Leather Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zed, Oct 5, 2020.
  1. Oct 5, 2020 at 9:32 PM
    Zed
    Zed [OP] New Member
    Houston Texas
    2017 Brown 1794 Tundra
    How often do you guys put leather protection on your seat?
  2. Oct 5, 2020 at 9:35 PM
    GODZILLA Introverted Troglodyte
    Do you have stock leather, or aftermarket?
    Stock Toyota leather is not true leather. It's essentially got a plastic coating, so leather conditioners and the like won't actually penetrate into it. If the protectant you're talking about is something that stays on the surface to protect it then it might have some benefits. If it's a leather conditioner that is supposed to be absorbed into the leather, however, it will not do anything for stock "leather" seats.
    P-Factor likes this.
  3. Oct 5, 2020 at 10:05 PM
    Zed
    Zed [OP] New Member
    Houston Texas
    Does that apply to the 1794 edition leather also?
  4. Oct 5, 2020 at 10:12 PM
    As far as I know it is all Toyota leather. Full disclosure, I could be wrong on the 1794.
  5. Oct 6, 2020 at 3:34 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I believe the 1794 and platinum are Lexus leather, and the lower trims aren't. I use chemical guys leather detailer about once a month, and the conditioner about every 3 months, depending on how dirty they get from the dogs.
    Spyker and HulkSmurf14 like this.
  6. Oct 6, 2020 at 4:00 PM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    Own a Lexus also. No real difference between it and the leather in my Pro when cleaning or "moisturizing".
    Any processed / dyed leather gets treated. I remember reading someone said to use detailing spray on it because it basically has a clear coat on it.
    Black Wolf and GODZILLA like this.
  7. Oct 6, 2020 at 4:01 PM
    @jhuey8947 could probably give you the best advice.
  8. Oct 6, 2020 at 4:06 PM
    @Ckatz53 you are our interior detailing master. Any tips on the leather?
  9. Oct 6, 2020 at 4:13 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    I'm fairly certain my split grain "cowhide" Limited seats are true leather. My leather conditioner works quite well actually. Granted they're not untreated shoe leather which in that case you'd use mink oil for the best results.
    Saltyhero13 likes this.
  10. Oct 6, 2020 at 4:17 PM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
  11. Oct 6, 2020 at 4:29 PM
    I use Surf City Garage Voodoo Enthusiast Grade 20201006_172726.jpg on my Limited "leather" seats. Pricey but good stuff..especially made for car seat leather treatment.
  12. Oct 6, 2020 at 4:53 PM
    My leather seats do have natural flaws that only real cowhide can have. I used to work with leather a lot. Years ago. Lots of leather work. Hand engraved and special tools to make kuul belts, purses, holsters, chaps, wallets. Still have all my stuff in storage. Haven't done it for quite some time. I'd get all my leather from Tandy. Quite familiar with split and full grain hides. Used to tan our own cowhides and deer/elk pelts. Made rattlesnake skin belts and hat bands. Depends on the leather how you treat it. Suede is the hardest to clean and treat without f'ing it up. Leather car seats? Easy
  13. Oct 6, 2020 at 5:00 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Short answer: at least once a year, or whenever I feel like the product has worn down. But I'll explain below if you care to read my long winded experience with leather.
    My understanding/research is most all new leather is manufactured with a protective layering that keeps the leather soft and supple underneath. This essentially nullifies any true conditioning of leather seats as the layer does its job and stops leather conditioners from penetrating the surface. Conditioners will soften the layer overall and make it appear "conditioned," but that feeling wears off rather quickly (compared to if you conditioned an old baseball glove) as it doesn't exactly penetrate the material. That's not to say conditioners do not help aesthetically, they just don't last as long as if it was on true old leather. Now if you're putting it on a 20 year old daily driving vehicle, more than likely either A) the leather is old school and never came with the layering technology or B) the protective layering did its job and has likely worn over time. This doesn't stop me from applying a conditioner to new vehicles on my detail work, as it adds a nice sheen and soft touch. Perception is reality, but I still explain to folks how their leather seats work if they're curious.
