Leer topper can't be wired to my 2023
Discussion in '3rd Gen Tundras (2022+)' started by Scottarue, Jul 12, 2023.
  1. Jul 12, 2023 at 5:44 PM
    Scottarue
    Scottarue [OP] New Member
    Scott
    2004 White Tundra Extra Cab 4.7L
    I have a 2023 Platinum that I bought a Leer topper for. The topper dealership cannot wire the topper to the Tundra for some reason. Can't seem to make the proper connections. Has anyone else had a similar problem?
  2. Jul 12, 2023 at 6:18 PM
    ryanjay11
    ryanjay11 New Member
    There are several folks on here with toppers that have been wired to their trucks.
    If they don't know what they are doing, I'd just go this route.
    Ltaco17 likes this.
  3. Jul 13, 2023 at 4:36 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    Take it some where else. If the topper dealership is unable to hook up lights it's probably best to move along.
    IslandStyle, Kap1 and Tom like this.
  4. Jul 13, 2023 at 9:39 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    You've got an incompetent shop. They make up excuses not to do a little bit of research or trying...
    My shop installed camper shell no problem and wired camper door locks so it locks unlocks from my fob.
  5. Jul 13, 2023 at 10:07 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Agreed with the others here. I have a Leer 100XR and have had it for about 7-8 months. Zero problems with the wiring. Leer even makes a mid 7-pin connector harness that makes it super simple.
    Don't let them feed you any bull about the complexity of wiring on a hybrid either. I don't have a hybrid, but I've already seen a lot of hybrids with Leer toppers.
    Unfortunately, it sounds like you've got a terrible shop on your hands.
  6. Jul 13, 2023 at 12:23 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    First hybrid with a topper here, took the dealership some back and forth with leer and a new harness but they knocked it out last year! Your shop just sucks
    Ltaco17 and pwpblue like this.
  7. Jul 15, 2023 at 10:28 PM
    NATE4SURF
    NATE4SURF New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    Just got my leer and wired up. Has DC ports and the key fob locking. It took them a bit longer than normal they said but they did it.
  8. Jul 18, 2023 at 11:15 PM
    NATE4SURF
    Laguna Hills, CA
    Here’s mine.
    IslandStyle likes this.
  9. Jul 20, 2023 at 1:18 PM
    IslandStyle
    IslandStyle New Member
    Oregon
    2022 SR5 DC: Blueprint, TRD Premium Off Road AND 2004 SR5 DC: Charcoal
    Same experience here. Got mine installed last November. It took a bit for my shop to sort it all out but they dialed it in. All the lights and the lock work great. It can certainly be done and as another poster mentioned, if your shop says they can't do it ask them for an install credit and take it to someone who can.
  10. Jul 27, 2023 at 4:58 PM
    Scottarue
    Scott
    I started this thread... Good news is that after the THIRD time in the Leer dealership shop, they got the interior dome light and the third stop light working. Is it really that hard?
    silverhack likes this.
  11. Jul 30, 2023 at 6:51 PM
    tundraKitKAt
    tundraKitKAt New Member
    2023 tundra sr5
    They probably have monkeys working for them, any real aftermarket shop tech would know where to get a tap for any kind of accessories, beacons, lights etc.. I ordered a "ROO LIGHT" switch for my lightbar and Beacon switch that fit nicely in the left switches panel. Wired those in direct from battery and fuse relay. Light Bar and Beacon but run on their own switches and work well.
    It alarms me that a "Truck cap" company that sells caps for a living couldn't figure out how to get the lights working.
    Id be scared of your "Third" time in on how they achieved this hopefully they didn't tie into a specifically needed 12v tap somewhere and called it a day.
