Largest tire for stock 2022 Tundra Limited
Discussion in 'Wheels & Tires' started by Conrad77, Sep 25, 2024.
  1. Sep 25, 2024 at 8:56 AM
    Conrad77
    Conrad77 [OP] New Member
    Hey Tundra owners.. I have a 2022 Limited tundra. Stock tires are 265/60/20. Anyone been able to put a larger Tire on without lifting? I've been told 285/60/20 or 285/55/20 will work. Comments please.
  2. Sep 25, 2024 at 9:00 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Conrad77[OP] likes this.
  3. Sep 25, 2024 at 9:02 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    ahhh man if only anyone has ever asked this question before.
    Believe it or not you're the first person to ask this question......
    Its a good thing this question hasn't been answered at least a 200+ times ....
    Conrad77[OP] and chrisgibbs707 like this.
  4. Sep 25, 2024 at 9:27 AM
    Conrad77
    Fixed the title typo, my apologies and thanks!
  5. Sep 25, 2024 at 9:29 AM
    Conrad77
    If I go any tire size larger, will the speedometer or anything else need to be adjusted?
    I read 275/60 and 65 /20 works without rubbing or needing a lift.
  6. Sep 25, 2024 at 9:43 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    285/65 or 295/60 on a stock 20” is common
  7. Sep 25, 2024 at 9:59 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    These sizes on the STOCK OEM rims might rub the UCA.
    Safe bet is 275/65/20 which is TALLER than 285/60/20 and 295/60/20.
    FYI - Toyota/Lexus Speedometer is about 2-3% SLOWER comparing to real GPS speed so getting the bigger tires (2-3% bigger) will just balance that out.
  8. Sep 25, 2024 at 11:47 AM
    Northern Toyota
    Tires and bilstein
    285/65/20 is taller and will fit. Not sure the offset on factory 20” wheels but 295’s have been on my 23 tundra for a year and 15k no issues.
  9. Sep 26, 2024 at 9:34 AM
    GoHuskers
    Nebraska
    Can you share some pics of your wheel/tire combo? Are you stock with No leveling and no lift? I'm interested in 295/60/20 on Black OEM OR Wheels. Thanks.
  10. Sep 26, 2024 at 10:38 AM
    Northern Toyota
    Tires and bilstein
    my wheels are 18”. This is with a 1” cornfed level up front but I had the tires installed before the lift with no issues
    SoCal_Erik likes this.
  11. Sep 27, 2024 at 12:54 PM
    Conrad77
    Thanks for the info Tundra owners! Went with 275/60/20 Nitto Ridge grapplers.
