LED illuminated grill emblem
Discussion in 'General Tundra Discussion' started by Husky570, Apr 12, 2023.
  1. Apr 12, 2023 at 5:51 AM
    Husky570
    Husky570 [OP] New Member
    Has anyone installed one of these? The wiring instructions are terrible, it’s supposed to illuminate when the headlights come on. I didn’t want to tap into the headlight harness, it shows connecting to the negative battery Terminal and somewhere in the fuse box.
    If anyone could help with the wiring connection so it comes on with the headlights and is tied into the fuse box that would be great!
  2. Apr 12, 2023 at 1:24 PM
    Husky570
    Is it a good idea to power it off of one of the fuses in the fuse box?
  3. Apr 12, 2023 at 1:42 PM
    Hopefully you don't have a 2018+, because you would have to relocate the TSS sensor.
    Hook it up like this....
    Install t-tap onto a 12V power wire (parking light wire is a good option) or if you want the lights on all the time you could utilize and add a circuit and tap into the fuse box to a keyed on circuit, or t-tap into any keyed on 12v power wire.
    RobertD likes this.
  4. Apr 12, 2023 at 4:34 PM
    Husky570
    Thank you sir!
  5. Jun 16, 2024 at 1:20 AM
    WhiteDevil1978
    WhiteDevil1978 Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    What is the size of the emblem? I have a 2023 Tundra, but I don't know if the size is right. Thanks!
  6. Jun 16, 2024 at 3:20 AM
  7. Jun 17, 2024 at 2:02 PM
    WhiteDevil1978
    Dustin
    I've seen the different sizes, but I am unsure of the measurements. I don't know exactly how they measure an emblem like that. I figured that businesses would just make it easy and list the sizes with the year and model if vehicle, but none that I have found has done so.
