Less expensive Molle Panels for bed
Discussion in '3rd Gen Tundras (2022+)' started by 2020Platinum, Aug 23, 2024.
  1. Aug 23, 2024 at 7:32 AM
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Took a chance on these less expensive Molle panels, much less expensive than the “big name” brands. Easy install, rock solid, couldn’t be happier. Link is in video description if ya wanna check them out, definitely worth saving some $!
    Molle Panels for Your Truck Bed. Save Some Money!
    https://youtu.be/14zUdp3G1-4
  2. Aug 23, 2024 at 8:06 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Killer setup. Found something to ‘save’ money by buying.
    Do you have a solar panel to charge those batteries?
    BTW, I used your video and discount code for the Carlinkit setup. That works well. I can’t get it to auto connect to my phone’s hotspot though if you have a ‘fix’ for that. Great videos.
    2020Platinum[OP] likes this.
  3. Aug 23, 2024 at 12:44 PM
    TRD_TUNDRA
    TRD_TUNDRA New Member
    2024 Tundra TRD Off Road and 2024 Sequoia TRD Pro
    I saw the same video and agree those are really nice for the money. I ordered a set but sent them back. Unfortunately they didn’t fit in combination with my Bakflip MX4 tonneau cover. I’ve been thinking about it some more and I may order them again and cut them up to fit since they are so cheap.
  4. Aug 25, 2024 at 4:42 AM
    2020Platinum
    Patrick
    Northeast PA
    Thank you, I appreciate all the support on the channel!
    so no solar yet, but it’s in the plans. I have a total of 400ah back there so honestly I never have to worry about running outta juice. lol. I use a Renogy 50A DC to DC charger that tops them off while driving, I have a video on that as well, it works great.
    for the Carlinkit, that’s actually an issue with the phone settings. I talk about it in my last video on the Carlinkit UHD, I get asked about that a lot. I did some testing and figured out that it has nothing to do with the box itself, it’s a security feature on the phone’s end. I kinda stumbled on it by accident after all my testing, my laptop won’t even auto connect to my phone hotspot without me manually going into the phone and allowing it, it’s a pain. That’s actually why I just went back to paying for wifi in the truck, Carlinkit auto connects every time and I don’t have to worry about it anymore (I know, first world problems)
    yea absolutely, that’s why I didn’t mind chopping that end piece off to work with my Retrax, they’re so inexpensive compared to other brands, but yet they’re great quality.
  5. Aug 26, 2024 at 8:17 AM
    MaineTundy
    I don’t see a 6’ bed option. The 5.5 work might work as long as it does not cover the light & distance to wheel well is the same.
    Yeah I found the same thing on the Carlinkit autoconnect. It’s the phone. It will auto connect if I have Settings->hotspot open when I start the truck. I was hoping you found a hack as I can’t be expected to take that extra step. The horror.
    Nice on the dc to dc charger. I have a 800 watt Renogy setup at a remote camp so I always wonder what folks have going on.
  6. Aug 30, 2024 at 2:52 AM
    2020Platinum
    Patrick
    Northeast PA
    Yea I love that battery setup with the Renogy DC to DC and the inverter. Total game changer for my trips away from home!
    if you want me to measure from tailgate to lights/wheel wells for the panels, let me know. Happy to help!
  7. Sep 15, 2024 at 7:56 AM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    Camburg 4-Link, Bed Molle panels, Pelican cargo bin, TRD drop-in Filters
    Hello group,
    Looks like they are sold out with no due in date.... But anyway, Will this system not work on 5.5 beds with tri-fold tonneau covers and drop down rails? If so, that's a bummer. This "cheaper" system appears to have a better design & looks. There are cutouts for the bed lights, where other designs cover the lights...
    Just my thoughts...
  8. Sep 15, 2024 at 2:59 PM
    2020Platinum
    Patrick
    Northeast PA
    Hey! Here’s a different brand, but in all honestly they’re basically identical. Don’t see any reason it wouldn’t work with your setup, hope it helps!
    https://www.amazon.com/dp/B0DB5Q7XSN
    kamaaina1[QUOTED] likes this.
  9. Sep 16, 2024 at 6:02 AM
    kamaaina1
    2024 Tundra TRD PRO
    Just purchased. We’ll see how the install goes, if at all. Thank you!
  10. Sep 20, 2024 at 11:38 AM
    kamaaina1
    2024 Tundra TRD PRO
    Well, no bueno on the Amazon molle bed panels. Will not work with the drop rail system. I tried every-which way, but no-go. The brackets just don't line up. Close to 1" off. Bummer. The search continues for a molle bed panel system that with work with a tonneau cover with drop rails in the 3rd. Gen's. Other that removing the tonneau cover, anyone have other manufacture suggestions? I checked with BuiltRight. No go either.
    charlOOsi and Black widow TRD like this.
  11. Sep 21, 2024 at 11:28 AM
    charlOOsi
    charlOOsi New Member
    I've been looking too. I've even been waiting to see if anyone has done any custom stuff that I can copy. No go. I wish someone would make one cause having MOLLE on the side is so helpful.
  12. Sep 21, 2024 at 7:45 PM
    kamaaina1
    2024 Tundra TRD PRO
    I already returned my product, but, on second thoughts, maybe there’s a possibility of a spring nut that may work within the drop rail system. Not sure how that’s gonna line up with the corner anchoring bolts though.
  13. Mar 18, 2025 at 1:54 PM
    Ramez Anis
    Ramez Anis New Member
    2024 Toyota Tundra limited TRD Off Road
    I think this is the only brand that has the T brackets like the one you installed. The other ones have different brackets that seems to install behind the rail. Unfortunately, this one is out of stock. The other one that you posted wouldn't work for me unless I remove the retrax pro tonneau cover to get behind the railing, then install it back once the panels are mounted.
    Looks good though. I wish they were still available.
  14. Mar 18, 2025 at 2:16 PM
    Ramez Anis
    I may have found the exact panel on Ebay... I am trying to get a hold of the seller and will report back if I end up buying one.
  15. Mar 18, 2025 at 5:27 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I got one with the behind the rail attachment that won't with with my cover. Would like to find a t bracket option.
  16. Mar 18, 2025 at 5:30 PM
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    If any can scan or draw a set up I have a waterjet at the shop......I'm planning to do a hall height option to work with my Decked drawers ...probably will grab a 3D Scanner for that and a few other projects...
    E
  17. Mar 18, 2025 at 7:32 PM
    Ramez Anis
  18. Mar 19, 2025 at 9:37 AM
    sandiegosteve
    San Diego
  19. Mar 19, 2025 at 9:50 AM
    Ramez Anis
    I just noticed that too... I placed my order yesterday when it showed that he had 5 in stock. I will update here once I hear back from the seller (I sent him a message inquiring about availability).
  20. Mar 20, 2025 at 6:55 AM
    Ramez Anis
    It looks like it was coming from China... The seller was being a bit weird and asked me to cancel my order twice... Makes me feel that he doesn't have the panels in stock. Oh well. I cancelled the order.
  21. Apr 14, 2025 at 1:24 PM
    Spacecowboy863
    Spacecowboy863 New Member
    looks awesome! thanks for sharing
