Leather seat issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by nocatch, Apr 18, 2019.
  1. Apr 18, 2019 at 3:07 AM
    nocatch
    nocatch [OP] New Member
    2018 tundra 1794
    Hi I am new to this forum, if there is anyone on this Here that has a 2018 Tundra 1794 and is having problem with the leather seats please let me know. My truck has about 13K and the front leather is already sagging and I am able to see 4 dots on the seat cover. please feed back would be great because Toyota corp. Is say that its wear and tear so its not cover under defect material.
  2. Apr 18, 2019 at 3:20 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Could you post pictures of the sag and dots?
  3. Apr 18, 2019 at 4:36 AM
    nocatch
    2018 tundra 1794
    I am not hard at all, I take good care of my stuff. I bought my 2007 limited new and that leather was excellent with 98k when I trade it in and it was sold by the dealer in less than a week. I will try and post pictures.
    Thanks
  4. Apr 18, 2019 at 4:37 AM
    nocatch
    2018 tundra 1794
  5. Apr 18, 2019 at 4:41 AM
    nocatch
    2018 tundra 1794
  6. Apr 18, 2019 at 4:42 AM
    nocatch
    2018 tundra 1794
    The second picture was my 2007 limited edition
    Mountun Goat likes this.
  7. Apr 18, 2019 at 4:43 AM
    nocatch
    2018 tundra 1794
  8. Apr 18, 2019 at 4:47 AM
    nocatch
    2018 tundra 1794
    If you can see the 4 dots on the seat base. I believe that is caused by the vent holes that Toyota has on the inner foam so that the air can flow to the leather for cooling and heat. And Toyota wants to tell me it wear and tear.
    rockmup and Mountun Goat like this.
  9. Apr 18, 2019 at 5:46 AM
    TXTundra2722
    2015 Black Tundra
    I could be blind. . or it could be the picture, but what dots?
    Hostage81 likes this.
  10. Apr 18, 2019 at 6:32 AM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    The sag is from how you get in/ out of the seat.
    The material /bolster cushion is the same on both sides of the seat however the concern is only seen on the exit side. Cushion material does break down over time.
    As for the Dots, I see them. Your suspicion is likely correct.
    OEM's typically use several different types of materials on seats even if it is just advertised as leather.
    In order for seats to have a cooling function, the seat needs to breath so perforated materials are used.
    The perforated section is likely a synthetic material (TPU/UL) either for better breath-ability, performance, durability, thickness consistency etc.
    I have seen these materials dis-color when exposed to specific chemicals/elements. (propane forklift exhaust on parts in a warehouse).
    I suspect that the TPU/UL is being exposed to something causing it to discolor. Sunscreen can also cause this to painted surfaces.
    The dots would be something i would at least file a claim on to ensure Corporate is aware.
  11. Apr 18, 2019 at 6:52 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    The side is from your entry/exit. I have 67k on my platinum seats and they are ok. I'm also careful of how I slide my 200lb butt across them.
    Inquiringone likes this.
  12. Apr 18, 2019 at 7:11 AM
    tundra403
    tundra403 New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    I've been told that even in the 1794 edition the leather is nicer.. but its still not just the greatest. I wanted leather but ended up going wiht an SR5.. after a few years, i plan to get Katzkin leather and maybe heated seats when the time comes.
    tenntundra and stuckinohio like this.
  13. Apr 18, 2019 at 7:18 AM
    bigblue14
    Craig
    The platinum and 1794 have the same grade of leather. Different color and the suede inserts are the only difference. The leather is the same as the LS Lexus.
  14. Apr 18, 2019 at 8:19 AM
    Heff
    Heff New Member
    2017 Tundra Limited
    I have a 2017 Limited, is the leather in my truck of lesser quality than the 1794 or Platinum, or is it just different in appearance?
  15. Apr 18, 2019 at 8:23 AM
    nocatch
    2018 tundra 1794
    I think that is the best thing you did because there is a Big difference on the Katzkin material and workmanship
  16. Apr 18, 2019 at 8:25 AM
    bigblue14
    Craig
    I don't know much specifically about the limited leather. I know that Toyota made a point for the 2014 update to say the platinum and 1794 had that leather. So my guess would be that limited isn't the same. They certainly feel different.
    Heff[QUOTED] likes this.
  17. Apr 18, 2019 at 8:35 AM
    Heff
    Heff New Member
    2017 Tundra Limited
    I have noticed they feel different. I know they have been using that softex in some vehicles, but they don't use it in Tundras, do they?
