LED Bulbs that don't hyperflash
Discussion in '2.5 Gen Tundras (2014-2021)' started by mestes1999, Aug 23, 2023.
  1. Aug 23, 2023 at 8:35 AM
    mestes1999
    mestes1999 [OP] New Member
    Marcus
    2020 Tundra SR5 CrewMax
    Anyone have a link to LED bulbs for turn signals which don't hyperflash? I don't want to do resistors. Surely there are bulbs that have them built in or something? What's so hard about this?
  2. Aug 23, 2023 at 8:40 AM
    Taco-Spike
    Two Trucks
    for front or rear? Both?
    some trucks get different results using LED's, some get hyper flash and some don't.
    are you not wanting resistors due to having to splice? there are options out there where resistors can be added without splicing and wires ~ just plug and play
    1lowlife likes this.
  3. Aug 23, 2023 at 8:42 AM
    mestes1999
    Marcus
    Both preferably. That's correct, I don't want to splice.
  4. Aug 23, 2023 at 9:08 AM
    minter66
    minter66 2007 TSS CrewMax
    This is by far the best way. The bulbs I used that had built in resistors failed within 1 hot Texas summer. This was easy and still works perfectly today. I imagine the process is similar to 2014-2021 as not much changed with the core electronics.
    https://www.youtube.com/watch?v=ORqtLwXfy-4
    Wallygator likes this.
  5. Aug 23, 2023 at 9:22 AM
  6. Aug 23, 2023 at 10:15 AM
    mestes1999
    Marcus
    Which are what?
  7. Aug 23, 2023 at 10:21 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    bulldog93 likes this.
  8. Aug 23, 2023 at 10:44 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I got some from SuperBrightLED.. but had to use a resistor.
  9. Aug 23, 2023 at 11:07 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  10. Aug 23, 2023 at 11:17 AM
    mestes1999
    Marcus
    Thanks for the help everyone
    Jaypown likes this.
  11. Aug 28, 2023 at 6:55 AM
    mestes1999
    Marcus
    So there's enough room for the resistor packs between the tail light housing and the truck body itself? No heat/melting plastic issues?
  12. Aug 28, 2023 at 7:31 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    The VLED resistor has double-sided tape on it, but I used a couple of self-tapping screws as well.
    Plenty of room between the tail light and the truck body.
    They aren't cheap, but I love my Hottail LED bulb tail light setup I got from @memario1214
    They work with the OEM tail light.
    They also come with resistors that do not require splicing..
    Tundra Total Taillight Kits - Hotshot Offroad | Toyota Tundra Forum (tundras.com)
    HotTails | 2014-21 Toyota Tundra – Hotshot Offroad
    bulldog93 and memario1214 like this.
  13. Aug 28, 2023 at 7:41 AM
    mestes1999
    Marcus
    Thanks so much for the pics, really helps.
  14. Aug 30, 2023 at 5:27 PM
    JohnnyWaffles
    JohnnyWaffles New Member
    San Jose, CA
    '14 TRD
    I got these a few months ago and was one of the best mods I've done. Along with changing out the headlights for new Toyota factory LED housing.
    1lowlife[QUOTED] likes this.
  15. Sep 4, 2023 at 10:52 AM
    mestes1999
    Marcus
    So I got the VLEDs, but the one of the wires is too thick for the duotap to clamp shut. The yellow wire fits fine, the white one is thicker, barely fits and won't stay shut even after pliers. If I hold it closed with pliers it works fine but if not, it hyperflashes.
