another wheel/rim that has to be stowed in the bed.
    Hopefully someone figures it out soon.
  9. Feb 11, 2023 at 8:00 PM
    Does that apply to the 3rd gens? That's what OP has.
  10. Feb 11, 2023 at 9:12 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yep my buddy has a gen 3
  11. Feb 11, 2023 at 9:21 PM
    Is he gonna supe it up like your truck? Two generations of long travel baja blasters? :)
  12. Feb 12, 2023 at 6:51 AM
    osu1978
    osu1978 New Member
    It sounds like a 34.5" diameter tire will work but the width of a 35x12.5 is far from ideal on a 7.5" width rim. Baja Boss AT 295/70r18 is at 34.5" but works for wheels in the 7-10" range. Should be a viable option but expensive and heavy for a spare.
  13. Feb 12, 2023 at 9:43 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I just got my 5th tire and wheel and have yet to put under the truck. I believe that the 295/60/r20 is ~34" diameter. I feel confident that it will fit in place of the spare based on what others have experienced.
    I really wanted to make sure that I had the same size spare to prevent any stress on the differentials.
  14. Feb 14, 2023 at 12:30 PM
    99ways2die
    99ways2die New Member
    FYI:
    285/60/20 Cooper AT3 XLT on a OEM Platinum rim fits just fine under the truck, in place of OEM spare.
    (just mounted mine)
    Weirdly enough - anyone else notice how the spare is off-center under the truck?
    I thought I was not lining it up correctly when winding up, but after getting under the truck and checking, it looks like the whole spare tire bracketry/etc is off to the passenger side.
    Toyota.........
    -99
    SC4333 likes this.
  15. Mar 6, 2023 at 6:26 PM
    frogg3r
    frogg3r New Member
    I was able to fit my full size spare. 18x9 SCS F5 wheel with 35x12.5 Toyo Open country AT3. I had to air it down to 20 psi to fit
  16. Mar 6, 2023 at 7:50 PM
    mambajack
    mambajack New Member
    I am running a 315 70 17 baja legend exp that is 34.6" diameter, it barely fits. as expected the larger width stick down more then the original
    SC4333 likes this.
  17. Mar 6, 2023 at 7:57 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I had no idea until Les Schwab mounted my full size spare off center, I was pissed but assumed that was the only way it went in. Last week I dropped my spare and cut my mounts off to help it tuck up better (huge improvement!) and walked over to check out my neighbors platinum- his stock spare was off center as well!
  18. Nov 29, 2023 at 7:41 PM
    rhoffman3
    rhoffman3 New Member
    R
    2023 Tundra Hybrid
    Hey @reywcms. Could you please post your buddy's tire make/model and specs and what trim they have for the Tundra? Limited, SR5, etc? Thanks a ton!
    -R
  19. Nov 29, 2023 at 10:02 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Well it’s now on 37s. The 35s were maxxis razor MT. SR5 I believe with the long bed pic attached
    Tundrastruck91 likes this.
  20. Dec 1, 2023 at 12:20 PM
    rhoffman3
    R
    2023 Tundra Hybrid
    Thanks @reywcms . Your buddy has a nice rig. Do you know if he got the 35" Maxxis Razors in the spare tire well with no issue? Thanks!
  21. Dec 1, 2023 at 12:31 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yes, he did have the 35" maxxis in the spare area.
  22. Dec 1, 2023 at 12:48 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Nice, now I know my full size 295/70 18 will fit!
  23. Dec 1, 2023 at 1:26 PM
    rhoffman3
    R
    2023 Tundra Hybrid
    Thanks great news. Thanks @reywcms . I just ordered some 34.6" BFG KO2s, 285/65R20 on my Limited 2023 Tundra so I am hopeful I won't run into any issues. I'll plan to update here with the results.
  24. Dec 1, 2023 at 5:59 PM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    Adding another data point to the thread:
    Toyo Open Country AT3 35 x 11.5 x 17 C-rated at 35 psi mounted on a Method 703 17 x 8.5 fits in the spare location.
    It’s a tight fit with 3/8” to 1/2” of breathing room to the panhard bar but I’ve experienced zero rub or interference in 2,000 miles including about 100 miles of forest service roads and mild trails.
    Black widow TRD likes this.
  25. Dec 2, 2023 at 6:51 AM
    rhoffman3
    R
    2023 Tundra Hybrid
    Thanks @Cassidy1866! That's also helping me feel confident that this purchase is going to work.
    Cassidy1866 likes this.
  26. Dec 2, 2023 at 7:20 AM
    Todd34
    Todd34 New Member
    I have the same tires mounted on 17" Icons and it fits as well. It's tight but no issues so far.
  27. Dec 2, 2023 at 8:55 PM
    Dtrancrx
    Dtrancrx New Member
    Do you guys have pics of the 35s mounted up there?
  28. Dec 3, 2023 at 11:44 AM
    Cassidy1866
    @Dtrancrx Here are a few different angles. I unintentionally wiped off the dirt on the panhard bar when messing around with that penny, trying to get it to balance without having to hold it. Should give some perspective on the amount of breathing room between tire and bar. It’s close but no rubbing.
  29. Dec 3, 2023 at 11:49 AM
    Dtrancrx
    Dtrancrx New Member
    Awesome..thanks for posting them
  30. Dec 3, 2023 at 11:50 AM
    rhoffman3
    R
    2023 Tundra Hybrid
    Thanks @Dtrancrx! That's really cool of you to take the time to take these photos for us.
