Leveling ride height on 21 SR5
Discussion in 'Suspension' started by eagleguy, Dec 11, 2022.
  1. Dec 11, 2022 at 3:59 PM
    eagleguy
    eagleguy [OP] New Member
    Ok guys I know this has been beaten to death but here I go.
    Please give me the make and part number of the shocks needed to get my Tundra level. Fornt and back if necessary'
    Also if I went with just the spacers up front, what make and model works best?
    Thanks and don't be mad that I didn't search, posting this on the run!
  2. Dec 11, 2022 at 4:20 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Good luck in your search, man!
    PermaFrostTRD likes this.
  3. Dec 11, 2022 at 4:41 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    A spacer is a spacer. Anything made of strong enough material will function. They require the bumpstops to be spaced as well, which means you have less suspension travel. Ride is gonna suck.
  4. Dec 12, 2022 at 12:56 AM
    sbtownsend7
    sbtownsend7 New Member
    2021 Barcelona Red Tundra Limited
    Nothing.....YET
    I used Bilstein 5100s on the middle setting and it made my 21 Limited DC sit level. I've used Low Range Off Road spacers in the past, but it lifted the whole truck (Front 3", rear 1") and you lose some of your turning radius because of the bump stops. I've been very happy with the look and ride with the 5100s.
    ATV25 likes this.
  5. Dec 13, 2022 at 2:38 PM
    eagleguy
    What is the ride like going from OEM to 5100 Series Bilsteins?
  6. Dec 13, 2022 at 8:04 PM
    sbtownsend7
    Nothing.....YET
    Honestly i really couldn't tell much difference at all. Didn't change it much at all.
  7. Dec 14, 2022 at 12:43 AM
    Zoso
    Zoso New Member
    SE Georgia
    2021 Cement DC LTD
    The ride from a spacer is NOT gonna suck. Travel will be limited, but the ride is the same. Just make damn sure you get the alignment right after install.
  8. Dec 14, 2022 at 5:33 PM
    eagleguy
    Did you go for a level look? What size spacer??
  9. Dec 14, 2022 at 5:50 PM
    eagleguy
    I see some are made of Nylon and other out of aluminum
  10. Dec 14, 2022 at 6:36 PM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    David
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
  11. Dec 14, 2022 at 6:54 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    nylon is going into the coils. Thats definitely gonna make it rougher. Aluminum is a puck on the top of the shock.
    any increase in height affects the ride. No way around it with a 2-2.5 inch lift
  12. Dec 15, 2022 at 12:41 AM
    Zoso
    Zoso New Member
    SE Georgia
    2021 Cement DC LTD
    WFD473 likes this.
  13. Dec 15, 2022 at 4:54 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    My suggestion would be 5100's on the middle setting. The cost isnt much more than nice spacers when you are all done. Alignment with any setup.
    You may end up 1/4" to 1/8" lower on the driver's side. I can't see it but if I measure the lean is there. There are shims you can buy to correct that.
    https://www.suspensionlifts.com/sho...bilstein-5100-height-adjustable-front-shocks/
    I'm running 5100's on the top setting. It measured close to level but the tundras look nose high when perfectly level. I ended up putting tapered 1 inch blocks in the rear. Debated rear shackles but I want to make sure I can shove a larger tire where the spare goes first. I do plan on going to 34.6" tire when I'm close to needing new, for a little more ground clearance and to balance out the look of the lift/tires a little better.
  14. Dec 17, 2022 at 4:46 PM
    eagleguy
    Going with the Rough Country spacer set up. My friend just got the Bilstein 5100 set up and I was not happy with the ride on top setting which looked like level. To each his own. Thanks guys
  15. Dec 17, 2022 at 4:48 PM
    eagleguy
  16. Dec 18, 2022 at 1:58 PM
    JediMedic86
    JediMedic86 New Member
    Cole
    2021 Cavalry Blue Tundra SR5
    Rough Country rear bumper, AJT interior products, TufSkinz interior products, BakFlip bed cover, BedRug full bed liner, Rough Country 2” strut leveling kit with rear N3 shocks.
    @eagleguy I used Rough Country 2” leveling struts in the front and RC N3 shocks in the rear. I’m happy with the stance. 0037925B-C634-4EE0-9568-B13A29B56279.jpg1C717F09-BC28-4E4D-8504-2A31E37A2D4A.jpg
  17. Dec 18, 2022 at 2:07 PM
    JediMedic86
    Cole
  18. Dec 18, 2022 at 2:28 PM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    Eibach Stage 2 Pro Truck right out of the box gives 2 1/4” in the front giving 1/4” rake. My truck has no side to side lean.
