Leveling kit interfere with safety sensors?
Discussion in 'Suspension' started by Lowry1967, Nov 25, 2018.
  1. Nov 25, 2018 at 4:25 AM
    Lowry1967
    Lowry1967 [OP] New Member
    Anthony
    Toyota tundra limited crew Max
  2. Nov 25, 2018 at 4:32 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Leveling kit is fine as long as your not doing hardcore offroad. Spacers will give a harsher ride over speedbumps and such.
  3. Nov 25, 2018 at 4:37 AM
    Lowry1967
    Anthony
    I'm reading it can mess up your safety sensors and cruise control radar . You know anything about that . Thanks for your input .
  4. Nov 25, 2018 at 4:38 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    In-coil spacers will give a harsher ride. Top spacers not. Although extreme situation like a speed bump will probably bottom out quicker, yes.
  5. Nov 25, 2018 at 4:40 AM
    Welcome from Ohio!
  6. Nov 25, 2018 at 4:44 AM
    Nm6300'asl
    2022 DC SR5 4x4
    I ran top spacers in 3 different tundras for over 750k miles, dont kid yourself they make the front end ride stiffer. They work fine and make the truck look great but it sure will not ride like stock.
  7. Nov 25, 2018 at 4:45 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Yes it can have an effect on all the safety sense stuff. Just be prepared if you decide to do it. If you are never going to go off road, blocks and spacers should be fine.
    Lowry1967[OP] likes this.
  8. Nov 25, 2018 at 5:53 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I leveled mine by dropping the rear... an air lift system was added to retain towing & payload.
    ColoradoTJ likes this.
  9. Nov 25, 2018 at 6:19 AM
    Welcome from Texas
  10. Nov 25, 2018 at 7:15 AM
    To answer your question, yes it can effect the TSS. From the limited exposure I have had with it, one can go get it recalibrated at the dealership.
    Search @Vizsla posts on what he did with his truck. Great resource for this topic.
    Lowry1967[QUOTED][OP] likes this.
  11. Nov 25, 2018 at 7:19 AM
    Nm6300'asl
    2022 DC SR5 4x4
    I have 6112's at top setting and toytec shackles on my '18, no issues with Tss, or radar cc.
  12. Nov 25, 2018 at 12:17 PM
    Lowry1967
    Anthony
    Thanks for all your help help.
  13. Nov 26, 2018 at 4:34 PM
    NY98M3
    NY98M3 New Member
    What do you mean by "In-coil"? Top Spacers?
  14. Nov 26, 2018 at 4:43 PM
    Boerseun
    Ferdie
    Sarasota Florida
    There might be different names for it, but basically there are 2 types of spacers.
    1. In-coil spacers (coil spacer) go inside the coilover assembly. You have to take the spring top plate off to install the spacer between the spring and the top plate. So in a sense the spacer is inside the coil over assembly.
    2. Top spacer (strut spacer) bolts to the top of the assembly , or in other words outside of the assembly.
    There are pros and cons to both. I am on my phone so I can't find it now, but I have a good summary article that I can post. I will search for that tomorrow.