  14. Oct 6, 2020 at 5:04 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    As far as I know all of the "leather" in Toyotas is the SofTex imitation leather. That doesn't necessarily mean that it's worse than old fashioned leather, but a lot of dudes I know that have it get extremely upset when you tell them that their Toyota pickup truck didn't come with seats that rival a $3000 leather chair.
    GODZILLA likes this.
  15. Oct 6, 2020 at 5:14 PM
    Real leather will stretch, have imperfections, will crease over time, and crack if not treated. Fake leather doesn't have those properties.
    Ckatz53 likes this.
  16. Oct 6, 2020 at 5:22 PM
    Split leather is used for most "leather " truck seats. Naturally full grain premium cowhides used for high end furniture and Lambo's will cost a small fortune. Handfitting, cutting, trimming, and handstitching doesn't come cheap.
  17. Oct 6, 2020 at 5:23 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    Except that it does. The vinyl seats in the old Ford work trucks we used to have used to do the exact same thing.
    Anyway, no need to start a back and forth. Modern leatherette is very nice quality and superior to old fashioned real leather in almost every way.
  18. Oct 6, 2020 at 5:25 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    I had the pleasure of sitting in a Bugatti at a car expo once and that stuff definitely felt different from a pickup truck, you're right on that one.
  19. Oct 6, 2020 at 5:27 PM
    That old vinyl leatherette crap and new will split and crack after awhile. Quite familiar with it. I know what leather is....
  20. Oct 6, 2020 at 5:29 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    Like I said, no need for a back and forth. I've had this conversation many times with triggered dudes in person. Our trucks have leatherette, it is what it is.
  21. Oct 6, 2020 at 5:35 PM
    The side bolsters, seat backs, and head restraints are not real leather, but the seat and seat front is real leather.....takes the most abuse. It is what it is...oh...not triggered....
  22. Oct 6, 2020 at 5:37 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    That's great, you're a step ahead of most. Swing by and we'll have some beers and shoot the shit.
  23. Oct 6, 2020 at 5:40 PM
    Got relatives in Anaheim Hills, Irvine, and Fullerton. I lived in Orange County when it was mostly orange groves and Irvine was still a ranch. I like beer too:thumbsup::burp:
  24. Oct 6, 2020 at 5:43 PM
    Blaaaaaaack....!
  25. Oct 6, 2020 at 5:46 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    The only color of Tundra that true men of taste and class own! Also the fastest by far. :thumbsup::D
  26. Oct 6, 2020 at 5:50 PM
    Of course. The truth hurts when it comes to not so super whites......It's The Way.....ha!
  27. Oct 7, 2020 at 8:53 AM
    husker99trd
    husker99trd New Member
    2016 TRDCM
    It is high quality Full Gain leather that is used in the Platinum and 1794 Tundras. I was told that is was "Lexus" leather buy a sales person back in 2014 and never verified it, my mistake. So I called 1-800-Toyota today and got the correct answer which is its Full Gain Leather.
    FYI..The Limited uses Split Leather which is coated and embossed. I also got that answer from 1-800-Toyota
    Spyker and Black Wolf like this.
  28. Oct 7, 2020 at 9:13 AM
    traveller09
    traveller09 New Member
    David
    Seattle Area
    2005 G500 & 1995 911. Looking to buy 1/2 ton truck mostly for overlanding and daily driver.
    Not sure if you all have tried "Leatherique". I have been using it for many years on my 911 and other cars, along with some leather chairs and couches in my house. I love their products.
    No affiliation. http://www.leatherique.com/products.html
  29. Oct 13, 2020 at 11:25 AM
    JGG10
    JGG10 New Member
    Minnesota
    2024 Lunar Rock Tundra Limited TRD Off-Road w/3" TRD Lift Kit
    TRD 3" Lift Kit, Method NV Double Black, Falken Wildpeak A/T4W 35x11.5r18
    I have a Platinum and I believe it is Lexus leather. Honestly, I don't put protection on it, but its in amazing shape; definitely different leather than the limited by the sounds of it.
