LED's and Glare in Snow
Discussion in 'Lighting' started by aaronoto, Jan 5, 2020.
  1. Jan 5, 2020 at 9:19 AM
    aaronoto
    aaronoto [OP] New Member
    My Tundra is the first truck I've head with LED's. Do you guys find that the glare from the LED's is horrible in the snow, especially at night when it's snowing heavy? I was thinking of swapping my fogs out for a set of Baja Design Squadron's, but was going to go white, now I'm thinking I need something amber up front....
  2. Jan 5, 2020 at 9:26 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Yes, yellow lights are better in snow and fog. You can look to get some Amber covers or laminx makes yellow covers you can tape on the led lights
    TheBeast and GODZILLA like this.
  3. Jan 5, 2020 at 9:37 AM
    omgboost is correct. The issues with glare have nothing to do with they type of light (LED, HID, etc.) and everything to do with the color/temp of the light. The yellow or amber lights don't reflect in such a glaring way, so they are better for seeing through debris like snow or dust.
    Zebruaj, TheBeast and Pinay like this.
  4. Jan 5, 2020 at 12:38 PM
    Professional Hand Model
    Hand Protectors
    They make an LED bulb that does all 3 types of light out of the same bulb. You just toggle through the switch and go from white, yellow, to amber depending on your preference at the time.
    BravoDeltaRomeo and HulkSmurf14 like this.
  5. Jan 5, 2020 at 2:00 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I'd like to see how well they perform...I couldn't imagine that well with three varying options...but, technology is getting better with every thought...
  6. Jan 8, 2020 at 4:08 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Don’t forget about the in-cab adjuster. It can help lower the beam/light pattern
    Mickeydog likes this.
  7. Jan 9, 2020 at 2:46 PM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Amber in the Fog Lights with Snow is no myth! It truly does make a great deal of difference in Thicker Conditions! :) Living up in Northern Minnesota, I personally ran GTR Lighting 3000k 35w HIDs for my Fog Lights for Years and LOVED that setup!
    Aerindel likes this.
  8. Jan 9, 2020 at 2:48 PM
    Aerindel
    Aerindel New Member
    Montana
    The truth is, LEDs are worse at pretty much everything except power consumption. People think they look cool but in practical terms they are pretty bad and worsen visibility in actual tests, even if people think they 'look' better most of what they are seeing actually is not helpful.
    TTund16 likes this.
  9. Jan 9, 2020 at 2:54 PM
    Atlanta, GA
    I dunno man... LEDs definitely made my night time driving easier, so much so that I put in a Job Application with HR after upgrading my own vehicle with LEDs! For example, The new MLED 2.0 LED Projector is INSANE to say the least! The correct LED for the right application is 110% going to be an upgrade from factory Halogen. :) You just need to make sure that A.) the Right LED is used in the Right application and B.) that they are Installed and adjusted properly for the ideal performance and the Road Safety of others!
    In Snowy conditions, I can see where a Brighter LED could limit visibility with the Glare that can reflect off Snow, but you still will have a better Distance/Hotspot down the road to provide more Distance Visability, which is the Name of the Game with Snowy Driving. This is where I always recommend for those who deal with the Fluffy White stuff more often than others to run an Amber Fog Light to level out that Visibility. :)
    Kerch71 and Black@Blue19 like this.
  10. Jan 9, 2020 at 6:45 PM
    Aerindel
    Aerindel New Member
    Montana
    The issue is the quality of the light itself is a type that reflects back at you worse than incandescents. You can make LEDS that work great but that isn't what most people want, even a lot of OEM headlights have become terrible because costumers associate that blue white glare with 'high tech' etc.
    And a lot of people don't care about blinding other drivers....which even if you don't care about them, makes it more dangerous for you if they are headed at you at 70 MPH and are blind.
    But yes, amber is better than white or blue. Red would be the best but of course there are reasons you can't use that for headlights.
    The focus/delineation of those in your picture is really impressive.
    TTund16 likes this.
  11. Feb 20, 2020 at 10:09 PM
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    That's definitely not how the new 2019 headlight beams look like.
  12. Feb 21, 2020 at 2:13 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Agree 150%. Distance visibility with my LED head and fog lights is crazy good. Not even a comparison to halogens imo. I haven't had any snow this year so I can't really speak to the glare. But I can get amber covers for my BD Squadrons if the need arises.
  13. Feb 21, 2020 at 3:31 AM
    Atlanta, GA
    That’s the MLED 2.0 Bi-LED Projector assembly for Retrofitting, here is one I’m installing into a 15-17’ F150 Headlight.
  14. Feb 21, 2020 at 6:07 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Technically, the yellow halogens are easier on the eyes, so it is better for on-coming drivers and for you. But the issue is that halogens do not put out as much light without consuming a lot of energy and putting out a lot of heat. Therefore, HID and LED steps in to solve either the light output part (HID) or both (LED). I have 3 cars, one with Halogen (VW Diesel Wagon), one with HID (Nissan Armada), and one with LED (Tundra with OEM LED). I can tell you that the halogens in my VW are the worst of the 3 at night. I cannot see crap. The HID and LED are much better. The HID is the best with light output.
    Headlight Revolution likes this.
  15. Feb 21, 2020 at 6:20 AM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    I just bought these in yellow to replace my factory LED fogs to help with rain, fog, dust, and the occasional snowy conditions I find myself in. Another downside to the LED in icy driving conditions is since they don't get warm, the ice can build up on the lights and limit their output.
    https://www.lightwerkz.net/index.ph...ght-led-lighting/stage-series-type-b-kit.html
    I also purchased these to replace my front blinkers when I noticed how dim the factory bulbs are. These are a 100% improvement over stock. Everyone with the new headlights need to buy these.
    https://www.lightwerkz.net/index.ph.../7443-7440/7443-high-visibility-amber-50.html
  16. Feb 21, 2020 at 6:29 AM
    motoryder
    motoryder ^^ I probably crashed after that pic
    Rancho Cucamonga, CA
    2500HD AT4
    I bought a set of these for the foglights in my wife's 4runner. (I think the company was LAsfit?) They are very bright through all colors, but its very important to make sure that they're clocked correctly and aimed properly. Since you're installing an LED bulb going into a halogen reflector, if you don't clock them and aim the light, it will be a scattered mess.
  17. Feb 21, 2020 at 6:34 AM
    Yellow or amber light has a longer wavelength. White light has a shorter wavelength. Longer light wavelengths are less scattered by fog molecules suspended in the air making amber lenses/lights ideal for fog.
  18. Feb 21, 2020 at 6:38 AM
    Cfincke
    San Antonio
  19. Feb 21, 2020 at 6:49 AM
    Atlanta, GA
  20. Feb 21, 2020 at 6:59 AM
    Cfincke
    San Antonio
    Yes sir!
    20190826_064441.jpg i am 10 feet from the wall as i was aiming the SS3 pro fog lights
  21. Feb 21, 2020 at 7:12 AM
    Atlanta, GA
    Nice pick on the Panamera shrouds too! :thumbsup:
    Cfincke[QUOTED] likes this.
  22. Feb 26, 2020 at 10:19 AM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    Those new MLEDs are no joke
    My retros and the SS3 Pros make a killer combo
