Leer Camper Shell Wiring
Discussion in 'Tonneau Covers, Caps and Shells' started by 7UNDRAAZ, Oct 1, 2022.
  1. Oct 1, 2022 at 5:52 PM
    7UNDRAAZ
    7UNDRAAZ [OP] New Member
    New to this page, I picked up a Leer shell for my truck. Previous owner stated he had it wired to lock/unlock with his key fob. Stated it was a PITA to do so. I was wondering if anyone here has done it and knows what wires to tie into? I also have the locking tailgate so could I not tie into that? TIA
  2. Oct 1, 2022 at 10:49 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Not a pain at all if you already have your tailgate wired to lock you just tap into those same wires. I have my tailgate and leer cap both wire to lock with the fob.
    7UNDRAAZ[OP] likes this.
  3. Sep 1, 2023 at 2:28 PM
    csgaddy
    csgaddy New Member
    Since you recently bought a leer shell, I figured you might be a good person to ask. I recently bought a leer camper shell and have the wiring harness. I have hooked everything but there is an extra plug that I believe has to be run back to the battery. My question is did you have to run a line back to the battery in order for your brake light on the shell to work? Right now I've hooked everything up but I'm not getting power to anything so I'm assuming this is because I need to run that last connection back to the battery.
  4. Sep 1, 2023 at 10:18 PM
    Joe333x
    Joe333x Member
    Boston
    No you dont need to run it to the battery. You pull out your taillight and tap into the brake light for the third brake light. For the dome light you can tap the taillight wire but then you can only use the dome light when your taillights are on.
    csgaddy[QUOTED] likes this.
  5. Sep 5, 2023 at 6:23 PM
    marcelo73
    marcelo73 New Member
    So Cal
    2016 Toyota Tundra Crewmax TRD PRO QUICKSAND
    295/70 18 Coopers
    Anyone have any experience with the simple two wire wiring. The dome light with acc switch on is not convenient, I will see what I can find with my probe light.
  6. Sep 5, 2023 at 7:11 PM
    biebs96
    PA
    I would suggest running a two pair wire from the cap to under the driver footwell.
    When I had my previous tundra with a cap, I wired the cap dome light to the footwell light.
    It would turn on with the cabin lights, fade on/off and if needed on for a long period, just leave a door cracked.
  7. Sep 5, 2023 at 7:40 PM
    Joe333x
    Joe333x Member
    Boston
    I am planning at some point to wire mine to the bed light so I can turn the dome on and off with that switch. Any 12v will work though but unfortunately I believe there is no constant 12v on the trailer hitch either.
    marcelo73[QUOTED] likes this.
  8. Sep 5, 2023 at 7:46 PM
    marcelo73
    So Cal
    295/70 18 Coopers
    I really like this idea...thank you.
    biebs96[QUOTED] likes this.
  9. Sep 5, 2023 at 7:59 PM
    2000 Limited TRD AC 4X4 Thunder Grey 272k miles. 2019 Limited TRD CM 4x4 - SOLD
    Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper - Rhino Vortex rack
    Get one of these and the light will come on anytime you open the back glass
    RecPro RV Gas Strut Switch for Automatic Lighting | 12V Automatic On/Off Switch for RV Compartment Light https://a.co/d/36AYOvK
  10. Sep 5, 2023 at 8:12 PM
    biebs96
    PA
    it was my favorite when I would unlock the truck and the cab and cap would all fade on and be illuminated.