  18. Apr 18, 2019 at 8:38 AM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    "Leather interior" means it meets industry standard % for leather content.
    There is a big misconception that leather interior mean 100% leather.
    You could source the "same leather" from one supplier but process and grade it differently to provide different quality levels.
  19. Apr 18, 2019 at 9:16 AM
    dmproske
    dmproske New Member
    david
    2018 CrewMax Limited
    Our 2018 Platinum Sequoia has real leather. I was told its Lexus grade leather. Whatever the case it appears to be of high quality.
    My 2018 Limited Tundra has "pleather" as in synthetic leather, or fancy vinyl. Its high quality and will wear well over time if treated right.
    Leather seats will wear well if you are mindful of how you get in and out of the vehicle, and keep them clean and conditioned. Neglect them and drag your full body weight across them getting in and out of the truck will cause them to look like shit and crack in a few years.
  20. Apr 18, 2019 at 10:04 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I like a little patina on brown leather. But then I had horses when I was a kid so...
  21. Apr 18, 2019 at 10:08 AM
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    I’ve got a 2016 1794 and am experiencing the same issue. The wear on the front seats isn’t holding up well and I only use it on the weekends. I’ve got 50k miles on it so I’m hoping they don’t turn terrible in the next couple of years.
  22. Apr 18, 2019 at 11:56 AM
    nocatch
    2018 tundra 1794
    West Texas can you post a picture of the seat because I only have 12k on my truck and it’s not good.
  23. Apr 18, 2019 at 1:09 PM
    multirc
    multirc New Member
    Ron
    2018 Tundra 1794 Edition
    I have a 2018 1794 and don't have those dots. I have the little sagging on the side but thats about it. I would argue about the “wear and tear” to Toyota Corp since the truck is only a year old. I can see wear and tear happening after 5 years or so but not one year. Especially those dots.
  24. Apr 18, 2019 at 1:17 PM
    dgtulsaguy
    dgtulsaguy New Member
    18' 1794
    I put covers on my 18' 1794's seats at about 25k but they were nearly perfect when they went on
  25. Apr 18, 2019 at 1:42 PM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Will do.
    I’m seeing some wear on the edge where I’m sliding in and out of the seat. I currently have 56k miles on a 2016.
    nocatch[QUOTED][OP] likes this.
  26. Apr 18, 2019 at 1:46 PM
    nocatch
    2018 tundra 1794
    Hi Ron can you send me pictures of your seat it will be greatly appreciated because I am getting things ready for Toyota Corp. At this moment they are telling me that it’s not covered and it’s wear and tear. I got my truck on 6/24/18 so it’s not even a year and this problem started in December. Thanks for your help
  27. Apr 18, 2019 at 2:03 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I’ve got a 16’ 1794 and I read a different thread about this issue. Since them I’m very careful on how I get in/out of drivers seat only. What I’ve figured out is don’t slide your butt over the outside bolster. It takes the most wear & tear.
    The rings that are appering, no doubt from heat / cooling mechanism. Is your truck still under warranty ? If so I’d go back to dealership and pitch a bitch.
    That’s just me, my dealership appears to be a fair one. Good luck, keep us posted on any up dates.:popcorn:
  28. Apr 18, 2019 at 2:28 PM
    nocatch
    2018 tundra 1794
    I this point, I have opened a case with Toyota and waiting on them to send a rep to look at the seat and make a decision on replacing. I understand your explanation on getting in and out of the truck. But that should not be the cause especially when you pay 50k for a truck. That is Toyota BS and they are playing with the wrong person. That is the reason I want as much pictures and miles of people that has one of these truck. Note this is my second tundra and I had absolutely no problem with my other leather and it had 98k when I sold it. Thanks for your help
    West Texas Tundra likes this.
  29. Apr 18, 2019 at 2:38 PM
    multirc
    multirc New Member
    Ron
    Thats weird..looking at my seat with the naked eye, I dont see any circles but in the pics I posted, you can see them very faint. Is this the same scenario as you or you can plainly see them?
    FE62CABF-0839-4165-B3C4-2670F6C44E15.jpg 505CD80D-AFFC-4EE6-BA8D-198A2AB31605.jpg
  30. Apr 18, 2019 at 2:46 PM
    nocatch
    2018 tundra 1794
    Thanks for the pictures how many miles on yours? Yes on mine you can see it with naked eye. That’s how I was able to file.
    Tundyfundy likes this.
