leveling
Discussion in 'Suspension' started by tmtundra, Apr 2, 2022.
  1. Apr 2, 2022 at 7:54 AM
    tmtundra
    tmtundra [OP] New Member
    2017 tundra trd off road
    looking for leveling kit for 2017 trd off road
  2. Apr 2, 2022 at 9:44 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Apr 8, 2022 at 4:49 AM
    Robert241
    Robert241 New Member
    Robert
    2015 Toyota Tundra SR5 TRD
    N/A
    What’s a good configuration for a leveling kit, I was thinking 3” in the front and 1” in the rear, does that sound/look good, I’m having trouble finding that configuration setup on existing trucks.
  4. Apr 8, 2022 at 6:41 AM
    frichco228
    Tundras have 2 inch rake, except the Pros which are 2 inches higher in front and level. So a 2 inch lift in front will level the truck.
  5. Apr 8, 2022 at 7:42 AM
    BamatundraSC
    BamatundraSC New Member
    Greer, SC
    2021 SR5 CM
    TRD Pro grille, color matched hood bulge, TRD Pro headlights, color matched front bumper end caps, Rough Country two inch loaded front struts, Matte black SCS Ray10’s, Cooper Rugged Trek 275/70/18, Rough Country tri fold hard bed cover, Dirty deeds 12” exhaust
    @Robert241 to @frichco228 point and to give you an idea, this is my truck with the Rough Country 2” loaded front struts. Stock height on the back.
    nobodyintexas likes this.
  6. Apr 8, 2022 at 12:07 PM
    Robert241
    Robert
    N/A
    Ok thanks, I like your truck, and you just saved me some extra work i would have had to do.
    BamatundraSC likes this.
  7. Apr 9, 2022 at 7:19 PM
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Thanks. I appreciate it! She’s come a long way since this picture.. 1B2A0B32-5118-4825-8FEE-02C08DB33218.jpg
    pvn.beluga and ATV25 like this.
  8. Apr 10, 2022 at 8:01 AM
    Tundra_Enthused
    Tundra_Enthused New Member
    Vancouver Island, BC
    2018 Quicksand Tundra TRD Off Road 2015 Toyota 4runner Sr5
    Fuel 18" Vector wheels, toyota tonneau cover, trd pro suspension upgrade, back up lights wired into reverse lights, tow mirrors
    I was contemplating for so long on how to level my truck with out braking the bank and using pucks or spacers. Ran across some trd pro bilstein remote resi front and rear on a used local site here in town. Saved quite a bit. Here are some photos. Sits nice and level. Raised the front about 1.5 to 2 inches and now it rides like a dream! Threw 500 lbs of potted plants in it the same day and handled super well.
  9. Apr 17, 2022 at 6:57 PM
    jaflynn738
    jaflynn738 New Member
    Truck looks great, what size tires, wheels and offset?
  10. Apr 18, 2022 at 3:54 AM
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Thank you. 275/70/18, SCS Ray 10 with +20 offset. The tires do poke out from the fender about an inch.
  11. Apr 18, 2022 at 4:36 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Measure your truck to see what your current rake is. I have seen on other discussions here that it varies from truck to truck (double cab vs crew max, 2x4 vs 4x4 etc. all add to the mix).
    I have a 4x4 Crew max and mine is exactly 1.5 inches, so I have a 3" front and 1.5" rear for exactly level, within 1/16" all the way around. Others have 2.5" front and 1.5" rear for level. and some have 3" front 1" rear.
  12. Apr 18, 2022 at 7:39 AM
    Tundra_Enthused
    I have just lifted the front about 1.5 inches by adding the trd pro suspension. Added rear too but i dont think it lifted the rear any with just the strut
  13. Apr 18, 2022 at 11:07 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    The rears will require AAL or Shackles to lift. Looks good though!!!
  14. Apr 18, 2022 at 11:51 AM
    Tundra_Enthused
    Ofcourse i just dont want to lift the rear its perfectly level now
  15. Apr 18, 2022 at 11:53 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Are you planning to load anything onto the bed? Or even tow?
    I’d probably even suggest getting Total Chaos Fab shackles since it’s only about 3/4”.
  16. Apr 18, 2022 at 1:00 PM
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    I just recently threw Bilstein 5100's on my truck and set the front ones on the middle setting and I think it looks pretty level.
    Tundra Dude 45 likes this.
  17. Apr 18, 2022 at 1:15 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Here’s what my 17 looked like w stock rims and tires after bilstein 6112 on top setting in front and 5160 on rear. Stock a arms, alignment was great. E51C3DCE-0078-4FDD-96CD-5BE60E3CF87F.jpg
  18. Apr 18, 2022 at 4:40 PM
    Tundra_Enthused
    Oh man the first day i had 5 100 lb potted plants in the box and it was a dream. I have a tent trailer with not much tongue weight but i will give the 3/4 shackles some thought
    pvn.beluga[QUOTED] likes this.
  19. Apr 20, 2022 at 4:24 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    This is my truck with 5100 up front middle setting stock shock on back. 2FDD80FF-4AAF-4BC2-8CAF-E66F5E62FB73.jpgF1EDF9B5-A7E9-449B-AD5A-6B18F008D201.jpg
  20. Apr 20, 2022 at 4:38 PM
    Tiamat
    Tiamat New Member
    Yes sir, I did 5100 in middle at almost two inch in the front. After measuring its a little less that 1/2 lower in the front id say 3/8 but it looks lever to me.
  21. Apr 26, 2022 at 1:36 PM
    TuTun
    TuTun New Member
    Colby
    South east
    16 MGM Limited Crew 4×4
    Under frame puddle lights 18+ black led headlights i hacker headlight harness w/dimmer Honeycomb grill 2" Supreme Suspensions front leveling kit
    2" Supreme suspension leveling kit with spacers and differential drop. Pic looks high in front but actually the front sits 1/2" lower than the rear which is about my target. $100 for kit and $390 installation. Can't tell any difference in ride smoothness.
    Tundra Dude 45 and Boerseun like this.
  22. Jun 15, 2022 at 8:43 AM
    DudeWheresMyZ71
    DudeWheresMyZ71 Stop the world and let me off
    21 Tundra TSS 4x4
    I know this post is a couple months old, are those true OEM mirrors or knock offs? Love the truck!
  23. Jul 31, 2022 at 7:17 PM
    Robert241
    Robert
    N/A
    Where did you find the TRD Bisten shocks, I think I may want to go in that direction. Thanks for any help you can give me on this.
